there was a caps lock indicator in manjaro plasma. I couldn’t find a way to enable it in settings.
maybe this thread will help you? https://www.reddit.com/r/kde/comments/s7ir31/how_to_enable_caps_lock_osd_in_kde/
In the system tray, click on the ^ to show the hidden items. Right click on Lock Keys Status, choose Configure Lock Keys Status (which should be the only option) and a window appears. Click in the box on the left of Caps Lock so that it is enabled.
There is no lock keys status in the system tray for me
See here
To obtain this:
Pudge
Try installing kdeplasma-addons.
sudo pacman -S kdeplasma-addons
I believe that jasonmoofang/[LockState will only add the Key State plasmoid.
Any ideas how many things are added with kdeplasma-addons? I looked at the github site and didn’t see what exactly is added.
Pudge
Of course, one may have to try both, one at a time, and see which looks nicer.
Pudge
There’s a (long) file list here (scroll down).
