How do i change my monitor layout? [SOLVED]
Using 3 monitors, and they are messed up, anyway to change the layout?
Yes but it is DE WM dependent.
not sure if this helps but im using bspwm
Sorry been a million years since I used it. If arandr is installed you could try that.
I’m not familiar with bspwm, but there’s something about it in the wiki, hope it’s helpful.
https://wiki.archlinux.org/title/bspwm#Note_for_multi-monitor_setups
https://wiki.archlinux.org/title/multihead
arandr worked, thank you
also thank you for wanting to help me pycrk
have a nice day
