local/libcanberra 0.30+2+gc0620e4-2
A small and lightweight implementation of the XDG Sound Theme Specification
local/libcanberra-pulse 0.30+2+gc0620e4-2
PulseAudio plugin for libcanberra
So they both seems not to be installed now. But they seems to handle sound where might there the relationship to graphics and gtk?
More interesting to me seems to be the last Fontconfig line.
Now I installed the snap-store snap. It starts but where there should be letters there are placeholders/rectangles instead like iit wants to use a font which is not installed or so.
Output:
[peter@monastir ~]$ snap-store
07:30:02:0052 Gs enabled plugins: odrs, rewrite-resource, snap, icons, key-colors, key-colors-metadata
07:30:02:0052 Gs disabled plugins: appstream, desktop-categories, desktop-menu-path, dpkg, dummy, epiphany, fedora-pkgdb-collections, generic-updates, hardcoded-blacklist, hardcoded-featured, hardcoded-popular, modalias, os-release, provenance, provenance-license, repos, shell-extensions
07:30:02:0211 Gs failed to create an app for */*/*/*/system/*
07:30:02:0218 Gs updates-shell: failed to get updates: no plugin could handle get-updates
07:30:02:0220 Gs failed to create an app for */*/*/*/system/*
07:30:02:0220 Gs failed to get system app
07:30:02:0220 Gs Only 0 apps for recent list, hiding
07:30:02:0230 GsPluginSnap Failed to load snap icon: local snap has no icon
07:30:02:0404 Gs hiding category graphics featured applications: found only 0 to show, need at least 9
07:30:02:0404 Gs hiding category productivity featured applications: found only 0 to show, need at least 9
07:30:02:0486 GLib g_path_get_basename: assertion 'file_name != NULL' failed
07:30:02:0486 GLib g_regex_match_full: assertion 'string != NULL' failed
07:30:02:0504 GLib g_variant_new_variant: assertion 'value != NULL' failed
07:30:02:0504 Gs not GsPlugin error g-io-error-quark:35: Invalid string value converting to GVariant
07:30:02:0505 Gs not handling error failed for action refine: Invalid string value converting to GVariant
07:30:02:0512 GsPluginSnap Failed to load snap icon: local snap has no icon
07:30:02:0690 GsPluginSnap Failed to load snap icon: local snap has no icon
@Peterl65
I launched it from the terminal and I’m getting the gtk error also. I think it’s trying to load a gtk3 file when it’s gtk2. Not sure though.
