How to enable PHP gd module (solved)
Hi,
I’ve installed the PHP GD library with Pacman :
sudo pacman -S gd php-gd
But when I run the command php -m I don’t see the gd module enabled.
Does someone know the command to enable a PHP module on Endeavouros/Budgie?
Thx
It has been a long time since I used php but last time I did you had to uncomment the extension in php.ini or phprc
Get it in php.ini, thanks @dalto
I thought there was a cmd line to do this …
gd
For php-gd uncomment the line in /etc/php/php.ini:
extension=gd
https://wiki.archlinux.org/index.php/PHP#gd
Edit : Looks like you solved it :+1:
