Hello everyone, I’m trying to connect to a remote computer using NoMachine but it doesn’t work. I keep getting error 107. This is the first time I’ve encountered this, maybe someone has had this problem, tell me what kind of error it is and how to fix it?
I will be very grateful for your help!
Just a hunch, if you have a recent EOS install (I don’t), I believe they started including a firewall package.
You can read about it at https://discovery.endeavouros.com/applications/firewalld/2022/03/
You may want to try the systemctl stop … command initially and see if you can use that app to connect to the other machine.
Hi! Most likely, this error means that the computer you are trying to connect to the remote cannot access the NoMachine service. To fix this error, try the following steps:
- Make sure that the correct IP address and port are set correctly (this can be done in the NoMachine user interface by opening the Server Settings > Services tab when working with the host you need access to)
- Make sure that the firewall configuration on the server and client machines is not causing the problem
- Check the status of nxserver on the server machine (to do this, open Server Settings (Server Settings > Services tab) and make sure the status is set to Running)
More details about each of the steps can be found here https://www.helpwire.app/blog/nomachine-not-working/
I hope I was able to help you.
