How to automount a usb drive
Hi All
I would like to automount a usb drive that has a ext4 file system when it is plugged in or when its plugged in when rebooting. How would I go about this?
Thanks
Most DEs/ file managers in DEs do it automatically. What edition are you using?
Hi @Rob-H,
welcome to the EnOS Forum :enos: :enos_flag: :penguin_face: :rocketa_purple:
Welcome to EOS, @Rob-H!
I’m using kde
then it’s mounted automatically in most cases.
what does your
lsblk
show
Have you looked at
Welcome to the forum @Rob-H :enos: :enos_flag: :partying_face:
That works. Thanks. Just have to fire out why its telling me I’m not authorized to mount it. Still have to open in dolphin
Got it working. Thankyou all for your help
Glad it works, please mark the post that helped you as the solution.
it is then very helpful for others with the same problem.
