Brand new to EndeavourOS, I left Lubuntu to try something new. I’m installing libreoffice using:
sudo pacman -S libreoffice-fresh
Package then installs as expected, but then lists optional dependencies that could be installed, some of which I’ll need. Do I install the optional dependencies one by one using the package names Terminal gives me? Or is there a command I’m missing like -Sxx that would install everthing? I’ve searched the forum and web but haven’t seen this answered.
You can just type them all out in one shot.
pacman -Syu package 1 package 2 package 3 etc
Thanks for the reply. -Syu package1, etc., not, -S package1 ect.?
There’s little functional difference between the two.
-Syu $package
updates all packages at the same time as installing $package
-S $package
installs $package
Have a read through https://wiki.archlinux.org/index.php/Pacman/Rosetta
OK, thanks. I’ll check out the link.
