how to customize lock screen on EOS? lock screen means = windows key or meta key + L - and not SDDM lock screen ,
Xfce?
no KDE plasma
Haven’t used plasma for a while. But should be under settings>locking screen or similar.
only shotcut key and wallpaper set but i want change theme or something
I am not sure what else one could expect from a screen locker, it just locks the screen and shows an image. Perhaps there are other screen lockers with more options that can be installed via AUR.
Since I am not a knowledgeable kde plasma user, let’s see what other users say …
This is a list of screen lockers from Arch WiKi.
https://wiki.archlinux.org/title/List_of_applications/Security#Screen_lockers
Try these in a VM before changing your DE. Will save you some time and save you from breaking the system. Once you’re familiar with what to do you can change your own system.
