High CPU temps - caused by plasmashell?
After a recent update I’ve started to get really high temps (over 70 C) when I log in. Plasmashell user CPU usage is high, over 70 %, general CPU usage is less than 6 %. I’ve tried eliminating background apps but they don’t seem to affect the situation.
I tested on a test profile and the temps were completely fine, under 40 C.
How do I trace what is causing this spike in CPU temps? Is something in my plasmashell buggin’ out?
Linking all the logs and stuff below:
hardware log
  Kernel: 6.6.40-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.1.1
  Desktop: KDE Plasma v: 6.1.3 tk: Qt v: N/A wm: kwin_x11 dm: SDDM
  Type: Desktop Mobo: ASRock model: B550M-ITX/ac serial: <superuser required>
    UEFI: American Megatrends LLC. v: L2.62 date: 01/31/2023
Battery:
  Device-1: hidpp_battery_0 model: Logitech MX Keys Wireless Keyboard
    serial: <filter> charge: 55% (should be ignored) status: discharging
  Info: 8-core model: AMD Ryzen 7 5700G with Radeon Graphics bits: 64
    type: MT MCP arch: Zen 3 rev: 0 cache: L1: 512 KiB L2: 4 MiB L3: 16 MiB
  Speed (MHz): avg: 3611 high: 4491 min/max: 400/4673 cores: 1: 3592 2: 3583
    3: 3585 4: 3587 5: 4487 6: 4482 7: 3586 8: 3583 9: 3587 10: 3588 11: 3586
    12: 3579 13: 4480 14: 4491 15: 400 16: 3584 bogomips: 121417
  Device-1: AMD Navi 21 [Radeon RX 6800/6800 XT / 6900 XT] vendor: Sapphire
    driver: vfio-pci v: N/A arch: RDNA-2 pcie: speed: 16 GT/s lanes: 16
    bus-ID: 03:00.0 chip-ID: 1002:73bf
  Device-2: AMD Cezanne [Radeon Vega Series / Radeon Mobile Series]
    driver: amdgpu v: kernel arch: GCN-5 pcie: speed: 8 GT/s lanes: 16 ports:
    active: DP-1 empty: DP-2,HDMI-A-1 bus-ID: 09:00.0 chip-ID: 1002:1638
    temp: 49.0 C
  Display: x11 server: X.Org v: 21.1.13 with: Xwayland v: 24.1.1
    compositor: kwin_x11 driver: X: loaded: amdgpu dri: radeonsi gpu: amdgpu
    display-ID: :0 screens: 1
  Screen-1: 0 s-res: 3440x1440 s-dpi: 96
  Monitor-1: DP-1 mapped: DisplayPort-0 model: BenQ EX3501R res: 3440x1440
    dpi: 107 diag: 889mm (35")
  API: EGL v: 1.5 platforms: device: 0 drv: radeonsi device: 1 drv: swrast
    gbm: drv: kms_swrast surfaceless: drv: radeonsi x11: drv: radeonsi
    inactive: wayland
  API: OpenGL v: 4.6 compat-v: 4.5 vendor: amd mesa v: 24.1.4-arch1.2
    glx-v: 1.4 direct-render: yes renderer: AMD Radeon Graphics (radeonsi
    renoir LLVM 18.1.8 DRM 3.54 6.6.40-1-lts) device-ID: 1002:1638
  API: Vulkan v: 1.3.279 surfaces: xcb,xlib device: 0 type: integrated-gpu
    driver: mesa radv device-ID: 1002:1638
  Device-1: AMD Navi 21/23 HDMI/DP Audio driver: snd_hda_intel v: kernel pcie:
    speed: 16 GT/s lanes: 16 bus-ID: 03:00.1 chip-ID: 1002:ab28
  Device-2: AMD Renoir Radeon High Definition Audio driver: snd_hda_intel
    v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 09:00.1 chip-ID: 1002:1637
  Device-3: AMD Family 17h/19h HD Audio vendor: ASRock driver: snd_hda_intel
    v: kernel pcie: speed: 8 GT/s lanes: 16 bus-ID: 09:00.6 chip-ID: 1022:15e3
  Device-4: SteelSeries ApS Arctis Pro Wireless
    driver: hid-generic,snd-usb-audio,usbhid type: USB rev: 1.1 speed: 12 Mb/s
