The technique used for displaying stuff on your TV is called Wi-Fi-direct. That means that your device is connected directly to your TV (comparable to a Bluetooth connection, although protocol and underlying technology differ, just to have an analogy). The same technique is used for example if you want to print from your Smartphone wirelessly without using your WLAN. As far as I know networkmanager and wicked do not support that kind of connection yet.
I might be wrong about it. The last time a had a look at it, was some time ago.
