Help with wifi/bluetooth
Good afternoon all, I am fairly new to Linux, and brand new to EndeavourOS. I have brand new Asus Vivobook model S5406SA-WH79.
wifi works, but i have to manually switch it on every reboot or when awakening the laptop.
Bluetooth does not work at all. Google says correct drivers are included in 6.14 which I am fully updated as of today with 6.14.3-arch1-1
when i attemp to rfkill enable bluetooth it does not unlock:
[havok@laptop ~]$ rfkill
ID TYPE DEVICE SOFT HARD
0 bluetooth hci0 unblocked unblocked
1 wlan asus-wlan blocked unblocked
2 bluetooth asus-bluetooth unblocked unblocked
3 wlan phy0 unblocked unblocked
[havok@laptop ~]$ rfkill unblock 1
here is dmesg:
[havok@laptop ~]$ sudo dmesg
[sudo] password for havok:
[ 0.000000] Linux version 6.14.3-arch1-1 (linux@archlinux) (gcc (GCC) 14.2.1 20250207, GNU ld (GNU Binutils) 2.44) #1 SMP PREEMPT_DYNAMIC Sun, 20 Apr 2025 12:38:52 +0000
[ 0.000000] Command line: initrd=\12d5c8ffbaf048b4a12c161a2e7786c5\6.14.3-arch1-1\initrd nvme_load=YES nowatchdog rw root=UUID=44d60f4b-8750-466e-81b4-7374617c0042 systemd.machine_id=12d5c8ffbaf048b4a12c161a2e7786c5
[ 0.000000] x86/split lock detection: #AC: crashing the kernel on kernel split_locks and warning on user-space split_locks
[ 0.000000] BIOS-provided physical RAM map:
[ 0.000000] BIOS-e820: [mem 0x0000000000000000-0x000000000009efff] usable
[ 0.000000] BIOS-e820: [mem 0x000000000009f000-0x00000000000fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000000100000-0x00000000634a3fff] usable
[ 0.000000] BIOS-e820: [mem 0x00000000634a4000-0x000000006d490fff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000006d491000-0x000000006d549fff] ACPI data
[ 0.000000] BIOS-e820: [mem 0x000000006d54a000-0x000000006d609fff] ACPI NVS
[ 0.000000] BIOS-e820: [mem 0x000000006d60a000-0x000000006fffefff] reserved
[ 0.000000] BIOS-e820: [mem 0x000000006ffff000-0x000000006fffffff] usable
[ 0.000000] BIOS-e820: [mem 0x0000000070000000-0x00000000807fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000c0000000-0x00000000cfffffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fe000000-0x00000000fe010fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fec00000-0x00000000fec00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed00000-0x00000000fed00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fed20000-0x00000000fed7ffff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000fee00000-0x00000000fee00fff] reserved
[ 0.000000] BIOS-e820: [mem 0x00000000ff000000-0x00000001043fffff] reserved
[ 0.000000] BIOS-e820: [mem 0x0000000104400000-0x000000087f7fffff] usable
[ 0.000000] NX (Execute Disable) protection: active
[ 0.000000] APIC: Static calls initialized
[ 0.000000] efi: EFI v2.9 by American Megatrends
[ 0.000000] efi: ACPI=0x6d549000 ACPI 2.0=0x6d549014 TPMFinalLog=0x6d592000 SMBIOS=0x6eaef000 SMBIOS 3.0=0x6eaee000 MEMATTR=0x5f82a698 ESRT=0x5f82c418 RNG=0x6d4b5f18 INITRD=0x59e00c98 TPMEventLog=0x6d4ac018
[ 0.000000] random: crng init done
[ 0.000000] efi: Remove mem63: MMIO range=[0xc0000000-0xcfffffff] (256MB) from e820 map
[ 0.000000] e820: remove [mem 0xc0000000-0xcfffffff] reserved
[ 0.000000] efi: Not removing mem64: MMIO range=[0xfe000000-0xfe010fff] (68KB) from e820 map
[ 0.000000] efi: Not removing mem65: MMIO range=[0xfec00000-0xfec00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem66: MMIO range=[0xfed00000-0xfed00fff] (4KB) from e820 map
[ 0.000000] efi: Not removing mem68: MMIO range=[0xfee00000-0xfee00fff] (4KB) from e820 map
[ 0.000000] efi: Remove mem69: MMIO range=[0xff000000-0xffffffff] (16MB) from e820 map
[ 0.000000] e820: remove [mem 0xff000000-0xffffffff] reserved
[ 0.000000] SMBIOS 3.7.0 present.
[ 0.000000] DMI: ASUSTeK COMPUTER INC. ASUS Vivobook S 14 S5406SA_S5406SA/S5406SA, BIOS S5406SA.307 10/15/2024
[ 0.000000] DMI: Memory slots populated: 8/8
[ 0.000000] tsc: Detected 3300.000 MHz processor
[ 0.000000] tsc: Detected 3302.400 MHz TSC
[ 0.000006] e820: update [mem 0x00000000-0x00000fff] usable ==> reserved
[ 0.000007] e820: remove [mem 0x000a0000-0x000fffff] usable
[ 0.000012] last_pfn = 0x87f800 max_arch_pfn = 0x400000000
[ 0.000015] MTRR map: 6 entries (3 fixed + 3 variable; max 23), built from 10 variable MTRRs
[ 0.000016] x86/PAT: Configuration [0-7]: WB WC UC- UC WB WP UC- WT
[ 0.000297] x2apic: enabled by BIOS, switching to x2apic ops
[ 0.000298] last_pfn = 0x70000 max_arch_pfn = 0x400000000
[ 0.004575] esrt: Reserving ESRT space from 0x000000005f82c418 to 0x000000005f82c590.
[ 0.004578] e820: update [mem 0x5f82c000-0x5f82cfff] usable ==> reserved
[ 0.004587] Using GB pages for direct mapping
[ 0.004799] Secure boot disabled
[ 0.004799] RAMDISK: [mem 0x52436000-0x541f6fff]
[ 0.004802] ACPI: Early table checksum verification disabled
[ 0.004804] ACPI: RSDP 0x000000006D549014 000024 (v02 ASUS)
[ 0.004807] ACPI: XSDT 0x000000006D548728 0001A4 (v01 ASUS Notebook 01072009 AMI 01000013)
[ 0.004810] ACPI: FACP 0x000000006D53C000 000114 (v06 ASUS Notebook 01072009 AMI 01000013)
[ 0.004813] ACPI: DSDT 0x000000006D514000 027F80 (v02 ASUS Notebook 01072009 INTL 20210930)
[ 0.004815] ACPI: FACS 0x000000006D605000 000040
[ 0.004816] ACPI: SSDT 0x000000006D547000 0006E3 (v02 INTEL PepoSsdt 00001000 INTL 20210930)
[ 0.004817] ACPI: SSDT 0x000000006D546000 00011E (v02 INTEL TxtSsdt 00001000 INTL 20210930)
[ 0.004818] ACPI: SSDT 0x000000006D545000 000388 (v02 PmaxDv Pmax_Dev 00000001 INTL 20210930)
[ 0.004820] ACPI: DTPR 0x000000006D544000 000088 (v01 00000000 00000000)
[ 0.004821] ACPI: SSDT 0x000000006D53E000 0052A0 (v02 DptfTb DptfTabl 00001000 INTL 20210930)
[ 0.004822] ACPI: SSDT 0x000000006D53D000 000C59 (v02 INTEL PDatTabl 00001000 INTL 20210930)
[ 0.004824] ACPI: FIDT 0x000000006D513000 00009C (v01 ASUS Notebook 01072009 AMI 00010013)
[ 0.004825] ACPI: MSDM 0x000000006D512000 000055 (v03 ASUS Notebook 01072009 ASUS 00000001)
[ 0.004826] ACPI: SSDT 0x000000006D511000 0006EC (v02 PmRef Cpu0Ist 00003000 INTL 20210930)
[ 0.004828] ACPI: SSDT 0x000000006D510000 0005FB (v02 PmRef Cpu0Hwp 00003000 INTL 20210930)
[ 0.004829] ACPI: SSDT 0x000000006D50F000 0001AB (v02 PmRef Cpu0Psd 00003000 INTL 20210930)
[ 0.004830] ACPI: SSDT 0x000000006D50E000 000394 (v02 PmRef Cpu0Cst 00003001 INTL 20210930)
[ 0.004831] ACPI: SSDT 0x000000006D50C000 001BAF (v02 PmRef ApIst 00003000 INTL 20210930)
[ 0.004833] ACPI: SSDT 0x000000006D50A000 001620 (v02 PmRef ApHwp 00003000 INTL 20210930)
[ 0.004834] ACPI: SSDT 0x000000006D508000 001349 (v02 PmRef ApPsd 00003000 INTL 20210930)
[ 0.004835] ACPI: SSDT 0x000000006D507000 000FBB (v02 PmRef ApCst 00003000 INTL 20210930)
[ 0.004836] ACPI: SSDT 0x000000006D503000 003BD7 (v02 CpuRef CpuSsdt 00003000 INTL 20210930)
[ 0.004837] ACPI: SSDT 0x000000006D500000 0024A2 (v02 INTEL IgfxSsdt 00003000 INTL 20210930)
[ 0.004839] ACPI: SSDT 0x000000006D4FF000 0000A5 (v02 INTEL TseSsdt 00001000 INTL 20210930)
[ 0.004840] ACPI: SSDT 0x000000006D4F6000 008E92 (v02 INTEL TcssSsdt 00001000 INTL 20210930)
[ 0.004841] ACPI: SSDT 0x000000006D4F1000 00450B (v02 ASUS LnlMRvp1 00001000 INTL 20210930)
[ 0.004842] ACPI: SSDT 0x000000006D4EF000 00140F (v02 ASUS I2Pm_Rvp 00001000 INTL 20210930)
[ 0.004843] ACPI: SSDT 0x000000006D4EB000 003962 (v02 ASUS Ther_Rvp 00001000 INTL 20210930)
[ 0.004845] ACPI: HPET 0x000000006D4EA000 000038 (v01 ASUS Notebook 01072009 AMI 01000013)
[ 0.004846] ACPI: APIC 0x000000006D4E8000 0000D8 (v05 ASUS Notebook 00000000 AMI 01000013)
[ 0.004847] ACPI: MCFG 0x000000006D4E7000 00003C (v01 ASUS Notebook 01072009 AMI 01000013)
[ 0.004848] ACPI: UEFI 0x000000006D579000 000048 (v01 ASUS Notebook 01072009 AMI 01000013)
[ 0.004850] ACPI: NHLT 0x000000006D4E6000 000960 (v00 ASUS Notebook 01072009 AMI 01000013)
[ 0.004851] ACPI: LPIT 0x000000006D4E5000 0000CC (v01 ASUS Notebook 01072009 AMI 01000013)
[ 0.004852] ACPI: SSDT 0x000000006D4E4000 000D5C (v02 ASUS PtidDevc 00001000 INTL 20210930)
[ 0.004853] ACPI: SSDT 0x000000006D4E3000 0001F0 (v02 ASUS TbtTypeC 00000000 INTL 20210930)
[ 0.004854] ACPI: DBGP 0x000000006D4E2000 000034 (v01 ASUS Notebook 01072009 AMI 01000013)
[ 0.004856] ACPI: DBG2 0x000000006D4E1000 000054 (v00 ASUS Notebook 01072009 AMI 01000013)
[ 0.004857] ACPI: SSDT 0x000000006D4DF000 00155E (v02 ASUS UsbCTabl 00001000 INTL 20210930)
[ 0.004858] ACPI: DMAR 0x000000006D4DE000 0000C0 (v01 ASUS Notebook 01072009 AMI 01000013)
[ 0.004859] ACPI: FPDT 0x000000006D4DD000 000044 (v01 ASUS A M I 01072009 AMI 01000013)
[ 0.004861] ACPI: SSDT 0x000000006D4DC000 00011E (v02 INTEL TxtSsdt 00001000 INTL 20210930)
[ 0.004862] ACPI: SSDT 0x000000006D4DB000 0006BB (v02 INTEL xh_lnl_m 00000000 INTL 20210930)
[ 0.004863] ACPI: SSDT 0x000000006D4D9000 001122 (v02 SocGpe SocGpe 00003000 INTL 20210930)
[ 0.004864] ACPI: SSDT 0x000000006D4D6000 002463 (v02 SocCmn SocCmn 00003000 INTL 20210930)
[ 0.004866] ACPI: BGRT 0x000000006D4D5000 000038 (v01 ASUS Notebook 01072009 AMI 00010013)
[ 0.004867] ACPI: SSDT 0x000000006D4BB000 0195A4 (v02 INTEL Cnv_Ssdt 00001000 INTL 20210930)
[ 0.004868] ACPI: SSDT 0x000000006D4B9000 0011A0 (v02 INTEL St00Ssdt 00001000 INTL 20210930)
[ 0.004869] ACPI: TPM2 0x000000006D4B8000 00004C (v04 ASUS Notebook 00000001 AMI 00000000)
[ 0.004871] ACPI: PHAT 0x000000006D4B7000 000700 (v01 ASUS Notebook 00000005 MSFT 0100000D)
[ 0.004872] ACPI: WSMT 0x000000006D4E9000 000028 (v01 ASUS Notebook 01072009 AMI 00010013)
[ 0.004873] ACPI: SDEV 0x000000006D4B6000 000138 (v01 00000000 00000000)
[ 0.004874] ACPI: Reserving FACP table memory at [mem 0x6d53c000-0x6d53c113]
[ 0.004875] ACPI: Reserving DSDT table memory at [mem 0x6d514000-0x6d53bf7f]
[ 0.004875] ACPI: Reserving FACS table memory at [mem 0x6d605000-0x6d60503f]
[ 0.004875] ACPI: Reserving SSDT table memory at [mem 0x6d547000-0x6d5476e2]
[ 0.004876] ACPI: Reserving SSDT table memory at [mem 0x6d546000-0x6d54611d]
[ 0.004876] ACPI: Reserving SSDT table memory at [mem 0x6d545000-0x6d545387]
[ 0.004876] ACPI: Reserving DTPR table memory at [mem 0x6d544000-0x6d544087]
[ 0.004876] ACPI: Reserving SSDT table memory at [mem 0x6d53e000-0x6d54329f]
[ 0.004877] ACPI: Reserving SSDT table memory at [mem 0x6d53d000-0x6d53dc58]
[ 0.004877] ACPI: Reserving FIDT table memory at [mem 0x6d513000-0x6d51309b]
[ 0.004877] ACPI: Reserving MSDM table memory at [mem 0x6d512000-0x6d512054]
[ 0.004878] ACPI: Reserving SSDT table memory at [mem 0x6d511000-0x6d5116eb]
[ 0.004878] ACPI: Reserving SSDT table memory at [mem 0x6d510000-0x6d5105fa]
[ 0.004878] ACPI: Reserving SSDT table memory at [mem 0x6d50f000-0x6d50f1aa]
[ 0.004878] ACPI: Reserving SSDT table memory at [mem 0x6d50e000-0x6d50e393]
[ 0.004879] ACPI: Reserving SSDT table memory at [mem 0x6d50c000-0x6d50dbae]
[ 0.004879] ACPI: Reserving SSDT table memory at [mem 0x6d50a000-0x6d50b61f]
[ 0.004879] ACPI: Reserving SSDT table memory at [mem 0x6d508000-0x6d509348]
[ 0.004879] ACPI: Reserving SSDT table memory at [mem 0x6d507000-0x6d507fba]
[ 0.004880] ACPI: Reserving SSDT table memory at [mem 0x6d503000-0x6d506bd6]
[ 0.004880] ACPI: Reserving SSDT table memory at [mem 0x6d500000-0x6d5024a1]
[ 0.004880] ACPI: Reserving SSDT table memory at [mem 0x6d4ff000-0x6d4ff0a4]
[ 0.004880] ACPI: Reserving SSDT table memory at [mem 0x6d4f6000-0x6d4fee91]
[ 0.004881] ACPI: Reserving SSDT table memory at [mem 0x6d4f1000-0x6d4f550a]
[ 0.004881] ACPI: Reserving SSDT table memory at [mem 0x6d4ef000-0x6d4f040e]
[ 0.004881] ACPI: Reserving SSDT table memory at [mem 0x6d4eb000-0x6d4ee961]
[ 0.004881] ACPI: Reserving HPET table memory at [mem 0x6d4ea000-0x6d4ea037]
[ 0.004882] ACPI: Reserving APIC table memory at [mem 0x6d4e8000-0x6d4e80d7]
[ 0.004882] ACPI: Reserving MCFG table memory at [mem 0x6d4e7000-0x6d4e703b]
[ 0.004882] ACPI: Reserving UEFI table memory at [mem 0x6d579000-0x6d579047]
[ 0.004883] ACPI: Reserving NHLT table memory at [mem 0x6d4e6000-0x6d4e695f]
[ 0.004883] ACPI: Reserving LPIT table memory at [mem 0x6d4e5000-0x6d4e50cb]
[ 0.004883] ACPI: Reserving SSDT table memory at [mem 0x6d4e4000-0x6d4e4d5b]
[ 0.004883] ACPI: Reserving SSDT table memory at [mem 0x6d4e3000-0x6d4e31ef]
[ 0.004884] ACPI: Reserving DBGP table memory at [mem 0x6d4e2000-0x6d4e2033]
[ 0.004884] ACPI: Reserving DBG2 table memory at [mem 0x6d4e1000-0x6d4e1053]
[ 0.004884] ACPI: Reserving SSDT table memory at [mem 0x6d4df000-0x6d4e055d]
[ 0.004884] ACPI: Reserving DMAR table memory at [mem 0x6d4de000-0x6d4de0bf]
[ 0.004885] ACPI: Reserving FPDT table memory at [mem 0x6d4dd000-0x6d4dd043]
[ 0.004885] ACPI: Reserving SSDT table memory at [mem 0x6d4dc000-0x6d4dc11d]
[ 0.004885] ACPI: Reserving SSDT table memory at [mem 0x6d4db000-0x6d4db6ba]
[ 0.004885] ACPI: Reserving SSDT table memory at [mem 0x6d4d9000-0x6d4da121]
[ 0.004886] ACPI: Reserving SSDT table memory at [mem 0x6d4d6000-0x6d4d8462]
[ 0.004886] ACPI: Reserving BGRT table memory at [mem 0x6d4d5000-0x6d4d5037]
[ 0.004886] ACPI: Reserving SSDT table memory at [mem 0x6d4bb000-0x6d4d45a3]
[ 0.004887] ACPI: Reserving SSDT table memory at [mem 0x6d4b9000-0x6d4ba19f]
[ 0.004887] ACPI: Reserving TPM2 table memory at [mem 0x6d4b8000-0x6d4b804b]
[ 0.004887] ACPI: Reserving PHAT table memory at [mem 0x6d4b7000-0x6d4b76ff]
[ 0.004887] ACPI: Reserving WSMT table memory at [mem 0x6d4e9000-0x6d4e9027]
[ 0.004888] ACPI: Reserving SDEV table memory at [mem 0x6d4b6000-0x6d4b6137]
[ 0.004942] APIC: Switched APIC routing to: cluster x2apic
[ 0.005237] No NUMA configuration found
[ 0.005238] Faking a node at [mem 0x0000000000000000-0x000000087f7fffff]
[ 0.005241] NODE_DATA(0) allocated [mem 0x87f7d42c0-0x87f7fefff]
[ 0.005359] Zone ranges:
[ 0.005359] DMA [mem 0x0000000000001000-0x0000000000ffffff]
[ 0.005360] DMA32 [mem 0x0000000001000000-0x00000000ffffffff]
[ 0.005361] Normal [mem 0x0000000100000000-0x000000087f7fffff]
[ 0.005361] Device empty
[ 0.005362] Movable zone start for each node
[ 0.005362] Early memory node ranges
[ 0.005363] node 0: [mem 0x0000000000001000-0x000000000009efff]
[ 0.005363] node 0: [mem 0x0000000000100000-0x00000000634a3fff]
[ 0.005364] node 0: [mem 0x000000006ffff000-0x000000006fffffff]
[ 0.005364] node 0: [mem 0x0000000104400000-0x000000087f7fffff]
[ 0.005365] Initmem setup node 0 [mem 0x0000000000001000-0x000000087f7fffff]
[ 0.005369] On node 0, zone DMA: 1 pages in unavailable ranges
[ 0.005383] On node 0, zone DMA: 97 pages in unavailable ranges
[ 0.006967] On node 0, zone DMA32: 52059 pages in unavailable ranges
[ 0.035062] On node 0, zone Normal: 17408 pages in unavailable ranges
[ 0.035072] On node 0, zone Normal: 2048 pages in unavailable ranges
[ 0.035827] ACPI: PM-Timer IO Port: 0x1808
[ 0.035833] ACPI: X2APIC_NMI (uid[0xffffffff] high level lint[0x1])
[ 0.035873] IOAPIC[0]: apic_id 2, version 32, address 0xfec00000, GSI 0-119
[ 0.035875] ACPI: INT_SRC_OVR (bus 0 bus_irq 0 global_irq 2 dfl dfl)
[ 0.035876] ACPI: INT_SRC_OVR (bus 0 bus_irq 9 global_irq 9 high level)
[ 0.035878] ACPI: Using ACPI (MADT) for SMP configuration information
[ 0.035878] ACPI: HPET id: 0x8086a701 base: 0xfed00000
[ 0.035885] e820: update [mem 0x59e3f000-0x59e6dfff] usable ==> reserved
[ 0.035892] TSC deadline timer available
[ 0.035894] CPU topo: Max. logical packages: 1
[ 0.035894] CPU topo: Max. logical dies: 1
[ 0.035894] CPU topo: Max. dies per package: 1
[ 0.035895] CPU topo: Max. threads per core: 1
[ 0.035896] CPU topo: Num. cores per package: 8
[ 0.035897] CPU topo: Num. threads per package: 8
[ 0.035897] CPU topo: Allowing 8 present CPUs plus 0 hotplug CPUs
[ 0.035906] PM: hibernation: Registered nosave memory: [mem 0x00000000-0x00000fff]
[ 0.035907] PM: hibernation: Registered nosave memory: [mem 0x0009f000-0x000fffff]
[ 0.035907] PM: hibernation: Registered nosave memory: [mem 0x59e3f000-0x59e6dfff]
[ 0.035908] PM: hibernation: Registered nosave memory: [mem 0x5f82c000-0x5f82cfff]
[ 0.035909] PM: hibernation: Registered nosave memory: [mem 0x634a4000-0x6fffefff]
[ 0.035909] PM: hibernation: Registered nosave memory: [mem 0x70000000-0x1043fffff]
[ 0.035910] [mem 0x80800000-0xfdffffff] available for PCI devices
[ 0.035911] Booting paravirtualized kernel on bare hardware
[ 0.035913] clocksource: refined-jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1910969940391419 ns
[ 0.039704] setup_percpu: NR_CPUS:8192 nr_cpumask_bits:8 nr_cpu_ids:8 nr_node_ids:1
[ 0.039993] percpu: Embedded 67 pages/cpu s237568 r8192 d28672 u524288
[ 0.039996] pcpu-alloc: s237568 r8192 d28672 u524288 alloc=12097152
[ 0.039997] pcpu-alloc: [0] 0 1 2 3 [0] 4 5 6 7
[ 0.040006] Kernel command line: initrd=\12d5c8ffbaf048b4a12c161a2e7786c5\6.14.3-arch1-1\initrd nvme_load=YES nowatchdog rw root=UUID=44d60f4b-8750-466e-81b4-7374617c0042 systemd.machine_id=12d5c8ffbaf048b4a12c161a2e7786c5
[ 0.040046] Unknown kernel command line parameters “nvme_load=YES”, will be passed to user space.
[ 0.040056] printk: log buffer data + meta data: 131072 + 458752 = 589824 bytes
[ 0.041899] Dentry cache hash table entries: 4194304 (order: 13, 33554432 bytes, linear)
[ 0.042800] Inode-cache hash table entries: 2097152 (order: 12, 16777216 bytes, linear)
[ 0.042857] Fallback order for Node 0: 0
[ 0.042859] Built 1 zonelists, mobility grouping on. Total pages: 8251459
[ 0.042859] Policy zone: Normal
[ 0.042999] mem auto-init: stack:all(zero), heap alloc:on, heap free:off
[ 0.043036] software IO TLB: area num 8.
[ 0.081835] SLUB: HWalign=64, Order=0-3, MinObjects=0, CPUs=8, Nodes=1
[ 0.081858] ftrace: allocating 55513 entries in 217 pages
[ 0.094533] ftrace: allocated 217 pages with 5 groups
[ 0.094590] Dynamic Preempt: full
[ 0.094621] rcu: Preemptible hierarchical RCU implementation.
[ 0.094622] rcu: RCU restricting CPUs from NR_CPUS=8192 to nr_cpu_ids=8.
[ 0.094623] rcu: RCU priority boosting: priority 1 delay 500 ms.
[ 0.094623] Trampoline variant of Tasks RCU enabled.
[ 0.094623] Rude variant of Tasks RCU enabled.
[ 0.094624] Tracing variant of Tasks RCU enabled.
[ 0.094624] rcu: RCU calculated value of scheduler-enlistment delay is 100 jiffies.
[ 0.094624] rcu: Adjusting geometry for rcu_fanout_leaf=16, nr_cpu_ids=8
[ 0.094629] RCU Tasks: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[ 0.094630] RCU Tasks Rude: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[ 0.094631] RCU Tasks Trace: Setting shift to 3 and lim to 1 rcu_task_cb_adjust=1 rcu_task_cpu_ids=8.
[ 0.097129] NR_IRQS: 524544, nr_irqs: 2048, preallocated irqs: 16
[ 0.097442] rcu: srcu_init: Setting srcu_struct sizes based on contention.
[ 0.097696] kfence: initialized - using 2097152 bytes for 255 objects at 0x(ptrval)-0x(ptrval)
[ 0.097718] Console: colour dummy device 80x25
[ 0.097721] printk: legacy console [tty0] enabled
[ 0.097750] ACPI: Core revision 20240827
[ 0.097975] hpet: HPET dysfunctional in PC10. Force disabled.
[ 0.098099] APIC: Switch to symmetric I/O mode setup
[ 0.098101] DMAR: Host address width 38
[ 0.098102] DMAR: DRHD base: 0x000000fc800000 flags: 0x0
[ 0.098105] DMAR: dmar0: reg_base_addr fc800000 ver 7:1 cap e9de008cee690402 ecap 1aca9a00f0ef5e
[ 0.098108] DMAR: DRHD base: 0x000000fc810000 flags: 0x0
[ 0.098110] DMAR: dmar1: reg_base_addr fc810000 ver 7:1 cap e9de008cee690402 ecap 1aca9a00f0ef5e
[ 0.098113] DMAR: DRHD base: 0x000000fc820000 flags: 0x1
[ 0.098120] DMAR: dmar2: reg_base_addr fc820000 ver 7:1 cap e9de008cee690402 ecap 1ac89800f0efda
[ 0.098132] DMAR: SATC flags: 0x1
[ 0.098133] DMAR-IR: IOAPIC id 2 under DRHD base 0xfc820000 IOMMU 2
[ 0.098134] DMAR-IR: HPET id 0 under DRHD base 0xfc820000
[ 0.098134] DMAR-IR: Queued invalidation will be enabled to support x2apic and Intr-remapping.
