there is no mountpoint because those partitions are not mounted.
open the file manager and click them!
Or open the terminal and read man mount
Are you new to Linux? Why did you expect it to be mounted?
Seems like an unmounted usb-installation media to me. Did you leave your usb stick on your pc after installation?
yes, iām new to linux. And i actually made it made it a bootable usb using dd. After using it i tried to format it. and this happened.
For formatting a device, it needs to be unmounted anyways.