    lanes: 1 bus-ID: 3-2.3:4 chip-ID: 1038:1294
  API: ALSA v: k6.6.40-1-lts status: kernel-api
  Server-1: PipeWire v: 1.2.1 status: active with: 1: pipewire-pulse
    4: pw-jack type: plugin
  Device-1: Realtek RTL8111/8168/8211/8411 PCI Express Gigabit Ethernet
    vendor: ASRock driver: r8169 v: kernel pcie: speed: 2.5 GT/s lanes: 1
    port: e000 bus-ID: 06:00.0 chip-ID: 10ec:8168
  IF: enp6s0 state: up speed: 1000 Mbps duplex: full mac: <filter>
  Device-2: Intel Dual Band Wireless-AC 3168NGW [Stone Peak] driver: iwlwifi
    v: kernel pcie: speed: 2.5 GT/s lanes: 1 bus-ID: 07:00.0 chip-ID: 8086:24fb
  IF-ID-1: virbr0 state: down mac: <filter>
Bluetooth:
  Device-1: Intel Wireless-AC 3168 Bluetooth driver: btusb v: 0.8 type: USB
    rev: 2.0 speed: 12 Mb/s lanes: 1 bus-ID: 1-9:8 chip-ID: 8087:0aa7
  Report: btmgmt ID: hci0 rfk-id: 0 state: up address: <filter> bt-v: 4.2
    lmp-v: 8
  Local Storage: total: 2.67 TiB used: 2.4 TiB (89.9%)
  ID-1: /dev/nvme0n1 vendor: A-Data model: SX8200PNP size: 476.94 GiB
    speed: 31.6 Gb/s lanes: 4 serial: <filter> temp: 31.9 C
  ID-2: /dev/sda vendor: Samsung model: SSD 850 EVO 250GB size: 232.89 GiB
    speed: 6.0 Gb/s serial: <filter>
  ID-3: /dev/sdb vendor: Samsung model: SSD 840 PRO Series size: 119.24 GiB
  ID-4: /dev/sdc vendor: A-Data model: SU800 size: 1.86 TiB speed: 6.0 Gb/s
    serial: <filter>
  ID-1: / size: 40.04 GiB used: 32.97 GiB (82.4%) fs: btrfs
    dev: /dev/nvme0n1p2
  ID-2: /home size: 436.4 GiB used: 380.06 GiB (87.1%) fs: btrfs
    dev: /dev/nvme0n1p3
  ID-3: /var/log size: 40.04 GiB used: 32.97 GiB (82.4%) fs: btrfs
    dev: /dev/nvme0n1p2
  System Temperatures: cpu: 48.5 C mobo: N/A gpu: amdgpu temp: 50.0 C
  Fan Speeds (rpm): fan-1: 1106 fan-2: 4218 fan-3: 1728 fan-4: 0 fan-5: 0
  Memory: total: 32 GiB note: est. available: 30.72 GiB used: 7.9 GiB (25.7%)
  Processes: 449 Power: uptime: 56m wakeups: 0 Init: systemd v: 256
    default: graphical
  Packages: 2014 pm: pacman pkgs: 1994 pm: flatpak pkgs: 20 Compilers:
    clang: 18.1.8 gcc: 14.1.1 alt: 13 Shell: Bash v: 5.2.26 running-in: konsole
    inxi: 3.3.35
All help greatly appreciated.
There are some newer UEFI Bios updates for your board. The latest is in Beta but there are two before that and they include a newer AMD AGESA. The beta version also has a newer AMD AGESA again.
Edit: Are you also using amd pstates?
Edit:
cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_driver
According to this I’m using “amd-pstate-epp”.
I’ll see if a BIOS update does anything.
The temps chilled down after a while while I was searching for the correct BIOS version and formatting a USB. Not sure what happened there.
I updated and reconfigured my new BIOS (it got reset to default settings and caused some boot issues :man_facepalming: ). Temps were initially very high when logging in, but soon chilled down. I’m marking this as solved.
Thanks for the help!
I don’t use amd-pstate-epp as i find this better.
[ricklinux@rick-ms7c37 ~]$ cat /sys/devices/system/cpu/cpu0/cpufreq/scaling_driver
amd-pstate
I’m using amd_pstate=passive or you could try active also.