[ 0.100124] DMAR-IR: Enabled IRQ remapping in x2apic mode
[ 0.105039] clocksource: tsc-early: mask: 0xffffffffffffffff max_cycles: 0x2f9a2767029, max_idle_ns: 440795219692 ns
[ 0.105045] Calibrating delay loop (skipped), value calculated using timer frequency.. 6604.80 BogoMIPS (lpj=3302400)
[ 0.105109] CPU0: Thermal monitoring enabled (TM1)
[ 0.105111] x86/cpu: User Mode Instruction Prevention (UMIP) activated
[ 0.105258] CET detected: Indirect Branch Tracking enabled
[ 0.105259] Last level iTLB entries: 4KB 0, 2MB 0, 4MB 0
[ 0.105260] Last level dTLB entries: 4KB 0, 2MB 0, 4MB 0, 1GB 0
[ 0.105263] Spectre V1 : Mitigation: usercopy/swapgs barriers and user pointer sanitization
[ 0.105264] Spectre V2 : Mitigation: Enhanced / Automatic IBRS
[ 0.105264] Spectre V2 : Spectre v2 / SpectreRSB mitigation: Filling RSB on context switch
[ 0.105266] Spectre V2 : mitigation: Enabling conditional Indirect Branch Prediction Barrier
[ 0.105267] Speculative Store Bypass: Mitigation: Speculative Store Bypass disabled via prctl
[ 0.105274] x86/fpu: Supporting XSAVE feature 0x001: ‘x87 floating point registers’
[ 0.105274] x86/fpu: Supporting XSAVE feature 0x002: ‘SSE registers’
[ 0.105275] x86/fpu: Supporting XSAVE feature 0x004: ‘AVX registers’
[ 0.105275] x86/fpu: Supporting XSAVE feature 0x200: ‘Protection Keys User registers’
[ 0.105276] x86/fpu: Supporting XSAVE feature 0x800: ‘Control-flow User registers’
[ 0.105276] x86/fpu: xstate_offset[2]: 576, xstate_sizes[2]: 256
[ 0.105277] x86/fpu: xstate_offset[9]: 832, xstate_sizes[9]: 8
[ 0.105277] x86/fpu: xstate_offset[11]: 840, xstate_sizes[11]: 16
[ 0.105278] x86/fpu: Enabled xstate features 0xa07, context size is 856 bytes, using ‘compacted’ format.
[ 0.106043] Freeing SMP alternatives memory: 48K
[ 0.106043] pid_max: default: 32768 minimum: 301
[ 0.106043] LSM: initializing lsm=capability,landlock,lockdown,yama,bpf
[ 0.106043] landlock: Up and running.
[ 0.106043] Yama: becoming mindful.
[ 0.106043] LSM support for eBPF active
[ 0.106043] Mount-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.106043] Mountpoint-cache hash table entries: 65536 (order: 7, 524288 bytes, linear)
[ 0.106043] smpboot: CPU0: Intel(R) Core​:trade_mark: Ultra 7 258V (family: 0x6, model: 0xbd, stepping: 0x1)
[ 0.106043] Performance Events: XSAVE Architectural LBR, PEBS fmt4±baseline, AnyThread deprecated, Lunarlake Hybrid events, 32-deep LBR, full-width counters, Intel PMU driver.
[ 0.106043] core: cpu_core PMU driver:
[ 0.106043] … version: 6
[ 0.106043] … bit width: 48
[ 0.106043] … generic registers: 10
[ 0.106043] … value mask: 0000ffffffffffff
[ 0.106043] … max period: 00007fffffffffff
[ 0.106043] … fixed-purpose events: 4
[ 0.106043] … event mask: 0001000f000003ff
[ 0.106043] signal: max sigframe size: 3632
[ 0.106043] Estimated ratio of average max frequency by base frequency (times 1024): 1303
[ 0.106043] rcu: Hierarchical SRCU implementation.
[ 0.106043] rcu: Max phase no-delay instances is 400.
[ 0.106043] Timer migration: 1 hierarchy levels; 8 children per group; 1 crossnode level
[ 0.106043] smp: Bringing up secondary CPUs …
[ 0.106043] smpboot: x86: Booting SMP configuration:
[ 0.106043] … node #0, CPUs: #1 #2 #3 #4 #5 #6 #7
[ 0.008418] core: cpu_atom PMU driver:
[ 0.008418] … version: 6
[ 0.008418] … bit width: 48
[ 0.008418] … generic registers: 8
[ 0.008418] … value mask: 0000ffffffffffff
[ 0.008418] … max period: 00007fffffffffff
[ 0.008418] … fixed-purpose events: 6
[ 0.008418] … event mask: 00000077000000ff
[ 0.112063] smp: Brought up 1 node, 8 CPUs
[ 0.112065] smpboot: Total of 8 processors activated (52838.40 BogoMIPS)
[ 0.113114] Memory: 32261096K/33005836K available (19197K kernel code, 2903K rwdata, 16272K rodata, 4528K init, 4964K bss, 727052K reserved, 0K cma-reserved)
[ 0.113136] devtmpfs: initialized
[ 0.113136] x86/mm: Memory block size: 128MB
[ 0.114415] ACPI: PM: Registering ACPI NVS region [mem 0x6d54a000-0x6d609fff] (786432 bytes)
[ 0.114415] clocksource: jiffies: mask: 0xffffffff max_cycles: 0xffffffff, max_idle_ns: 1911260446275000 ns
[ 0.114415] futex hash table entries: 2048 (order: 5, 131072 bytes, linear)
[ 0.114415] pinctrl core: initialized pinctrl subsystem
[ 0.114415] PM: RTC time: 21:57:42, date: 2025-04-22
[ 0.115094] NET: Registered PF_NETLINK/PF_ROUTE protocol family
[ 0.115413] DMA: preallocated 4096 KiB GFP_KERNEL pool for atomic allocations
[ 0.115661] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA pool for atomic allocations
[ 0.115941] DMA: preallocated 4096 KiB GFP_KERNEL|GFP_DMA32 pool for atomic allocations
[ 0.115945] audit: initializing netlink subsys (disabled)
[ 0.115960] audit: type=2000 audit(1745359062.010:1): state=initialized audit_enabled=0 res=1
[ 0.115960] thermal_sys: Registered thermal governor ‘fair_share’
[ 0.115960] thermal_sys: Registered thermal governor ‘bang_bang’
[ 0.115960] thermal_sys: Registered thermal governor ‘step_wise’
[ 0.115960] thermal_sys: Registered thermal governor ‘user_space’
[ 0.115960] thermal_sys: Registered thermal governor ‘power_allocator’
[ 0.116044] cpuidle: using governor ladder
[ 0.116047] cpuidle: using governor menu
[ 0.116096] acpiphp: ACPI Hot Plug PCI Controller Driver version: 0.5
[ 0.116185] PCI: ECAM [mem 0xc0000000-0xcfffffff] (base 0xc0000000) for domain 0000 [bus 00-ff]
[ 0.116195] PCI: Using configuration type 1 for base access
[ 0.116271] kprobes: kprobe jump-optimization is enabled. All kprobes are optimized if possible.
[ 0.116281] HugeTLB: registered 1.00 GiB page size, pre-allocated 0 pages
[ 0.116281] HugeTLB: 16380 KiB vmemmap can be freed for a 1.00 GiB page
[ 0.116281] HugeTLB: registered 2.00 MiB page size, pre-allocated 0 pages
[ 0.116281] HugeTLB: 28 KiB vmemmap can be freed for a 2.00 MiB page
[ 0.117067] raid6: skipped pq benchmark and selected avx2x4
[ 0.117067] raid6: using avx2x2 recovery algorithm
[ 0.117094] ACPI: Added OSI(Module Device)
[ 0.117094] ACPI: Added OSI(Processor Device)
[ 0.117095] ACPI: Added OSI(3.0 SCP Extensions)
[ 0.117095] ACPI: Added OSI(Processor Aggregator Device)
[ 0.132589] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.I2C3.TPD0], AE_NOT_FOUND (20240827/dswload2-162)
[ 0.132594] fbcon: Taking over console
[ 0.132598] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240827/psobject-220)
[ 0.132600] ACPI: Skipping parse of AML opcode: Scope (0x0010)
[ 0.132657] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.I2C4.TPL1], AE_NOT_FOUND (20240827/dswload2-162)
[ 0.132659] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240827/psobject-220)
[ 0.132660] ACPI: Skipping parse of AML opcode: Scope (0x0010)
[ 0.132715] ACPI BIOS Error (bug): Could not resolve symbol [_SB.PC00.I2C5.TPL1], AE_NOT_FOUND (20240827/dswload2-162)
[ 0.132717] ACPI Error: AE_NOT_FOUND, During name lookup/catalog (20240827/psobject-220)
[ 0.132719] ACPI: Skipping parse of AML opcode: Scope (0x0010)
[ 0.133638] ACPI BIOS Error (bug): Failure creating named object [_TZ.FAN0], AE_ALREADY_EXISTS (20240827/dswload2-326)
[ 0.133641] ACPI Error: AE_ALREADY_EXISTS, During name lookup/catalog (20240827/psobject-220)
[ 0.133642] ACPI: Skipping parse of AML opcode: Device (0x5B82)
[ 0.138919] ACPI: 29 ACPI AML tables successfully acquired and loaded
[ 0.144355] ACPI: USB4 OSC: OS supports USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.144356] ACPI: USB4 OSC: OS controls USB3+ DisplayPort+ PCIe+ XDomain+
[ 0.146402] ACPI: Interpreter enabled
[ 0.146436] ACPI: PM: (supports S0 S3 S4 S5)
[ 0.146437] ACPI: Using IOAPIC for interrupt routing
[ 0.147365] PCI: Using host bridge windows from ACPI; if necessary, use “pci=nocrs” and report a bug
[ 0.147366] PCI: Ignoring E820 reservations for host bridge windows
[ 0.148054] ACPI: Enabled 9 GPEs in block 00 to 7F
[ 0.148094] ACPI: Enabled 13 GPEs in block 80 to DF
[ 0.149961] ACPI: _SB
.PC00.RP02.PXP
: New power resource
[ 0.151039] ACPI: _SB
.PC00.RP03.PXSX.WRST: New power resource
[ 0.151220] ACPI: _SB
.PC00.RP04.PXP
[ 0.152068] ACPI: _SB
.PC00.RP05.PXP
[ 0.153043] ACPI: _SB
.PC00.XHCI.RHUB.HS06.BTRT: New power resource
.PC00.XHCI.RHUB.HS06.DBTR: New power resource
[ 0.153043] ACPI: _SB_.PC00.PAUD: New power resource
[ 0.156283] ACPI: _SB_.PC00.I2C3.PXTC: New power resource
[ 0.156867] ACPI: _SB_.PC00.I2C4.PTPL: New power resource
[ 0.157445] ACPI: _SB_.PC00.I2C5.PTPL: New power resource
[ 0.161077] ACPI: _SB_.PC00.CNVW.WRST: New power resource
[ 0.161077] ACPI: _SB_.PC00.BTPC.WRST: New power resource
[ 0.161430] ACPI: _SB_.PC00.TBT0: New power resource
[ 0.161460] ACPI: _SB_.PC00.TBT1: New power resource
[ 0.161486] ACPI: _SB_.PC00.D3C_: New power resource
[ 0.169413] ACPI: : Can’t tag data node
[ 0.169542] ACPI: : Can’t tag data node
[ 0.169668] ACPI: : Can’t tag data node
