How to know whether my system has Intel-pstate driver by default?
Just now I read a blog on Intel-pstate driver (to control cpu temperature) and I want to know whether it’s baked to the kernel or I have to install manually.
If I have to install it manually, how to install it?
System Info:
  Kernel: 5.4.153-1-lts54 x86_64 bits: 64 compiler: gcc v: 11.1.0
  parameters: BOOT_IMAGE=/@/boot/vmlinuz-linux-lts54
  root=UUID=140ff4ed-d56a-4a46-8c79-545720e64c75 rw rootflags=subvol=@ quiet
  loglevel=3 nowatchdog
  Desktop: Cinnamon 5.0.5 tk: GTK 3.24.30 vt: 7 dm: LightDM 1.30.0
  Type: Laptop System: Dell product: Inspiron 15-3567 v: N/A
  serial: <filter> Chassis: type: 9 serial: <filter>
  Mobo: Dell model: 0D53F5 v: A00 serial: <filter> UEFI: Dell v: 2.15.0
  date: 06/16/2021
  Info: Dual Core model: Intel Core i5-7200U bits: 64 type: MT MCP
  arch: Amber/Kaby Lake note: check family: 6 model-id: 8E (142) stepping: 9
  microcode: EA cache: L2: 3 MiB
  flags: avx avx2 lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
  bogomips: 21599
  Speed: 2500 MHz min/max: 400/2500 MHz Core speeds (MHz): 1: 2500 2: 2500
  3: 2504 4: 2500
  Vulnerabilities: Type: itlb_multihit status: KVM: Split huge pages
  Type: l1tf
  mitigation: PTE Inversion; VMX: conditional cache flushes, SMT vulnerable
  Type: spec_store_bypass
  mitigation: Speculative Store Bypass disabled via prctl and seccomp
  Type: spectre_v1
  Type: spectre_v2 mitigation: Full generic retpoline, IBPB: conditional,
  IBRS_FW, STIBP: conditional, RSB filling
  Device-1: Intel HD Graphics 620 vendor: Dell driver: i915 v: kernel
  bus-ID: 00:02.0 chip-ID: 8086:5916 class-ID: 0300
  Device-2: AMD Sun XT [Radeon HD 8670A/8670M/8690M / R5 M330 / M430 /
  Radeon 520 Mobile]
  vendor: Dell driver: radeon v: kernel alternate: amdgpu bus-ID: 01:00.0
  chip-ID: 1002:6660 class-ID: 0380
  Device-3: Realtek Integrated_Webcam_HD type: USB driver: uvcvideo
  bus-ID: 1-5:3 chip-ID: 0bda:5769 class-ID: 0e02 serial: <filter>
  Display: x11 server: X.org 1.20.13 driver: loaded: ati,intel,radeon
  unloaded: fbdev,modesetting,vesa resolution: <missing: xdpyinfo>
  Device-1: Intel Sunrise Point-LP HD Audio vendor: Dell
  driver: snd_hda_intel v: kernel bus-ID: 00:1f.3 chip-ID: 8086:9d71
  class-ID: 0403
  Sound Server-1: ALSA v: k5.4.153-1-lts54 running: yes
  Sound Server-2: JACK v: 1.9.19 running: no
  Sound Server-3: PulseAudio v: 15.0 running: yes
  Sound Server-4: PipeWire v: 0.3.38 running: no
  Device-1: Intel Wireless 3165 driver: iwlwifi v: kernel port: e000
  bus-ID: 02:00.0 chip-ID: 8086:3165 class-ID: 0280
  Device-2: Realtek RTL810xE PCI Express Fast Ethernet vendor: Dell
  driver: r8169 v: kernel port: d000 bus-ID: 03:00.0 chip-ID: 10ec:8136
  class-ID: 0200
  IF: enp3s0 state: down mac: <filter>
Bluetooth:
  Device-1: Intel Bluetooth wireless interface type: USB driver: btusb
  v: 0.8 bus-ID: 1-8:5 chip-ID: 8087:0a2a class-ID: e001
  Report: rfkill ID: hci0 rfk-id: 1 state: down bt-service: not found
  Local Storage: total: 931.51 GiB used: 192.47 GiB (20.7%)
  ID-1: /dev/sda maj-min: 8:0 vendor: Seagate model: ST1000LM035-1RK172
  size: 931.51 GiB block-size: physical: 4096 B logical: 512 B
  speed: 6.0 Gb/s type: HDD rpm: 5400 serial: <filter> rev: SDM3 scheme: GPT
  ID-1: / raw-size: 100.1 GiB size: 100.1 GiB (100.00%)
  used: 8.12 GiB (8.1%) fs: btrfs dev: /dev/sda1 maj-min: 8:1
  ID-2: /boot/efi raw-size: 250.2 MiB size: 246.3 MiB (98.45%)
  used: 562 KiB (0.2%) fs: vfat dev: /dev/sda3 maj-min: 8:3
  ID-3: /home raw-size: 831.17 GiB size: 831.17 GiB (100.00%)
  used: 184.35 GiB (22.2%) fs: btrfs dev: /dev/sda2 maj-min: 8:2
  ID-4: /var/log raw-size: 100.1 GiB size: 100.1 GiB (100.00%)
  System Temperatures: cpu: 51.0 C mobo: 50.0 C gpu: radeon temp: 47.0 C
  Fan Speeds (RPM): cpu: 2555
  Processes: 230 Uptime: 2h 31m wakeups: 1 Memory: 7.65 GiB
  used: 2.41 GiB (31.5%) Init: systemd v: 249 tool: systemctl Compilers:
  gcc: 11.1.0 Packages: pacman: 906 lib: 245 Shell: Bash v: 5.1.8
  running-in: gnome-terminal inxi: 3.3.06
It’s part of the kernel it’s in the kernel. You can use the below command to check.
cat /sys/devices/system/cpu/cpu*/cpufreq/scaling_driver
For more information go here.
Thank you
