How do I disable my keyboard and mouse from waking my PC either from sleep or hibernate?
:point_up:
I thought sudo meant using root? I guess you mean sudo su?
Edit: Anyways done it it works.
sudo
https://wiki.archlinux.org/index.php/Sudo
root
https://wiki.archlinux.org/index.php/Users_and_groups#Overview
Just in case you are seeking clarity. Using root can be dangerous so be careful!
P.s. That’s not what I meant and am pretty sure neither did @ricklinux :grinning:
I see now, thanks :slight_smile:
I did write to the file, but it still has the same issue :confused:
This was temporary to see if either one was the issue. Not permanent if restarted.
I didn’t even restart it and it still failed.
Obviously then it’s something else causing it.
Yes I know, do you know how do I find out what my mouse and keyboard use (like for exmaple is it EHCI etc)?