[ 0.169785] ACPI: : Can’t tag data node
[ 0.169904] ACPI: : Can’t tag data node
[ 0.172140] ACPI: _TZ_.FN00: New power resource
[ 0.172160] ACPI: _TZ_.FN01: New power resource
[ 0.172201] ACPI: _TZ_.FN02: New power resource
[ 0.172237] ACPI: _TZ_.FN03: New power resource
[ 0.172273] ACPI: _TZ_.FN04: New power resource
[ 0.172526] ACPI: \PIN_: New power resource
[ 0.172908] ACPI: PCI Root Bridge [PC00] (domain 0000 [bus 00-fe])
[ 0.172915] acpi PNP0A08:00: _OSC: OS supports [ExtendedConfig ASPM ClockPM Segments MSI EDR HPX-Type3]
[ 0.173763] acpi PNP0A08:00: _OSC: platform does not support [AER]
[ 0.175421] acpi PNP0A08:00: OSC: OS now controls [PCIeHotplug SHPCHotplug PME PCIeCapability LTR DPC]
[ 0.176985] PCI host bridge to bus 0000:00
[ 0.176987] pci_bus 0000:00: root bus resource [io 0x0000-0x0cf7 window]
[ 0.176989] pci_bus 0000:00: root bus resource [io 0x0d00-0xffff window]
[ 0.176990] pci_bus 0000:00: root bus resource [mem 0x000a0000-0x000bffff window]
[ 0.176991] pci_bus 0000:00: root bus resource [mem 0x80800000-0xbfffffff window]
[ 0.176992] pci_bus 0000:00: root bus resource [mem 0x2000000000-0x3fbfffffff window]
[ 0.176994] pci_bus 0000:00: root bus resource [bus 00-fe]
[ 0.177824] pci 0000:00:00.0: [8086:6400] type 00 class 0x060000 conventional PCI endpoint
[ 0.178246] pci 0000:00:02.0: [8086:64a0] type 00 class 0x030000 PCIe Root Complex Integrated Endpoint
[ 0.178500] pci 0000:00:02.0: BAR 0 [mem 0x3010000000-0x3010ffffff 64bit pref]
[ 0.178503] pci 0000:00:02.0: BAR 2 [mem 0x2000000000-0x200fffffff 64bit pref]
[ 0.178508] pci 0000:00:02.0: ROM [mem 0x8e000000-0x8e1fffff pref]
[ 0.178556] pci 0000:00:02.0: Video device with shadowed ROM at [mem 0x000c0000-0x000dffff]
[ 0.178805] pci 0000:00:04.0: [8086:641d] type 00 class 0x118000 conventional PCI endpoint
[ 0.178822] pci 0000:00:04.0: BAR 0 [mem 0x30142c0000-0x30142dffff 64bit]
[ 0.179070] pci 0000:00:07.0: [8086:a84e] type 01 class 0x060400 PCIe Root Port
[ 0.179106] pci 0000:00:07.0: PCI bridge to [bus 01-2a]
[ 0.179113] pci 0000:00:07.0: bridge window [mem 0x88000000-0x8dffffff]
[ 0.179124] pci 0000:00:07.0: bridge window [mem 0x2810000000-0x300fffffff 64bit pref]
[ 0.179239] pci 0000:00:07.0: PME# supported from D0 D3hot D3cold
[ 0.179283] pci 0000:00:07.0: PTM enabled (root), 4ns granularity
[ 0.179992] pci 0000:00:07.1: [8086:a84f] type 01 class 0x060400 PCIe Root Port
[ 0.180020] pci 0000:00:07.1: PCI bridge to [bus 2b-54]
[ 0.180027] pci 0000:00:07.1: bridge window [mem 0x82000000-0x87ffffff]
[ 0.180037] pci 0000:00:07.1: bridge window [mem 0x2010000000-0x280fffffff 64bit pref]
[ 0.180149] pci 0000:00:07.1: PME# supported from D0 D3hot D3cold
[ 0.180198] pci 0000:00:07.1: PTM enabled (root), 4ns granularity
[ 0.180892] pci 0000:00:0a.0: [8086:647d] type 00 class 0x118000 PCIe Root Complex Integrated Endpoint
[ 0.180915] pci 0000:00:0a.0: BAR 0 [mem 0x3014310000-0x301431ffff 64bit]
[ 0.180922] pci 0000:00:0a.0: enabling Extended Tags
[ 0.181001] pci 0000:00:0b.0: [8086:643e] type 00 class 0x120000 PCIe Root Complex Integrated Endpoint
[ 0.181016] pci 0000:00:0b.0: BAR 0 [mem 0x3012000000-0x3013ffffff 64bit]
[ 0.181019] pci 0000:00:0b.0: BAR 4 [mem 0x301433a000-0x301433afff 64bit]
[ 0.181121] pci 0000:00:0d.0: [8086:a831] type 00 class 0x0c0330 conventional PCI endpoint
[ 0.181160] pci 0000:00:0d.0: BAR 0 [mem 0x3014300000-0x301430ffff 64bit]
[ 0.181204] pci 0000:00:0d.0: PME# supported from D3hot D3cold
[ 0.181477] pci 0000:00:0d.2: [8086:a833] type 00 class 0x0c0340 conventional PCI endpoint
[ 0.181515] pci 0000:00:0d.2: BAR 0 [mem 0x3014280000-0x30142bffff 64bit]
[ 0.181518] pci 0000:00:0d.2: BAR 2 [mem 0x3014339000-0x3014339fff 64bit]
[ 0.181555] pci 0000:00:0d.2: supports D1 D2
[ 0.181556] pci 0000:00:0d.2: PME# supported from D0 D1 D2 D3hot D3cold
[ 0.181718] pci 0000:00:12.0: [8086:a845] type 00 class 0x070000 conventional PCI endpoint
[ 0.181766] pci 0000:00:12.0: BAR 0 [mem 0x30142f0000-0x30142fffff 64bit]
[ 0.181819] pci 0000:00:12.0: PME# supported from D0 D3hot
[ 0.182302] pci 0000:00:13.0: [8086:a862] type 00 class 0x078000 conventional PCI endpoint
[ 0.182372] pci 0000:00:13.0: BAR 0 [mem 0x3014338000-0x3014338fff 64bit]
[ 0.182449] pci 0000:00:13.0: PME# supported from D3hot
[ 0.182564] pci 0000:00:14.0: [8086:a87d] type 00 class 0x0c0330 conventional PCI endpoint
[ 0.182600] pci 0000:00:14.0: BAR 0 [mem 0x30142e0000-0x30142effff 64bit]
[ 0.182640] pci 0000:00:14.0: PME# supported from D3hot D3cold
[ 0.182942] pci 0000:00:14.2: [8086:a87f] type 00 class 0x050000 conventional PCI endpoint
[ 0.182992] pci 0000:00:14.2: BAR 0 [mem 0x3014320000-0x3014327fff 64bit]
[ 0.182997] pci 0000:00:14.2: BAR 2 [mem 0x3014337000-0x3014337fff 64bit]
[ 0.183105] pci 0000:00:14.3: [8086:a840] type 00 class 0x028000 PCIe Root Complex Integrated Endpoint
[ 0.183136] pci 0000:00:14.3: BAR 0 [mem 0x301432c000-0x301432ffff 64bit]
[ 0.183146] pci 0000:00:14.3: enabling Extended Tags
[ 0.183189] pci 0000:00:14.3: PME# supported from D0 D3hot D3cold
[ 0.183470] pci 0000:00:14.7: [8086:a876] type 00 class 0x0d1100 PCIe Root Complex Integrated Endpoint
[ 0.183511] pci 0000:00:14.7: BAR 0 [mem 0x3014328000-0x301432bfff 64bit]
[ 0.183524] pci 0000:00:14.7: enabling Extended Tags
[ 0.183576] pci 0000:00:14.7: PME# supported from D0 D3hot D3cold
[ 0.183837] pci 0000:00:15.0: [8086:a878] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.183897] pci 0000:00:15.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[ 0.184225] pci 0000:00:15.1: [8086:a879] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.184284] pci 0000:00:15.1: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[ 0.184608] pci 0000:00:15.2: [8086:a87a] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.184667] pci 0000:00:15.2: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[ 0.184984] pci 0000:00:15.3: [8086:a87b] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.185043] pci 0000:00:15.3: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[ 0.185348] pci 0000:00:16.0: [8086:a870] type 00 class 0x078000 conventional PCI endpoint
[ 0.185399] pci 0000:00:16.0: BAR 0 [mem 0x3014332000-0x3014332fff 64bit]
[ 0.185451] pci 0000:00:16.0: PME# supported from D3hot
[ 0.185975] pci 0000:00:19.0: [8086:a850] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.186036] pci 0000:00:19.0: BAR 0 [mem 0x00000000-0x00000fff 64bit]
[ 0.186399] pci 0000:00:1c.0: [8086:a83c] type 01 class 0x060400 PCIe Root Port
[ 0.186450] pci 0000:00:1c.0: PCI bridge to [bus 55]
[ 0.186462] pci 0000:00:1c.0: bridge window [mem 0x8e200000-0x8e2fffff]
[ 0.186678] pci 0000:00:1c.0: PME# supported from D0 D3hot D3cold
[ 0.186804] pci 0000:00:1c.0: PTM enabled (root), 4ns granularity
[ 0.187644] pci 0000:00:1f.0: [8086:a807] type 00 class 0x060100 conventional PCI endpoint
[ 0.187990] pci 0000:00:1f.3: [8086:a828] type 00 class 0x040100 conventional PCI endpoint
[ 0.188043] pci 0000:00:1f.3: BAR 0 [mem 0x3014200000-0x301427ffff 64bit]
[ 0.188050] pci 0000:00:1f.3: BAR 4 [mem 0x3014000000-0x30141fffff 64bit]
[ 0.188102] pci 0000:00:1f.3: PME# supported from D3hot D3cold
[ 0.188181] pci 0000:00:1f.4: [8086:a822] type 00 class 0x0c0500 conventional PCI endpoint
[ 0.188234] pci 0000:00:1f.4: BAR 0 [mem 0x3014330000-0x30143300ff 64bit]
[ 0.188240] pci 0000:00:1f.4: BAR 4 [io 0xefa0-0xefbf]
[ 0.188430] pci 0000:00:1f.5: [8086:a823] type 00 class 0x0c8000 conventional PCI endpoint
[ 0.188533] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]
[ 0.188654] pci 0000:00:07.0: PCI bridge to [bus 01-2a]
[ 0.188707] pci 0000:00:07.1: PCI bridge to [bus 2b-54]
[ 0.189064] pci 0000:55:00.0: [144d:a80a] type 00 class 0x010802 PCIe Endpoint
[ 0.189110] pci 0000:55:00.0: BAR 0 [mem 0x8e200000-0x8e203fff 64bit]
[ 0.189585] pci 0000:00:1c.0: ASPM: current common clock configuration is inconsistent, reconfiguring
[ 0.192419] pci 0000:00:1c.0: PCI bridge to [bus 55]
[ 0.194854] ACPI: PCI: Interrupt link LNKA configured for IRQ 0
[ 0.194917] ACPI: PCI: Interrupt link LNKB configured for IRQ 1
[ 0.194977] ACPI: PCI: Interrupt link LNKC configured for IRQ 0
[ 0.195037] ACPI: PCI: Interrupt link LNKD configured for IRQ 0
[ 0.195097] ACPI: PCI: Interrupt link LNKE configured for IRQ 0
[ 0.195156] ACPI: PCI: Interrupt link LNKF configured for IRQ 0
[ 0.195216] ACPI: PCI: Interrupt link LNKG configured for IRQ 0
[ 0.195275] ACPI: PCI: Interrupt link LNKH configured for IRQ 0
[ 0.195886] ACPI: _SB
.PEPD: Duplicate LPS0 _DSM functions (mask: 0x1)
[ 0.496602] Low-power S0 idle used by default for system suspend
[ 0.499097] iommu: Default domain type: Translated
[ 0.499097] iommu: DMA domain TLB invalidation policy: lazy mode
[ 0.499230] SCSI subsystem initialized
[ 0.499241] libata version 3.00 loaded.
