how do i get yakuake to activate with shortcut?
I LOVE the app but it would be nice to activate it quickly with a shortcut key like guake was superkey+fll if i recall correctly
i made it shown as an indcator but would rather hide it. i would rather though make it just activate with a shortcut key if possible??? IDK
The default shortcut is F12, I believe.
I tinkered with this a while ago and I’m pretty sure it tells you that on the first run and can be configured from there too, so you may have just missed it ![]()
OMG my brain, i can’t beleve… i think your right too ~ doh
Hey
Assuming your using Plasma 6
In KDE SystemSettings > Keyboard > Shortcuts> Applications you’ll see yakuake
I uncheck f12 and hit the button to the right that should say custom shortcut and choose what you like.
I prefer Alt+q or Alt+ESC to bring it up.
In app shortcuts
Alt+Shift+left/right arrow or up/down arrow= change window size (not permanent)
Ctrl+Shift+t = new tab
Shift+left/right arrow = switch tabs
Making yakuake better:
bottom right corner >Open Menu>Configure Yakuake > Appearance > Get New Skins > and when the window pops up type in at the top “minimal” and choose “breeze-minimal” by hannes
Right click in the Yakuake window and choose >Edit Current Profile> Goto left side > appearance> Goto right side and hit “Get New” button and search for “Vivid Blur Dark Konsole”
Enjoy
