Hi, Im trying to find out how can I undervolt my cpu, My mother is an Asrock A520M HDV so I cant do it from there (or at least I cant find how to do it from there) So the other option is to do it from the system. I found both Amdctl and Ryzenadj but dont really understand how to do it form there so if anyone is willing to help me with that it’d be amazing.
And btw, does auto-cpufreq really make a diference? should I install it? what about ananicy? if noth one or both of those, what would you recommend? Thanks to yall
Before you dive into undervolting, have you tried to enable cTDP down in the BIOS ?
I’m using an Ryzen 5 5600 and have enabled it. Other than that I’m relying on the AMD-pstate-epp CPU governor which is set to active. Turbo frequencies are disabled in power safe and can be activated manually via the power profile set to performance.
There is lots of information in the EOS wiki on amd-pstates. You should peruse the topics and check if amd-pstates is working using the proper commands such as
Not sure which one would be best for your system. I think you also need cpupower installed and configured. I would just read up on all of it in the wiki and you should be able to try it and verify if it’s working. Then you can determine which parameter better suits your hardware.
