Let’s say I want to install EndeavourOS somewhere and perhaps over time I will come up with the idea to install other Linuxes because I want to try out some things in real life (not only VM).
What would be a reasonable size of /efi?
I know @dalto has a lot of systems on his disk. How large is your /efi partition?
It depends on your hardware as initrd sizes vary. Also, different distros save differing amounts of data there. 1GB is usually more than enough for 2 distros as long as you don’t go crazy installing kernels.
When I had 7 distros on one machine I was using 2GB for my /efi
Many distros store the images in the ESP even when using grub so it really depends.
