to fix pgpme not found
try find the file on /usr/lib/
then do symlink the actual file to filename that pacman looking for
for example :
cd /usr/lib/
sudo ln -s libgpgme.so.45.0.0 libgpgme.so.11
when pgpme not found in /usr/lib/
download the binary from here
extract
unzstd gpgme-2.0.0-1-x86_64.pkg.tar.zst
tar -xvf gpgme-2.0.0-1-x86_64.pkg.tar
rsync -av usr/ /usr/
then do symlink if pacman still cannot found the pgpme
symlink is only temporary recover to able to fix the pacman,
the correct one you must download the gpgme with version same as pacman required