[ 0.499241] ACPI: bus type USB registered
[ 0.499241] usbcore: registered new interface driver usbfs
[ 0.499241] usbcore: registered new interface driver hub
[ 0.499241] usbcore: registered new device driver usb
[ 0.499241] EDAC MC: Ver: 3.0.0
[ 0.500203] efivars: Registered efivars operations
[ 0.500295] NetLabel: Initializing
[ 0.500297] NetLabel: domain hash size = 128
[ 0.500298] NetLabel: protocols = UNLABELED CIPSOv4 CALIPSO
[ 0.500312] NetLabel: unlabeled traffic allowed by default
[ 0.500315] mctp: management component transport protocol core
[ 0.500317] NET: Registered PF_MCTP protocol family
[ 0.500328] PCI: Using ACPI for IRQ routing
[ 0.518965] PCI: pci_cache_line_size set to 64 bytes
[ 0.519327] pci 0000:00:1f.5: BAR 0 [mem 0xfe010000-0xfe010fff]: can’t claim; no compatible bridge window
[ 0.519712] e820: reserve RAM buffer [mem 0x0009f000-0x0009ffff]
[ 0.519714] e820: reserve RAM buffer [mem 0x59e3f000-0x5bffffff]
[ 0.519715] e820: reserve RAM buffer [mem 0x5f82c000-0x5fffffff]
[ 0.519716] e820: reserve RAM buffer [mem 0x634a4000-0x63ffffff]
[ 0.519716] e820: reserve RAM buffer [mem 0x87f800000-0x87fffffff]
[ 0.520078] pci 0000:00:02.0: vgaarb: setting as boot VGA device
[ 0.520078] pci 0000:00:02.0: vgaarb: bridge control possible
[ 0.520078] pci 0000:00:02.0: vgaarb: VGA device added: decodes=io+mem,owns=io+mem,locks=none
[ 0.520078] vgaarb: loaded
[ 0.520151] clocksource: Switched to clocksource tsc-early
[ 0.520231] VFS: Disk quotas dquot_6.6.0
[ 0.520231] VFS: Dquot-cache hash table entries: 512 (order 0, 4096 bytes)
[ 0.520358] pnp: PnP ACPI init
[ 0.520577] system 00:00: [io 0x0680-0x069f] has been reserved
[ 0.520581] system 00:00: [io 0x164e-0x164f] has been reserved
[ 0.521153] system 00:02: [mem 0xfedc0000-0xfedc7fff] has been reserved
[ 0.521156] system 00:02: [mem 0xd8000000-0xd8000fff] has been reserved
[ 0.521157] system 00:02: [mem 0x00000000-0x00000fff] could not be reserved
[ 0.521159] system 00:02: [mem 0xc0000000-0xcfffffff] has been reserved
[ 0.521160] system 00:02: [mem 0xfed20000-0xfed7ffff] could not be reserved
[ 0.521161] system 00:02: [mem 0xfc800000-0xfc81ffff] could not be reserved
[ 0.521162] system 00:02: [mem 0xfed45000-0xfed8ffff] could not be reserved
[ 0.521162] system 00:02: [mem 0xfee00000-0xfeefffff] could not be reserved
[ 0.521688] system 00:03: [io 0x2000-0x20fe] has been reserved
[ 0.522021] system 00:05: [io 0x1854-0x1857] has been reserved
[ 0.522359] pnp: PnP ACPI: found 6 devices
[ 0.527635] clocksource: acpi_pm: mask: 0xffffff max_cycles: 0xffffff, max_idle_ns: 2085701024 ns
[ 0.527684] NET: Registered PF_INET protocol family
[ 0.527901] IP idents hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.538307] tcp_listen_portaddr_hash hash table entries: 16384 (order: 6, 262144 bytes, linear)
[ 0.538345] Table-perturb hash table entries: 65536 (order: 6, 262144 bytes, linear)
[ 0.538562] TCP established hash table entries: 262144 (order: 9, 2097152 bytes, linear)
[ 0.538878] TCP bind hash table entries: 65536 (order: 9, 2097152 bytes, linear)
[ 0.539059] TCP: Hash tables configured (established 262144 bind 65536)
[ 0.539226] MPTCP token hash table entries: 32768 (order: 7, 786432 bytes, linear)
[ 0.539360] UDP hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[ 0.539522] UDP-Lite hash table entries: 16384 (order: 8, 1048576 bytes, linear)
[ 0.539621] NET: Registered PF_UNIX/PF_LOCAL protocol family
[ 0.539630] NET: Registered PF_XDP protocol family
[ 0.539641] pci 0000:00:07.0: bridge window [io 0x1000-0x0fff] to [bus 01-2a] add_size 1000
[ 0.539645] pci 0000:00:07.1: bridge window [io 0x1000-0x0fff] to [bus 2b-54] add_size 1000
[ 0.539661] pci 0000:00:07.0: bridge window [io 0x3000-0x3fff]: assigned
[ 0.539663] pci 0000:00:07.1: bridge window [io 0x4000-0x4fff]: assigned
[ 0.539666] pci 0000:00:15.0: BAR 0 [mem 0x3011000000-0x3011000fff 64bit]: assigned
[ 0.539726] pci 0000:00:15.1: BAR 0 [mem 0x3011001000-0x3011001fff 64bit]: assigned
[ 0.539771] pci 0000:00:15.2: BAR 0 [mem 0x3011002000-0x3011002fff 64bit]: assigned
[ 0.539787] pci 0000:00:15.3: BAR 0 [mem 0x3011003000-0x3011003fff 64bit]: assigned
[ 0.539802] pci 0000:00:19.0: BAR 0 [mem 0x3011004000-0x3011004fff 64bit]: assigned
[ 0.539818] pci 0000:00:1f.5: BAR 0 [mem 0x80800000-0x80800fff]: assigned
[ 0.539830] pci 0000:00:07.0: PCI bridge to [bus 01-2a]
[ 0.539837] pci 0000:00:07.0: bridge window [io 0x3000-0x3fff]
[ 0.539842] pci 0000:00:07.0: bridge window [mem 0x88000000-0x8dffffff]
[ 0.539845] pci 0000:00:07.0: bridge window [mem 0x2810000000-0x300fffffff 64bit pref]
[ 0.539851] pci 0000:00:07.1: PCI bridge to [bus 2b-54]
[ 0.539853] pci 0000:00:07.1: bridge window [io 0x4000-0x4fff]
[ 0.539857] pci 0000:00:07.1: bridge window [mem 0x82000000-0x87ffffff]
[ 0.539860] pci 0000:00:07.1: bridge window [mem 0x2010000000-0x280fffffff 64bit pref]
[ 0.539866] pci 0000:00:1c.0: PCI bridge to [bus 55]
[ 0.539935] pci 0000:00:1c.0: bridge window [mem 0x8e200000-0x8e2fffff]
[ 0.539949] pci_bus 0000:00: resource 4 [io 0x0000-0x0cf7 window]
[ 0.539950] pci_bus 0000:00: resource 5 [io 0x0d00-0xffff window]
[ 0.539951] pci_bus 0000:00: resource 6 [mem 0x000a0000-0x000bffff window]
[ 0.539953] pci_bus 0000:00: resource 7 [mem 0x80800000-0xbfffffff window]
[ 0.539953] pci_bus 0000:00: resource 8 [mem 0x2000000000-0x3fbfffffff window]
[ 0.539955] pci_bus 0000:01: resource 0 [io 0x3000-0x3fff]
[ 0.539956] pci_bus 0000:01: resource 1 [mem 0x88000000-0x8dffffff]
[ 0.539956] pci_bus 0000:01: resource 2 [mem 0x2810000000-0x300fffffff 64bit pref]
[ 0.539958] pci_bus 0000:2b: resource 0 [io 0x4000-0x4fff]
[ 0.539959] pci_bus 0000:2b: resource 1 [mem 0x82000000-0x87ffffff]
[ 0.539959] pci_bus 0000:2b: resource 2 [mem 0x2010000000-0x280fffffff 64bit pref]
[ 0.539961] pci_bus 0000:55: resource 1 [mem 0x8e200000-0x8e2fffff]
[ 0.541069] PCI: CLS 64 bytes, default 64
[ 0.541114] DMAR: Intel-IOMMU force enabled due to platform opt in
[ 0.541126] DMAR: No RMRR found
[ 0.541126] DMAR: No ATSR found
[ 0.541128] DMAR: dmar1: Using Queued invalidation
[ 0.541132] DMAR: dmar0: Using Queued invalidation
[ 0.541133] DMAR: dmar2: Using Queued invalidation
[ 0.541183] Trying to unpack rootfs image as initramfs…
[ 0.541642] pci 0000:00:04.0: Adding to iommu group 0
[ 0.541657] pci 0000:00:0a.0: Adding to iommu group 1
[ 0.541668] pci 0000:00:0b.0: Adding to iommu group 2
[ 0.541878] pci 0000:00:02.0: Adding to iommu group 3
[ 0.542022] pci 0000:00:00.0: Adding to iommu group 4
[ 0.542153] pci 0000:00:07.0: Adding to iommu group 5
[ 0.542165] pci 0000:00:07.1: Adding to iommu group 6
[ 0.542178] pci 0000:00:0d.0: Adding to iommu group 7
[ 0.542187] pci 0000:00:0d.2: Adding to iommu group 7
[ 0.542198] pci 0000:00:12.0: Adding to iommu group 8
[ 0.542208] pci 0000:00:13.0: Adding to iommu group 9
[ 0.542222] pci 0000:00:14.0: Adding to iommu group 10
[ 0.542232] pci 0000:00:14.2: Adding to iommu group 10
[ 0.542240] pci 0000:00:14.3: Adding to iommu group 11
[ 0.542248] pci 0000:00:14.7: Adding to iommu group 12
[ 0.542264] pci 0000:00:15.0: Adding to iommu group 13
[ 0.542272] pci 0000:00:15.1: Adding to iommu group 13
[ 0.542281] pci 0000:00:15.2: Adding to iommu group 13
[ 0.542290] pci 0000:00:15.3: Adding to iommu group 13
[ 0.542300] pci 0000:00:16.0: Adding to iommu group 14
[ 0.542309] pci 0000:00:19.0: Adding to iommu group 15
[ 0.542404] pci 0000:00:1c.0: Adding to iommu group 16
[ 0.542428] pci 0000:00:1f.0: Adding to iommu group 17
[ 0.542437] pci 0000:00:1f.3: Adding to iommu group 17
[ 0.542446] pci 0000:00:1f.4: Adding to iommu group 17
[ 0.542454] pci 0000:00:1f.5: Adding to iommu group 17
[ 0.542548] pci 0000:55:00.0: Adding to iommu group 18
[ 0.543085] DMAR: Intel(R) Virtualization Technology for Directed I/O
[ 0.543088] PCI-DMA: Using software bounce buffering for IO (SWIOTLB)
[ 0.543089] software IO TLB: mapped [mem 0x000000004ddec000-0x0000000051dec000] (64MB)
[ 0.543133] clocksource: tsc: mask: 0xffffffffffffffff max_cycles: 0x2f9a2767029, max_idle_ns: 440795219692 ns
[ 0.543188] clocksource: Switched to clocksource tsc
[ 0.543225] platform rtc_cmos: registered platform RTC device (no PNP device found)
[ 0.566600] Initialise system trusted keyrings
[ 0.566633] Key type blacklist registered
[ 0.566808] workingset: timestamp_bits=36 max_order=23 bucket_order=0
[ 0.567816] fuse: init (API version 7.42)
[ 0.568137] integrity: Platform Keyring initialized
[ 0.568149] integrity: Machine keyring initialized
[ 0.574157] xor: automatically using best checksumming function avx
[ 0.574157] Key type asymmetric registered
[ 0.574158] Asymmetric key parser ‘x509’ registered
[ 0.574167] Block layer SCSI generic (bsg) driver version 0.4 loaded (major 246)
[ 0.574251] io scheduler mq-deadline registered
[ 0.574252] io scheduler kyber registered
[ 0.574257] io scheduler bfq registered
[ 0.574504] ledtrig-cpu: registered to indicate activity on CPUs
[ 0.574829] pcieport 0000:00:07.0: PME: Signaling with IRQ 126
[ 0.574848] pcieport 0000:00:07.0: pciehp: Slot #6 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.575122] pcieport 0000:00:07.1: PME: Signaling with IRQ 127
[ 0.575136] pcieport 0000:00:07.1: pciehp: Slot #7 AttnBtn- PwrCtrl- MRL- AttnInd- PwrInd- HotPlug+ Surprise+ Interlock- NoCompl+ IbPresDis- LLActRep+
[ 0.575851] pcieport 0000:00:1c.0: PME: Signaling with IRQ 128
[ 0.576107] shpchp: Standard Hot Plug PCI Controller Driver version: 0.4
[ 0.576202] Monitor-Mwait will be used to enter C-1 state
[ 0.576204] Monitor-Mwait will be used to enter C-2 state
[ 0.576205] Monitor-Mwait will be used to enter C-3 state
[ 0.576695] ACPI: AC: AC Adapter [ADP0] (off-line)
[ 0.576716] input: Lid Switch as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/device:00/PNP0C0D:01/input/input0
[ 0.576723] ACPI: button: Lid Switch [LID0]
[ 0.576739] input: Power Button as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0C0C:00/input/input1
[ 0.576748] ACPI: button: Power Button [PWRB]
[ 0.583163] thermal LNXTHERM:00: registered as thermal_zone0
[ 0.583164] ACPI: thermal: Thermal Zone [TZ00] (28 C)
[ 0.583291] Serial: 8250/16550 driver, 32 ports, IRQ sharing enabled
[ 0.584329] ACPI: battery: Slot [BAT0] (battery present)
[ 0.584413] serial 0000:00:12.0: enabling device (0000 → 0002)
[ 0.584615] hpet_acpi_add: no address or irqs in _CRS
[ 0.584635] Non-volatile memory driver v1.3
[ 0.584636] Linux agpgart interface v0.103
[ 0.607989] ACPI: bus type drm_connector registered
[ 0.614271] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 0.614301] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 1
[ 0.615569] xhci_hcd 0000:00:0d.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[ 0.616669] xhci_hcd 0000:00:0d.0: xHCI Host Controller
[ 0.616680] xhci_hcd 0000:00:0d.0: new USB bus registered, assigned bus number 2
[ 0.616690] xhci_hcd 0000:00:0d.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 0.616935] usb usb1: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 0.616949] usb usb1: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.616955] usb usb1: Product: xHCI Host Controller
[ 0.616961] usb usb1: Manufacturer: Linux 6.14.3-arch1-1 xhci-hcd
[ 0.616966] usb usb1: SerialNumber: 0000:00:0d.0
[ 0.617152] hub 1-0:1.0: USB hub found
[ 0.617180] hub 1-0:1.0: 1 port detected
[ 0.617559] usb usb2: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[ 0.617562] usb usb2: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.617563] usb usb2: Product: xHCI Host Controller
[ 0.617565] usb usb2: Manufacturer: Linux 6.14.3-arch1-1 xhci-hcd
[ 0.617566] usb usb2: SerialNumber: 0000:00:0d.0
[ 0.617646] hub 2-0:1.0: USB hub found
[ 0.617674] hub 2-0:1.0: 2 ports detected
[ 0.619449] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.619453] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 3
[ 0.620588] xhci_hcd 0000:00:14.0: hcc params 0x20007fc1 hci version 0x120 quirks 0x0000000200009810
[ 0.621040] xhci_hcd 0000:00:14.0: xHCI Host Controller
[ 0.621043] xhci_hcd 0000:00:14.0: new USB bus registered, assigned bus number 4
[ 0.621045] xhci_hcd 0000:00:14.0: Host supports USB 3.2 Enhanced SuperSpeed
[ 0.621079] usb usb3: New USB device found, idVendor=1d6b, idProduct=0002, bcdDevice= 6.14
[ 0.621082] usb usb3: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.621084] usb usb3: Product: xHCI Host Controller
[ 0.621085] usb usb3: Manufacturer: Linux 6.14.3-arch1-1 xhci-hcd
[ 0.621086] usb usb3: SerialNumber: 0000:00:14.0
[ 0.621186] hub 3-0:1.0: USB hub found
[ 0.621219] hub 3-0:1.0: 8 ports detected
[ 0.623439] usb usb4: New USB device found, idVendor=1d6b, idProduct=0003, bcdDevice= 6.14
[ 0.623441] usb usb4: New USB device strings: Mfr=3, Product=2, SerialNumber=1
[ 0.623443] usb usb4: Product: xHCI Host Controller
[ 0.623444] usb usb4: Manufacturer: Linux 6.14.3-arch1-1 xhci-hcd
[ 0.623446] usb usb4: SerialNumber: 0000:00:14.0
[ 0.623534] hub 4-0:1.0: USB hub found
[ 0.623561] hub 4-0:1.0: 2 ports detected
[ 0.624085] usbcore: registered new interface driver usbserial_generic
[ 0.624092] usbserial: USB Serial support registered for generic
[ 0.624180] rtc_cmos rtc_cmos: RTC can wake from S4
[ 0.625236] rtc_cmos rtc_cmos: registered as rtc0
[ 0.625455] rtc_cmos rtc_cmos: setting system clock to 2025-04-22T21:57:42 UTC (1745359062)
[ 0.625510] rtc_cmos rtc_cmos: alarms up to one month, y3k, 114 bytes nvram
[ 0.625949] intel_pstate: Intel P-state driver initializing
[ 0.627661] Hybrid CPU capacity scaling enabled
[ 0.628116] intel_pstate: HWP enabled
[ 0.628264] Relocating firmware framebuffer to offset 0x0000000000800000[d] within [mem 0x2000000000-0x200fffffff flags 0x14220c]
[ 0.628377] simple-framebuffer simple-framebuffer.0: [drm] Registered 1 planes with drm panic
[ 0.628379] [drm] Initialized simpledrm 1.0.0 for simple-framebuffer.0 on minor 0
[ 0.629433] Console: switching to colour frame buffer device 100x37
[ 0.630046] Freeing initrd memory: 30468K
[ 0.630058] simple-framebuffer simple-framebuffer.0: [drm] fb0: simpledrmdrmfb frame buffer device
[ 0.630719] hid: raw HID events driver (C) Jiri Kosina
[ 0.630768] drop_monitor: Initializing network drop monitor service
[ 0.630837] NET: Registered PF_INET6 protocol family
[ 0.636325] Segment Routing with IPv6
[ 0.636325] RPL Segment Routing with IPv6
[ 0.636330] In-situ OAM (IOAM) with IPv6
[ 0.636344] NET: Registered PF_PACKET protocol family
[ 0.637012] ENERGY_PERF_BIAS: Set to ‘normal’, was ‘performance’
[ 0.637129] microcode: Current revision: 0x00000116
[ 0.637232] IPI shorthand broadcast: enabled
[ 0.638151] sched_clock: Marking stable (630000783, 7418041)->(659502332, -22083508)
[ 0.638324] registered taskstats version 1
[ 0.638588] Loading compiled-in X.509 certificates
[ 0.642440] Loaded X.509 cert ‘Build time autogenerated kernel key: 153b0a8ad8975753c99c6379dae770f697e830d1’
[ 0.644671] zswap: loaded using pool zstd/zsmalloc
[ 0.644731] Demotion targets for Node 0: null
[ 0.644939] Key type .fscrypt registered
[ 0.644940] Key type fscrypt-provisioning registered
[ 0.645456] Btrfs loaded, zoned=yes, fsverity=yes
[ 0.645790] integrity: Loading X.509 certificate: UEFI:db
[ 0.645802] integrity: Loaded X.509 cert ‘ASUS Secure Boot DB: 7f24bbb882a8aeb84f34f5d74105ebb3’
[ 0.645803] integrity: Loading X.509 certificate: UEFI:db
[ 0.645813] integrity: Loaded X.509 cert ‘Microsoft UEFI CA 2023: 81aa6b3244c935bce0d6628af39827421e32497d’
[ 0.645813] integrity: Loading X.509 certificate: UEFI:db
[ 0.645822] integrity: Loaded X.509 cert ‘Microsoft Corporation: Windows UEFI CA 2023: aefc5fbbbe055d8f8daa585473499417ab5a5272’
[ 0.645822] integrity: Loading X.509 certificate: UEFI:db
[ 0.645830] integrity: Loaded X.509 cert ‘Microsoft Corporation UEFI CA 2011: 13adbf4309bd82709c8cd54f316ed522988a1bd4’
[ 0.645831] integrity: Loading X.509 certificate: UEFI:db
[ 0.645838] integrity: Loaded X.509 cert ‘Microsoft Windows Production PCA 2011: a92902398e16c49778cd90f99e4f9ae17c55af53’
[ 0.646856] PM: Magic number: 5:313:1006
[ 0.646935] memory memory45: hash matches
[ 0.648999] RAS: Correctable Errors collector initialized.
