Hello friends.
My pc is very old and only has BIOS, no UEFI/EFI (don’t know how to spell it exactly), so I can only format a SSD/HDD with MBR, I can’t format using GPT (someone correct me if I’m wrong).
So I want to format an SSD and a HDD, but I don’t know which format I should choose.
I am currently using Windows 10 + EndeavorOS with dual boot, because there are games on https://www.protondb.com/ that are 0% compatible with Linux (because of problems with Anti-Cheat blocking Linux) and I am forced to use Windows 10 (it is the only reason why I am still using Windows).
So I thought that if I want to have a hard drive that can access Windows and EndeavourOS, the only format that exists is FAT32, but I heard that it only supports 4GB files, so I couldn’t put big files on that SSD/HDD, right?
I don’t know of another similar format, so I have ruled out FAT32 because my files, games, backup, etc., exceed 4GB each.
(Currently I spend more than 90% of the time on EndeavourOS and it’s literally my main OS, but I don’t want to give up playing X games a few times with my friends. If I didn’t need to use Windows 10, I would just format all my SSD/HDD to ext4)
So for now I need to format 2 hard drives, one to Windows 10 basic format (NTFS), and the other to EndeavourOS format (ext4).
What is the correct way to do it?
Do you recommend another format/file system?
Should it be done from the terminal?
I found this for now, but I don’t know if this works for EOS/Arch, also I’ve seen different ways to do it and I don’t know which one is correct:
For example, imagine if I want to format my 1st SSD to FAT32, should I not put sda to 100% format it, instead of sda1, since sda can have 4 partitions:
sudo umount /dev/sda
sudo mkfs.vfat -F 32 -n NAME-SSD /dev/sda
press enter
I’ve seen people use different terminal commands, so which one would be correct for FAT32 and ext4?
Is the command to format an SSD different from the one to format an HDD?
Also how do I know if it’s a quick format, or a slow full format? I mean, when you format in Windows 10, you can do a quick format, or a slow deep format, I don’t know if this exists in Linux as well.
Sorry, I want to make sure I’m doing things correctly!
Thanks in advance friends!
NAME MAJ:MIN RM SIZE RO TYPE MOUNTPOINTS
sda 8:0 0 223,6G 0 disk
├─sda1 8:1 0 50M 0 part
├─sda2 8:2 0 119,4G 0 part
├─sda3 8:3 0 535M 0 part
└─sda4 8:4 0 103,6G 0 part /
sdb 8:16 0 223,6G 0 disk
└─sdb1 8:17 0 223,6G 0 part
sdc 8:32 0 232,9G 0 disk
└─sdc1 8:33 0 232,9G 0 part
