Help yay has done this when i tried using it to update the system
[nate@nate-ms7d32 ~]$ yay
 -> /var/lib/pacman/db.lck is present.
 -> There may be another Pacman instance running. Waiting...
That usually means exactly what is says. I haven’t had that happen on Arch/EOS. Last time I had that issue on Manjaro, years ago, I simply rebooted and all was fine.
i will try and reboot and see what happens and report back
https://forum.endeavouros.com/t/error-updating-system-unknown-trust/41182/5
Reboot will not help, because the locked pacman-db will not be released.
Just run sudo rm /var/lib/pacman/db.lck and try your update again.
 -> There may be another Pacman instance running. Waiting...^C
[nate@nate-ms7d32 ~]$ sudo rm /var/lib/pacman/db.lck
[sudo] password for nate:
:: Synchronising package databases...
 endeavouros is up to date
 core is up to date
 extra        7.7 MiB  2.19 MiB/s 00:04 [----------------------------------------------------------------------------------------------] 100%
 multilib        134.6 KiB   301 KiB/s 00:00 [----------------------------------------------------------------------------------------------] 100%
:: Searching AUR for updates...
:: Searching databases for updates...
 -> dracut: local (107-1) is newer than endeavouros (106-1)
:: 55 packages to upgrade/install.
55  endeavouros/endeavouros-mirrorlist  25.3.1-1                -> 25.5-1
54  core/fakeroot                       1.37.1.1-1              -> 1.37.1.2-1
53  core/grub                           2:2.12.r283.ga4da71da-1 -> 2:2.12.r292.g73d1c959-1
52  core/libxml2                        2.14.2-2                -> 2.14.3-1
51  core/m4                             1.4.19-3                -> 1.4.20-1
50  core/mpdecimal                      4.0.0-2                 -> 4.0.1-1
49  core/systemd                        257.5-2                 -> 257.5-3
48  core/systemd-libs                   257.5-2                 -> 257.5-3
47  core/systemd-resolvconf             257.5-2                 -> 257.5-3
46  core/systemd-sysvcompat             257.5-2                 -> 257.5-3
45  extra/abseil-cpp                    20250127.1-1            -> 20250127.1-2
44  extra/dkms                          3.1.8-1                 -> 3.2.1-1
43  extra/electron34                    34.5.5-1                -> 34.5.6-1
42  extra/electron36                    36.2.0-1                -> 36.2.1-1
41  extra/exfatprogs                    1.2.8-1                 -> 1.2.9-1
40  extra/firefox                       138.0.1-1               -> 138.0.3-1
39  extra/flatpak                       1:1.16.0-3              -> 1:1.16.1-1
38  extra/freeglut                      3.6.0-1                 -> 3.6.0-2
37  extra/fribidi                       1.0.16-1                -> 1.0.16-2
36  extra/fzf                           0.61.3-1                -> 0.62.0-1
35  extra/ghostscript                   10.05.1-1               -> 10.05.1-2
34  extra/git                           2.49.0-1                -> 2.49.0-2
33  extra/gtest                         1.16.0-2                -> 1.17.0-1
32  extra/gtk-update-icon-cache         1:4.18.5-1              -> 1:4.18.5-2
31  extra/gtk3                          1:3.24.49-1             -> 1:3.24.49-2
30  extra/gtk4                          1:4.18.5-1              -> 1:4.18.5-2
29  extra/gupnp-igd                     1.6.0-1                 -> 1.6.0-2
28  extra/harfbuzz                      11.2.0-1                -> 11.2.1-1
27  extra/harfbuzz-icu                  11.2.0-1                -> 11.2.1-1
26  extra/intel-ucode                   20250211-1              -> 20250512-1
25  extra/libcamera                     0.5.0-1                 -> 0.5.0-2
24  extra/libcamera-ipa                 0.5.0-1                 -> 0.5.0-2
23  extra/libdecor                      0.2.2-1                 -> 0.2.3-1
22  extra/libgudev                      238-1                   -> 238-3
21  extra/libnice                       0.1.22-1                -> 0.1.22-2
20  extra/libportal                     0.9.1-1                 -> 0.9.1-2
19  extra/libportal-gtk3                0.9.1-1                 -> 0.9.1-2
18  extra/libportal-gtk4                0.9.1-1                 -> 0.9.1-2
17  extra/libstemmer                    2.2.0-2                 -> 3.0.1-1
16  extra/lm_sensors                    1:3.6.0.r41.g31d1f125-3 -> 1:3.6.2-1
15  extra/nodejs-lts-jod                22.14.0-2               -> 22.15.1-1
14  extra/ocl-icd                       2.3.2-2                 -> 2.3.3-1
13  extra/python-cryptography           44.0.2-1                -> 44.0.3-1
12  extra/python-more-itertools         10.6.0-1                -> 10.7.0-1
11  extra/sdl3                          3.2.12-1                -> 3.2.14-1
10  extra/webkit2gtk-4.1                2.48.1-2                -> 2.48.2-1
 9  extra/webkitgtk-6.0                 2.48.1-2                -> 2.48.2-1
 8  extra/woff2                         1.0.2-5                 -> 1.0.2-6
 7  extra/yyjson                        0.11.0-1                -> 0.11.1-1
 6  multilib/lib32-harfbuzz             11.2.0-1                -> 11.2.1-1
 5  multilib/lib32-libxml2              2.14.2-2                -> 2.14.3-1
 4  multilib/lib32-lm_sensors           1:3.6.0.r41.g31d1f125-3 -> 1:3.6.2-2
 3  aur/balena-etcher                   2:2.1.1-1               -> 2:2.1.2-2
 2  aur/brave-bin                       1:1.78.97-1             -> 1:1.78.102-1
 1  aur/exodus                          25.13.6-1               -> 25.13.7-1
==> Packages to exclude: (eg: "1 2 3", "1-3", "^4" or repo name)
 -> Excluding packages may cause partial upgrades and break systems
thank you for the help it is fixed