[ 0.655022] clk: Disabling unused clocks
[ 0.655023] PM: genpd: Disabling unused power domains
[ 0.659449] Freeing unused decrypted memory: 2028K
[ 0.659976] Freeing unused kernel image (initmem) memory: 4528K
[ 0.659991] Write protecting the kernel read-only data: 36864k
[ 0.660347] Freeing unused kernel image (text/rodata gap) memory: 1280K
[ 0.660385] Freeing unused kernel image (rodata/data gap) memory: 112K
[ 0.664388] x86/mm: Checked W+X mappings: passed, no W+X pages found.
[ 0.664391] rodata_test: all tests were successful
[ 0.664394] Run /init as init process
[ 0.664395] with arguments:
[ 0.664396] /init
[ 0.664396] with environment:
[ 0.664397] HOME=/
[ 0.664397] TERM=linux
[ 0.664397] nvme_load=YES
[ 0.692417] systemd[1]: Successfully made /usr/ read-only.
[ 0.692523] systemd[1]: systemd 257.5-2-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[ 0.692526] systemd[1]: Detected architecture x86-64.
[ 0.692527] systemd[1]: Running in initrd.
[ 0.692627] systemd[1]: Hostname set to .
[ 0.757391] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[ 0.796193] systemd[1]: Queued start job for default target Initrd Default Target.
[ 0.804906] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 0.805099] systemd[1]: Expecting device /dev/disk/by-uuid/44d60f4b-8750-466e-81b4-7374617c0042…
[ 0.805171] systemd[1]: Reached target Initrd /usr File System.
[ 0.805235] systemd[1]: Reached target Path Units.
[ 0.805296] systemd[1]: Reached target Slice Units.
[ 0.805349] systemd[1]: Reached target Swaps.
[ 0.805404] systemd[1]: Reached target Timer Units.
[ 0.805509] systemd[1]: Listening on Journal Socket (/dev/log).
[ 0.805593] systemd[1]: Listening on Journal Sockets.
[ 0.805673] systemd[1]: Listening on udev Control Socket.
[ 0.805743] systemd[1]: Listening on udev Kernel Socket.
[ 0.805798] systemd[1]: Reached target Socket Units.
[ 0.806473] systemd[1]: Starting Create List of Static Device Nodes…
[ 0.807030] systemd[1]: Starting Check battery level during early boot…
[ 0.807890] systemd[1]: Starting Journal Service…
[ 0.809308] systemd[1]: Starting Load Kernel Modules…
[ 0.810315] systemd[1]: TPM PCR Barrier (initrd) was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 0.810635] systemd[1]: Starting Virtual Console Setup…
[ 0.812471] systemd[1]: Finished Create List of Static Device Nodes.
[ 0.814749] systemd[1]: Starting Create Static Device Nodes in /dev gracefully…
[ 0.817130] systemd[1]: Finished Check battery level during early boot.
[ 0.824402] systemd[1]: Finished Virtual Console Setup.
[ 0.824426] systemd-journald[176]: Collecting audit messages is disabled.
[ 0.825063] systemd[1]: dracut ask for additional cmdline parameters was skipped because no trigger condition checks were met.
[ 0.825928] systemd[1]: Starting dracut cmdline hook…
[ 0.826169] i2c_dev: i2c /dev entries driver
[ 0.828461] Asymmetric key parser ‘pkcs8’ registered
[ 0.828997] systemd[1]: Finished Load Kernel Modules.
[ 0.830312] systemd[1]: Starting Apply Kernel Variables…
[ 0.834328] systemd[1]: Finished Create Static Device Nodes in /dev gracefully.
[ 0.835245] systemd[1]: Starting Create Static Device Nodes in /dev…
[ 0.837661] systemd[1]: Finished Apply Kernel Variables.
[ 0.846245] systemd[1]: Finished Create Static Device Nodes in /dev.
[ 0.846436] systemd[1]: Reached target Preparation for Local File Systems.
[ 0.846553] systemd[1]: Reached target Local File Systems.
[ 0.860027] systemd[1]: Finished dracut cmdline hook.
[ 0.860275] systemd[1]: dracut pre-udev hook was skipped because no trigger condition checks were met.
[ 0.861054] systemd[1]: Starting Rule-based Manager for Device Events and Files…
[ 0.864458] usb 3-4: new full-speed USB device number 2 using xhci_hcd
[ 0.905695] systemd[1]: Started Rule-based Manager for Device Events and Files.
[ 0.906250] systemd[1]: dracut pre-trigger hook was skipped because no trigger condition checks were met.
[ 0.907126] systemd[1]: Starting Coldplug All udev Devices…
[ 0.961898] systemd[1]: Created slice Slice /system/modprobe.
[ 0.962719] systemd[1]: Starting Load Kernel Module configfs…
[ 0.971611] systemd[1]: Finished Coldplug All udev Devices.
[ 0.973909] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 0.974081] systemd[1]: Finished Load Kernel Module configfs.
[ 0.978246] systemd[1]: dracut initqueue hook was skipped because no trigger condition checks were met.
[ 0.978274] systemd[1]: Reached target Preparation for Remote File Systems.
[ 0.979989] systemd[1]: Reached target Remote File Systems.
[ 0.980252] systemd[1]: dracut pre-mount hook was skipped because no trigger condition checks were met.
[ 0.990949] usb 3-4: New USB device found, idVendor=1050, idProduct=0407, bcdDevice= 5.43
[ 0.990955] usb 3-4: New USB device strings: Mfr=1, Product=2, SerialNumber=0
[ 0.990957] usb 3-4: Product: YubiKey OTP+FIDO+CCID
[ 0.990958] usb 3-4: Manufacturer: Yubico
[ 0.992399] i8042: PNP: PS/2 Controller [PNP030b:PS2K] at 0x60,0x64 irq 1
[ 0.992402] i8042: PNP: PS/2 appears to have AUX port disabled, if this is incorrect please boot with i8042.nopnp
[ 0.994097] serio: i8042 KBD port at 0x60,0x64 irq 1
[ 1.008602] cryptd: max_cpu_qlen set to 1000
[ 1.015338] AES CTR mode by8 optimization enabled
[ 1.023456] intel-lpss 0000:00:15.0: enabling device (0004 → 0006)
[ 1.023847] idma64 idma64.0: Found Intel integrated DMA 64-bit
[ 1.025927] systemd[1]: systemd-vconsole-setup.service: Deactivated successfully.
[ 1.026157] systemd[1]: Stopped Virtual Console Setup.
[ 1.026435] systemd[1]: Stopping Virtual Console Setup…
[ 1.027336] systemd[1]: Starting Virtual Console Setup…
[ 1.028317] nvme 0000:55:00.0: platform quirk: setting simple suspend
[ 1.028495] nvme nvme0: pci function 0000:55:00.0
[ 1.030464] input: AT Translated Set 2 keyboard as /devices/platform/i8042/serio0/input/input2
[ 1.040494] intel-lpss 0000:00:15.1: enabling device (0004 → 0006)
[ 1.040828] nvme nvme0: D3 entry latency set to 10 seconds
[ 1.041452] idma64 idma64.1: Found Intel integrated DMA 64-bit
[ 1.043634] nvme nvme0: 8/0/0 default/read/poll queues
[ 1.046640] nvme0n1: p1 p2
[ 1.047075] systemd[1]: Finished Virtual Console Setup.
[ 1.056467] intel-lpss 0000:00:15.2: enabling device (0004 → 0006)
[ 1.056722] idma64 idma64.2: Found Intel integrated DMA 64-bit
[ 1.072472] intel-lpss 0000:00:15.3: enabling device (0004 → 0006)
[ 1.074151] idma64 idma64.3: Found Intel integrated DMA 64-bit
[ 1.095483] intel-lpss 0000:00:19.0: enabling device (0004 → 0006)
[ 1.105464] usb 3-5: new high-speed USB device number 3 using xhci_hcd
[ 1.111915] ucsi_acpi USBC000:00: error -ENODEV: PPM init failed
[ 1.233387] usb 3-5: New USB device found, idVendor=3277, idProduct=0060, bcdDevice= 1.01
[ 1.233396] usb 3-5: New USB device strings: Mfr=3, Product=1, SerialNumber=2
[ 1.233398] usb 3-5: Product: USB2.0 FHD UVC WebCam
[ 1.233400] usb 3-5: Manufacturer: Shinetech
[ 1.233402] usb 3-5: SerialNumber: 200901010001
[ 1.246319] usbcore: registered new interface driver usbhid
[ 1.246323] usbhid: USB HID core driver
[ 1.247708] systemd[1]: Started Journal Service.
[ 1.267586] input: ASCP1200:00 093A:3016 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ASCP1200:00/0018:093A:3016.0001/input/input3
[ 1.267674] input: ASCP1200:00 093A:3016 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ASCP1200:00/0018:093A:3016.0001/input/input4
[ 1.267757] hid-generic 0018:093A:3016.0001: input,hidraw0: I2C HID v1.00 Mouse [ASCP1200:00 093A:3016] on i2c-ASCP1200:00
[ 1.267907] input: Yubico YubiKey OTP+FIDO+CCID as /devices/pci0000:00/0000:00:14.0/usb3/3-4/3-4:1.0/0003:1050:0407.0002/input/input5
[ 1.384566] hid-generic 0003:1050:0407.0002: input,hidraw1: USB HID v1.10 Keyboard [Yubico YubiKey OTP+FIDO+CCID] on usb-0000:00:14.0-4/input0
[ 1.384729] hid-generic 0003:1050:0407.0003: hiddev96,hidraw2: USB HID v1.10 Device [Yubico YubiKey OTP+FIDO+CCID] on usb-0000:00:14.0-4/input1
[ 1.384912] hid-generic 0018:0B05:19B6.0004: hidraw3: I2C HID v1.00 Device [ITE5570:00 0B05:19B6] on i2c-ITE5570:00
[ 1.430293] intel_ish_ipc 0000:00:12.0: ISH loader: load firmware: intel/ish/ish_lnlm.bin
[ 1.436633] input: ASCP1200:00 093A:3016 Mouse as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ASCP1200:00/0018:093A:3016.0001/input/input6
[ 1.436718] input: ASCP1200:00 093A:3016 Touchpad as /devices/pci0000:00/0000:00:15.1/i2c_designware.1/i2c-1/i2c-ASCP1200:00/0018:093A:3016.0001/input/input7
[ 1.436785] hid-multitouch 0018:093A:3016.0001: input,hidraw0: I2C HID v1.00 Mouse [ASCP1200:00 093A:3016] on i2c-ASCP1200:00
[ 1.632459] intel_ish_ipc 0000:00:12.0: ISH loader: wait response of cmd 2 timeout
[ 1.736454] intel_ish_ipc 0000:00:12.0: ISH loader: wait response of cmd 2 timeout
[ 1.841456] intel_ish_ipc 0000:00:12.0: ISH loader: wait response of cmd 0 timeout
[ 1.876593] EXT4-fs (nvme0n1p2): mounted filesystem 44d60f4b-8750-466e-81b4-7374617c0042 r/w with ordered data mode. Quota mode: none.
