How do I center my dock?
Hey everyone,
I was reading the Share your desktop and I found this cool dock configuration for KDE
Since nobody explained what it is and how I can configure mine like that I decided to open a Topic to ask how
I also want a blurry-transparent effect on the dock background too if its possible
If you right-click on the panel and select “Show panel configuration” you will get this window:
Screenshot_20240822_141826
Change width to “Fit content”
If it doesn’t collapse to a dock, remove your spacers.
Maybe this topic can help you for KDE: https://forum.endeavouros.com/t/kde-6-widget-that-will-give-you-latte-dock-features-for-your-panel-bars/59389
With a lot of suffer I’ve figured it out that how it works, but it doesn’t display correctly
Normal Mode:
Edit Mode:
Also the more icons I pin icons get smaller
It looks you did something strange. Did you set something to a fixed length?
I removed the dock and added it again, now its fine :+1:
