just installed an ssd, mounted it, making sure it’s mounted when i boot my PC, but i still can’t use it, the mountpoint is read only, how to make it possible to read & write?
What filesystem?
EXT4 filesystem
Try changing the ownership of the mountpoint:
sudo chown user:user /path/to/mountpoint
Replace user with your real username.
how to know my username?
Type
whoami
in a terminal.
You don’t really need your username.
Just write:
sudo chown -R $USER:$USER [path/to/device]
should add the -R so it will make you owner of everything.
sudo chown -R $USER:$USER /path/to/mountpoint
Right.
-R, --recursive operate on files and directories recursively
However, in this case, it seemed that the partition didn’t contain anything to begin with.
At least that is how I understood it.
have you tried putting it in fstab? what file system is on the SSD personallyt I format my drives as soon as I install them get rid of ntfs system and use ext4. then check to see if its being reconignized by doing either sudo blkid or lsblk. you dont need sudo for lsblk
gotcha