[ 2.246915] systemd-journald[176]: Received SIGTERM from PID 1 (systemd).
[ 2.306179] systemd[1]: systemd 257.5-2-arch running in system mode (+PAM +AUDIT -SELINUX -APPARMOR -IMA +IPE +SMACK +SECCOMP +GCRYPT +GNUTLS +OPENSSL +ACL +BLKID +CURL +ELFUTILS +FIDO2 +IDN2 -IDN +IPTC +KMOD +LIBCRYPTSETUP +LIBCRYPTSETUP_PLUGINS +LIBFDISK +PCRE2 +PWQUALITY +P11KIT +QRENCODE +TPM2 +BZIP2 +LZ4 +XZ +ZLIB +ZSTD +BPF_FRAMEWORK +BTF +XKBCOMMON +UTMP -SYSVINIT +LIBARCHIVE)
[ 2.306183] systemd[1]: Detected architecture x86-64.
[ 2.608310] systemd[1]: bpf-restrict-fs: LSM BPF program attached
[ 2.793217] systemd[1]: initrd-switch-root.service: Deactivated successfully.
[ 2.793289] systemd[1]: Stopped Switch Root.
[ 2.793928] systemd[1]: systemd-journald.service: Scheduled restart job, restart counter is at 1.
[ 2.794201] systemd[1]: Created slice CUPS Slice.
[ 2.794499] systemd[1]: Created slice Slice /system/dirmngr.
[ 2.794774] systemd[1]: Created slice Slice /system/getty.
[ 2.795056] systemd[1]: Created slice Slice /system/gpg-agent.
[ 2.795324] systemd[1]: Created slice Slice /system/gpg-agent-browser.
[ 2.796201] systemd[1]: Created slice Slice /system/gpg-agent-extra.
[ 2.797173] systemd[1]: Created slice Slice /system/gpg-agent-ssh.
[ 2.798191] systemd[1]: Created slice Slice /system/keyboxd.
[ 2.799275] systemd[1]: Created slice Slice /system/systemd-fsck.
[ 2.800277] systemd[1]: Created slice User and Session Slice.
[ 2.801130] systemd[1]: Started Dispatch Password Requests to Console Directory Watch.
[ 2.801895] systemd[1]: Started Forward Password Requests to Wall Directory Watch.
[ 2.802562] systemd[1]: Set up automount Arbitrary Executable File Formats File System Automount Point.
[ 2.802676] systemd[1]: Expecting device /dev/disk/by-uuid/A0B4-6E14…
[ 2.802780] systemd[1]: Reached target Local Encrypted Volumes.
[ 2.802885] systemd[1]: Reached target Login Prompts.
[ 2.802985] systemd[1]: Stopped target Switch Root.
[ 2.803085] systemd[1]: Stopped target Initrd File Systems.
[ 2.803177] systemd[1]: Stopped target Initrd Root File System.
[ 2.803270] systemd[1]: Reached target Local Integrity Protected Volumes.
[ 2.803371] systemd[1]: Reached target Remote File Systems.
[ 2.803461] systemd[1]: Reached target Slice Units.
[ 2.803548] systemd[1]: Reached target Swaps.
[ 2.803634] systemd[1]: Reached target Local Verity Protected Volumes.
[ 2.803757] systemd[1]: Listening on Device-mapper event daemon FIFOs.
[ 2.803876] systemd[1]: Listening on LVM2 poll daemon socket.
[ 2.804704] systemd[1]: Listening on Process Core Dump Socket.
[ 2.805383] systemd[1]: Listening on Credential Encryption/Decryption.
[ 2.806119] systemd[1]: TPM PCR Measurements was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 2.806129] systemd[1]: Make TPM PCR Policy was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 2.806169] systemd[1]: Listening on udev Control Socket.
[ 2.806820] systemd[1]: Listening on udev Kernel Socket.
[ 2.806932] systemd[1]: Listening on User Database Manager Socket.
[ 2.807570] systemd[1]: Mounting Huge Pages File System…
[ 2.808021] systemd[1]: Mounting POSIX Message Queue File System…
[ 2.808555] systemd[1]: Mounting Kernel Debug File System…
[ 2.809130] systemd[1]: Mounting Kernel Trace File System…
[ 2.809761] systemd[1]: Starting Create List of Static Device Nodes…
[ 2.811444] systemd[1]: Starting Monitoring of LVM2 mirrors, snapshots etc. using dmeventd or progress polling…
[ 2.823902] systemd[1]: Starting Load Kernel Module configfs…
[ 2.825520] systemd[1]: Starting Load Kernel Module dm_mod…
[ 2.827647] systemd[1]: Starting Load Kernel Module drm…
[ 2.829253] systemd[1]: Starting Load Kernel Module fuse…
[ 2.830564] systemd[1]: Starting Load Kernel Module loop…
[ 2.830969] systemd[1]: Clear Stale Hibernate Storage Info was skipped because of an unmet condition check (ConditionPathExists=/sys/firmware/efi/efivars/HibernateLocation-8cf2644b-4b0b-428f-9387-6d876050dc67).
[ 2.832728] systemd[1]: Starting Journal Service…
[ 2.835271] systemd[1]: Starting Load Kernel Modules…
[ 2.836569] systemd[1]: TPM PCR Machine ID Measurement was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 2.837673] systemd[1]: Starting Remount Root and Kernel File Systems…
[ 2.838708] systemd[1]: Early TPM SRK Setup was skipped because of an unmet condition check (ConditionSecurity=measured-uki).
[ 2.840049] systemd[1]: Starting Load udev Rules from Credentials…
[ 2.842171] systemd[1]: Starting Coldplug All udev Devices…
[ 2.845293] systemd[1]: Mounted Huge Pages File System.
[ 2.846178] systemd[1]: Mounted POSIX Message Queue File System.
[ 2.846407] systemd[1]: Mounted Kernel Debug File System.
[ 2.846629] systemd[1]: Mounted Kernel Trace File System.
[ 2.846994] systemd[1]: Finished Create List of Static Device Nodes.
[ 2.847367] systemd[1]: modprobe@configfs.service: Deactivated successfully.
[ 2.848182] systemd[1]: Finished Load Kernel Module configfs.
[ 2.848459] loop: module loaded
[ 2.849991] systemd[1]: modprobe@drm.service: Deactivated successfully.
[ 2.850159] systemd[1]: Finished Load Kernel Module drm.
[ 2.851590] systemd[1]: modprobe@fuse.service: Deactivated successfully.
[ 2.851741] systemd[1]: Finished Load Kernel Module fuse.
[ 2.853041] systemd[1]: modprobe@loop.service: Deactivated successfully.
[ 2.853194] systemd[1]: Finished Load Kernel Module loop.
[ 2.853970] device-mapper: uevent: version 1.0.3
[ 2.854083] device-mapper: ioctl: 4.49.0-ioctl (2025-01-17) initialised: dm-devel@lists.linux.dev
[ 2.854385] systemd[1]: Finished Load Kernel Modules.
[ 2.854861] systemd[1]: modprobe@dm_mod.service: Deactivated successfully.
[ 2.854998] systemd[1]: Finished Load Kernel Module dm_mod.
[ 2.856585] systemd[1]: Mounting FUSE Control File System…
[ 2.857659] systemd[1]: Repartition Root Disk was skipped because no trigger condition checks were met.
[ 2.858449] systemd[1]: Starting Apply Kernel Variables…
[ 2.859683] systemd[1]: Starting Create Static Device Nodes in /dev gracefully…
[ 2.860789] systemd[1]: Finished Load udev Rules from Credentials.
[ 2.861482] systemd-journald[376]: Collecting audit messages is disabled.
[ 2.863600] systemd[1]: Mounted FUSE Control File System.
[ 2.865225] systemd[1]: Started Journal Service.
[ 2.865767] EXT4-fs (nvme0n1p2): re-mounted 44d60f4b-8750-466e-81b4-7374617c0042 r/w. Quota mode: none.
[ 2.890960] systemd-journald[376]: Received client request to flush runtime journal.
[ 3.093880] mousedev: PS/2 mouse device common for all mice
[ 3.112578] intel_vsec 0000:00:0a.0: enabling device (0000 → 0002)
[ 3.121771] input: Intel HID events as /devices/platform/INTC107B:00/input/input8
[ 3.122851] intel-hid INTC107B:00: failed to enable HID power button
[ 3.164464] pci 0000:00:0b.0: Setting to D3hot
[ 3.164518] thermal thermal_zone2: Temperature check failed (-5)
[ 3.171689] thermal thermal_zone3: Temperature check failed (-5)
[ 3.176727] intel_pmc_core INT33A1:00: Assuming a default substate order for this platform
[ 3.176754] intel_pmc_core INT33A1:00: initialized
[ 3.178611] intel_vpu 0000:00:0b.0: enabling device (0000 → 0002)
[ 3.182204] thermal thermal_zone5: Temperature check failed (-5)
[ 3.186462] intel_vpu 0000:00:0b.0: [drm] Firmware: intel/vpu/vpu_40xx_v0.0.bin, version: Mar 6 2025
NPU40xxci_tag_ud202512_vpu_rc_20250306_11305064b5debc377e1c4b74f69dc14e2e536dba393d
[ 3.186470] intel_vpu 0000:00:0b.0: [drm] Scheduler mode: OS
[ 3.188370] thermal thermal_zone6: Temperature check failed (-5)
[ 3.196252] mc: Linux media interface: v0.10
[ 3.200024] ACPI: bus type thunderbolt registered
[ 3.227835] input: PC Speaker as /devices/platform/pcspkr/input/input9
[ 3.238730] Bluetooth: Core ver 2.22
[ 3.238745] NET: Registered PF_BLUETOOTH protocol family
[ 3.238746] Bluetooth: HCI device and connection manager initialized
[ 3.238749] Bluetooth: HCI socket layer initialized
[ 3.238751] Bluetooth: L2CAP socket layer initialized
[ 3.238752] Bluetooth: SCO socket layer initialized
[ 3.253986] videodev: Linux video capture interface: v2.00
[ 3.257075] cfg80211: Loading compiled-in X.509 certificates for regulatory database
[ 3.259515] proc_thermal_pci 0000:00:04.0: enabling device (0400 → 0402)
[ 3.259597] intel_rapl_common: Found RAPL domain package
[ 3.259602] intel_rapl_common: Found RAPL domain dram
[ 3.261030] asus_wmi: ASUS WMI generic driver loaded
[ 3.261450] Loaded X.509 cert ‘sforshee: 00b28ddf47aef9cea7’
[ 3.261549] Loaded X.509 cert ‘wens: 61c038651aabdcf94bd0ac7ff06c7248db18c600’
[ 3.261583] platform regulatory.0: Direct firmware load for regulatory.db failed with error -2
[ 3.261585] cfg80211: failed to load regulatory.db
[ 3.266724] asus_wmi: Initialization: 0x1
[ 3.266862] asus_wmi: SFUN value: 0x21
[ 3.266866] asus-nb-wmi asus-nb-wmi: Detected ATK, not ASUSWMI, use DSTS
[ 3.269400] RAPL PMU: API unit is 2^-32 Joules, 3 fixed counters, 655360 ms ovfl timer
[ 3.269403] RAPL PMU: hw unit of domain pp0-core 2^-14 Joules
[ 3.269404] RAPL PMU: hw unit of domain package 2^-14 Joules
[ 3.269404] RAPL PMU: hw unit of domain dram 2^-14 Joules
[ 3.269882] [drm] Initialized intel_vpu 1.0.0 for 0000:00:0b.0 on minor 0
[ 3.270896] btintel_pcie 0000:00:14.7: enabling device (0000 → 0002)
[ 3.278199] proc_thermal_pci 0000:00:04.0: msi enabled:1 msix enabled:0
[ 3.283579] Intel(R) Wireless WiFi driver for Linux
[ 3.285164] iwlwifi 0000:00:14.3: enabling device (0000 → 0002)
[ 3.286026] asus-nb-wmi asus-nb-wmi: Using throttle_thermal_policy for platform_profile support
[ 3.296038] input: Asus WMI hotkeys as /devices/platform/asus-nb-wmi/input/input10
[ 3.297491] Bluetooth: hci0: Device revision is 0
[ 3.297496] Bluetooth: hci0: Secure boot is enabled
[ 3.297497] Bluetooth: hci0: OTP lock is disabled
