I just downloaded the appimage for Freetube and have tried to run it within firejail using --appimage flag but the application fails to start up:
$ firejail --appimage ./freetube_0.11.2_amd64.AppImage
Mounting appimage type 2
Reading profile /etc/firejail/default.profile
Reading profile /etc/firejail/disable-common.inc
Reading profile /etc/firejail/disable-passwdmgr.inc
Reading profile /etc/firejail/disable-programs.inc
** Note: you can use --noprofile to disable default.profile **
Parent pid 3671, child pid 3674
** Warning: dropping all Linux capabilities **
Warning: /sbin directory link was not blacklisted
Warning: /usr/sbin directory link was not blacklisted
Child process initialized in 80.97 ms
Parent is shutting down, bye...
AppImage unmounted
However using --noprofile will launch the app and it seems to run as expected but I am not sure if it is properly sandboxed or not.
$ firejail --appimage --noprofile ./freetube_0.11.2_amd64.AppImage --noprofile
Parent pid 3794, child pid 3797
Child process initialized in 28.44 ms
(node:2) electron: The default of contextIsolation is deprecated and will be changing from false to true in a future release of Electron. See https://github.com/electron/electron/issues/23506 for more information
I would really appreciate if anyone could shed some light on this.
