The Problem
So the problem is, basically, i cannot figure out how to switch kernels within GRUB. I have 3 kernels WITH
headers:
linux | linux-headers
linux-lts | linux-lts-headers
linux-zen | linux-zen-headers
How do i switch between kernels within GRUB?
pebcak
2
Doesn’t the Grub boot menu show up at boot from which you could choose the kernel you want to boot?
yes, the problem is that it only has 2 options: boot to endeavour os with Linux linux AND fallback initframs, it doesn’t have the rest
pebcak
4
Could you run the following command:
sudo grub-mkconfig -o /grub/boot/grub.cfg
This should regenerate grub.cfg and add the other kernels to Grub boot menu.
Command output:
/usr/bin/grub-mkconfig: line 262: /grub/boot/grub.cfg.new: No such file or directory
dalto
6
There is typo in the command. It should be:
It’s fine
Thanks @dalto ! This worked.
system
Closed
9
