I have enabled apparmor.service
. I have followed the steps given in archwiki.
Open /etc/default/grub
with sudo permissions with nano or vim or vi or what ever is your favorite editor.
Open the terminal
$ export $EDITOR="your favorite editor"
$ echo $EDITOR --> to check that the editor is properly set
$ sudoedit /etc/default/grub --> it will prompt you for your password write it and hit enter
Now add in the line
GRUB_CMDLINE_LINUX_DEFAULT = " quiet apparmor=1 security=apparmor ..."
Save the file
$ sudo update-grub --> it will prompt you for your password write it and hit enter
Restart your pc / laptop
If you followed the steps then it should be enabled and working…
Did you also do the thing that immediately followed enabling the service?
Interestingly, this doesn’t follow what the Arch wiki says - why is there a difference here?
I’m almost certain that EnOS doesn’t include this wrapper. Copy-pasting something from another forum isn’t great, and especially so when it’s based on a fundamentally different distribution and so ends up being misleading.
I am getting an error. It says invalid argument
sorry i thought it should work in eos as not only manjaro but other ubuntu derivatives also follow this command
On Buntu and Manjaro, update-grub
either runs a script or is aliased to:
on Arch, btw, as well as on EndeavourOS, this alias does not exist.
Just copy-pasting a solution from another forum for another distro might be dangerous and you could cause more harm than good, if you do not understand what it does.
Some of us have popped in an alias that does the same thing - but it is not a default by any means. Easily fixed by posting the alias beforehand, or the full command in posts…
invalid argument
What does? When? Where?
In terminal while adding apparmor
to lsm=
That doesn’t make much sense - could you expand on exactly what you did?
For adding kernel parameters, choose the instructions for the bootloader you are using:
I did this on a machine recently and couldn’t get it to work following the arch wiki.
This is what worked for me:
sudo systemctl enable apparmor.service
sudo nano /etc/default/grub
find the line that starts with:
add this:
- Hold ctrl and O
Note: the letter O, not the number zero.
Hold ctrl and and press x
reboot
check if apparmor is running with:
systemctl status apparmor
or
aa-enabled
(deleted by author)
Could you please elaborate the methods. I could not understand what to do? How to determine your bootloader?
If you installed EnOS then you have GRUB.
