My laptop’s microphone has a terrible static noise, no matter what I record. I know I fixed this issues a few months ago by using someone’s daemon.conf, but I can’t for the life of me find it again. Anyone know how to fix it? I’ve tried the method from arch wiki.
some hardware info would be great
inxi -Fxxc0z --no-host | eos-sendlog
https://clbin.com/ZmUyh
Thank you. I never know which commands to share in these situations
arecord -l
will list the input devices and info.
As everyone is switching to pipewire I can recommend to try that, it solves a lot of this little nasty issue with pulseaudio…
**** List of CAPTURE Hardware Devices ****
card 0: PCH [HDA Intel PCH], device 0: ALC3202 Analog [ALC3202 Analog]
Subdevices: 1/1
Subdevice #0: subdevice #0
Make sure you have alsa-utils installed, launch
alsamixer
, then select your audio device (pressingF6
), navigate all the way left using theleft arrow
, and stop on Loopback, if Enabled disable it using thedown arrow
. This should not impact audio playback or microphone recording negatively, unless you require loopback mixing.
Is this what you try already?
I haven’t. But I just installed pipewire, which mostly solved the problem, even though some static noise still persists. Is pulseaudio now uninstalled?
pipewire-pulse replacing it… to be able to use stuff build for pulse what I mean is stuff like audiomixer from pulseaudio are still in use.
but alsamixer is a good start to check for these loopback settings… in some cases alsamixer has also switches for stuff like microphone amplification e.t.c that can help
Btw, after checking pipewire wiki page, I don’t seem to have a pipewire directory in my /etc. Is that normal?
Worked like a charm. Thank you.
/usr/share/pipewire/
holds configs/examples
as it is running on userlevel
