I have the fingerprint reader working with login, lock screen, and sudo by editing the PAM files. But, how can I enable the fingerprint reader to work system-wide or is that not possible?
I am not 100% sure since I am not using a fingerprint reader but a Yubikey as sudo replacement.
If by “system-wide” you mean dialogs like this:
You need to edit /etc/pam.d/polkit-1
Yes, that’s the dialog I’m talking about PolicyKit1 KDE Agent
I edited /etc/pam.d/polkit-1
and it looked like it was going to work and then I kept getting an error.
I checked my enrolled fingerprint and it was deleted. So I enrolled it again. I tried again and same thing. I keep getting an error and my fingerprint keeps getting deleted.
I did just do an update. Maybe something in the update broke the fingerprint reader. I don’t know.