[ 3.297498] Bluetooth: hci0: API lock is enabled
[ 3.297499] Bluetooth: hci0: Debug lock is disabled
[ 3.297499] Bluetooth: hci0: Minimum firmware build 1 week 10 2014
[ 3.297501] Bluetooth: hci0: Bootloader timestamp 2023.33 buildtype 1 build 45995
[ 3.298043] Bluetooth: hci0: Found device firmware: intel/ibt-0190-0291-iml.sfi
[ 3.298048] Bluetooth: hci0: Boot Address: 0x30099000
[ 3.298049] Bluetooth: hci0: Firmware Version: 58-7.25
[ 3.298417] iwlwifi 0000:00:14.3: Detected crf-id 0x2001910, cnv-id 0x1080900 wfpm id 0x80005b20
[ 3.298433] iwlwifi 0000:00:14.3: PCI dev a840/00e4, rev=0x461, rfid=0x20112200
[ 3.298435] iwlwifi 0000:00:14.3: Detected Intel(R) Wi-Fi 7 BE201 320MHz
[ 3.304490] asus_wmi: fan_curve_get_factory_default (0x00110024) failed: -19
[ 3.304717] iwlwifi 0000:00:14.3: TLV_FW_FSEQ_VERSION: FSEQ Version: 0.0.4.196
[ 3.305102] asus_wmi: fan_curve_get_factory_default (0x00110025) failed: -19
[ 3.305386] iwlwifi 0000:00:14.3: loaded firmware version 96.44729d4e.0 bz-b0-fm-c0-96.ucode op_mode iwlmvm
[ 3.305725] asus_wmi: fan_curve_get_factory_default (0x00110032) failed: -19
[ 3.306877] asus_wmi: using asus-wmi for asus::kbd_backlight
[ 3.320959] pps_core: LinuxPPS API ver. 1 registered
[ 3.320965] pps_core: Software ver. 5.3.6 - Copyright 2005-2007 Rodolfo Giometti giometti@linux.it
[ 3.324560] intel_rapl_common: Found RAPL domain package
[ 3.324563] intel_rapl_common: Found RAPL domain core
[ 3.324565] intel_rapl_common: Found RAPL domain dram
[ 3.327743] PTP clock support registered
[ 3.327949] spi-nor spi0.0: supply vcc not found, using dummy regulator
[ 3.328556] usb 3-5: Found UVC 1.10 device USB2.0 FHD UVC WebCam (3277:0060)
[ 3.332584] Creating 1 MTD partitions on “0000:00:1f.5”:
[ 3.332592] 0x000000000000-0x000002000000 : “BIOS”
[ 3.334526] usb 3-5: Found UVC 1.50 device USB2.0 FHD UVC WebCam (3277:0060)
[ 3.336922] usbcore: registered new interface driver uvcvideo
[ 3.345179] ACPI: battery: new hook: ASUS Battery Extension
[ 3.351899] Bluetooth: hci0: Waiting for firmware download to complete
[ 3.351903] Bluetooth: hci0: Firmware loaded in 52593 usecs
[ 3.351955] Bluetooth: hci0: Waiting for device to boot
[ 3.354023] Bluetooth: hci0: Device booted in 2065 usecs
[ 3.354026] Bluetooth: hci0: Waiting for device transition to d0
[ 3.354027] Bluetooth: hci0: Device moved to D0 in 0 usecs
[ 3.354290] Bluetooth: hci0: dsbr: enable: 0x01 value: 0x0b
[ 3.356515] Bluetooth: hci0: Found device firmware: intel/ibt-0190-0291-pci.sfi
[ 3.356524] Bluetooth: hci0: Boot Address: 0x10000800
[ 3.356524] Bluetooth: hci0: Firmware Version: 58-7.25
[ 3.374967] snd_hda_intel 0000:00:1f.3: Digital mics found on Skylake+ platform, using SOF driver
[ 3.505540] Console: switching to colour dummy device 80x25
[ 3.519631] xe 0000:00:02.0: vgaarb: deactivate vga console
[ 3.519829] xe 0000:00:02.0: [drm] Found lunarlake (device ID 64a0) integrated display version 20.00 stepping B0
[ 3.521933] xe 0000:00:02.0: [drm] Using GuC firmware from xe/lnl_guc_70.bin version 70.40.2
[ 3.541267] xe 0000:00:02.0: [drm] Using GuC firmware from xe/lnl_guc_70.bin version 70.40.2
[ 3.547928] xe 0000:00:02.0: [drm] Using HuC firmware from xe/lnl_huc.bin version 9.4.13
[ 3.550261] xe 0000:00:02.0: [drm] Using GSC firmware from xe/lnl_gsc_1.bin version 104.0.0.1263
[ 3.551402] mei_gsc_proxy 0000:00:16.0-0f73db04-97ab-4125-b893-e904ad0d5464: bound 0000:00:02.0 (ops xe_gsc_proxy_component_ops [xe])
[ 3.562872] sof-audio-pci-intel-lnl 0000:00:1f.3: enabling device (0000 → 0002)
[ 3.562993] sof-audio-pci-intel-lnl 0000:00:1f.3: DSP detected with PCI class/subclass/prog-if 0x040100
[ 3.574069] xe 0000:00:02.0: vgaarb: VGA decodes changed: olddecodes=io+mem,decodes=none:owns=io+mem
[ 3.587706] xe 0000:00:02.0: [drm] Finished loading DMC firmware i915/xe2lpd_dmc.bin (v2.28)
[ 3.851168] iwlwifi 0000:00:14.3: Detected RF FM, rfid=0x20112200
[ 3.851997] iwlwifi 0000:00:14.3: loaded PNVM version 8af7618d
[ 3.852036] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[ 3.909196] Bluetooth: hci0: Waiting for firmware download to complete
[ 3.909203] Bluetooth: hci0: Firmware loaded in 539732 usecs
[ 3.909292] Bluetooth: hci0: Waiting for device to boot
[ 3.945241] Bluetooth: hci0: Device booted in 35173 usecs
[ 3.945247] Bluetooth: hci0: Waiting for device transition to d0
[ 3.945350] Bluetooth: hci0: Device moved to D0 in 101 usecs
[ 3.945409] Bluetooth: hci0: RXQ: no new CD found
[ 3.945564] Bluetooth: hci0: Found Intel DDC parameters: intel/ibt-0190-0291-pci.ddc
[ 3.945749] Bluetooth: hci0: Applying Intel DDC parameters completed
[ 3.946794] Bluetooth: hci0: Firmware timestamp 2025.7 buildtype 1 build 82746
[ 3.946798] Bluetooth: hci0: Firmware SHA1: 0x9919f053
[ 3.947095] Bluetooth: hci0: Fseq status: Success (0x00)
[ 3.947097] Bluetooth: hci0: Fseq executed: 00.00.04.195
[ 3.947099] Bluetooth: hci0: Fseq BT Top: 00.00.04.195
[ 3.958950] iwlwifi 0000:00:14.3: base HW address: 88:f4:da:0a:0d:61
[ 3.966502] xe 0000:00:02.0: [drm] ccs1 fused off
[ 3.966506] xe 0000:00:02.0: [drm] ccs2 fused off
[ 3.966506] xe 0000:00:02.0: [drm] ccs3 fused off
[ 3.986828] xe 0000:00:02.0: [drm] vcs1 fused off
[ 3.986831] xe 0000:00:02.0: [drm] vcs2 fused off
[ 3.986832] xe 0000:00:02.0: [drm] vcs3 fused off
[ 3.986832] xe 0000:00:02.0: [drm] vcs4 fused off
[ 3.986833] xe 0000:00:02.0: [drm] vcs5 fused off
[ 3.986833] xe 0000:00:02.0: [drm] vcs6 fused off
[ 3.986834] xe 0000:00:02.0: [drm] vcs7 fused off
[ 3.986834] xe 0000:00:02.0: [drm] vecs1 fused off
[ 3.986835] xe 0000:00:02.0: [drm] vecs2 fused off
[ 3.986835] xe 0000:00:02.0: [drm] vecs3 fused off
[ 3.988834] Bluetooth: hci0: Failed to read codec capabilities (-95)
[ 3.989374] Bluetooth: hci0: Failed to read codec capabilities (-95)
[ 4.071359] [drm] Initialized xe 1.1.0 for 0000:00:02.0 on minor 0
[ 4.072011] ACPI: video: Video Device [GFX0] (multi-head: yes rom: no post: no)
[ 4.072149] input: Video Bus as /devices/LNXSYSTM:00/LNXSYBUS:00/PNP0A08:00/LNXVIDEO:00/input/input11
[ 4.083546] sof-audio-pci-intel-lnl 0000:00:1f.3: bound 0000:00:02.0 (ops i915_audio_component_bind_ops [xe])
[ 4.086689] fbcon: xedrmfb (fb0) is primary device
[ 4.090175] sof-audio-pci-intel-lnl 0000:00:1f.3: use msi interrupt mode
[ 4.112267] sof-audio-pci-intel-lnl 0000:00:1f.3: hda codecs found, mask 5
[ 4.112270] sof-audio-pci-intel-lnl 0000:00:1f.3: using HDA machine driver skl_hda_dsp_generic now
[ 4.112272] sof-audio-pci-intel-lnl 0000:00:1f.3: NHLT device BT(0) detected, ssp_mask 0x4
[ 4.112273] sof-audio-pci-intel-lnl 0000:00:1f.3: BT link detected in NHLT tables: 0x4
[ 4.112274] sof-audio-pci-intel-lnl 0000:00:1f.3: DMICs detected in NHLT tables: 2
[ 4.114241] sof-audio-pci-intel-lnl 0000:00:1f.3: Firmware paths/files for ipc type 1:
[ 4.114242] sof-audio-pci-intel-lnl 0000:00:1f.3: Firmware file: intel/sof-ipc4/lnl/sof-lnl.ri
[ 4.114243] sof-audio-pci-intel-lnl 0000:00:1f.3: Firmware lib path: intel/sof-ipc4-lib/lnl
[ 4.114243] sof-audio-pci-intel-lnl 0000:00:1f.3: Topology file: intel/sof-ipc4-tplg/sof-hda-generic-2ch.tplg
[ 4.114583] sof-audio-pci-intel-lnl 0000:00:1f.3: Loaded firmware library: ADSPFW, version: 2.12.0.1
[ 4.157316] xe 0000:00:02.0: [drm] GT1: found GSC cv104.1.0
[ 4.407822] sof-audio-pci-intel-lnl 0000:00:1f.3: Booted firmware version: 2.12.0.1
[ 4.419428] sof-audio-pci-intel-lnl 0000:00:1f.3: Topology: ABI 3:29:1 Kernel ABI 3:23:1
[ 4.419624] skl_hda_dsp_generic skl_hda_dsp_generic: ASoC: Parent card not yet available, widget card binding deferred
[ 4.420125] sof-audio-pci-intel-lnl 0000:00:1f.3: Loaded firmware library: ADSPFW, version: 2.12.0.1
[ 4.457169] snd_hda_codec_realtek ehdaudio0D0: autoconfig for ALC294: line_outs=1 (0x17/0x0/0x0/0x0/0x0) type:speaker
[ 4.457175] snd_hda_codec_realtek ehdaudio0D0: speaker_outs=0 (0x0/0x0/0x0/0x0/0x0)
[ 4.457177] snd_hda_codec_realtek ehdaudio0D0: hp_outs=1 (0x21/0x0/0x0/0x0/0x0)
[ 4.457179] snd_hda_codec_realtek ehdaudio0D0: mono: mono_out=0x0
[ 4.457180] snd_hda_codec_realtek ehdaudio0D0: inputs:
[ 4.899321] skl_hda_dsp_generic skl_hda_dsp_generic: hda_dsp_hdmi_build_controls: no PCM in topology for HDMI converter 3
[ 4.913623] input: sof-hda-dsp Headphone as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input12
[ 4.913702] input: sof-hda-dsp HDMI/DP,pcm=3 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input13
[ 4.913762] input: sof-hda-dsp HDMI/DP,pcm=4 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input14
[ 4.913818] input: sof-hda-dsp HDMI/DP,pcm=5 as /devices/pci0000:00/0000:00:1f.3/skl_hda_dsp_generic/sound/card0/input15
[ 5.284971] Console: switching to colour frame buffer device 240x75
[ 5.302608] xe 0000:00:02.0: [drm] fb0: xedrmfb frame buffer device
[ 6.187083] ish-hid {33AECD58-B679-4E54-9BD9-A04D34F0C226}: [hid-ish]: enum_devices_done OK, num_hid_devices=1
[ 6.189988] hid-generic 001F:8087:0AC2.0005: hidraw4: SENSOR HUB HID v2.00 Device [hid-ishtp 8087:0AC2] on
[ 6.196490] hid-sensor-hub 001F:8087:0AC2.0005: hidraw4: SENSOR HUB HID v2.00 Device [hid-ishtp 8087:0AC2] on
[ 11.737942] nvme nvme0: using unchecked data buffer
[ 14.140826] warning: `kdeconnectd’ uses wireless extensions which will stop working for Wi-Fi 7 hardware; use nl80211
[ 34.478046] iwlwifi 0000:00:14.3: RFIm is deactivated, reason = 4
[ 34.593033] iwlwifi 0000:00:14.3: Registered PHC clock: iwlwifi-PTP, with index: 0
[ 38.623193] wlan0: authenticate with 26:5a:4c:1a:35:ca (local address=88:f4:da:0a:0d:61)
[ 38.623632] wlan0: send auth to 26:5a:4c:1a:35:ca (try 1/3)
[ 38.740837] wlan0: authenticate with 26:5a:4c:1a:35:ca (local address=88:f4:da:0a:0d:61)
[ 38.740851] wlan0: send auth to 26:5a:4c:1a:35:ca (try 1/3)
[ 38.784685] wlan0: authenticated
[ 38.786547] wlan0: associate with 26:5a:4c:1a:35:ca (try 1/3)
[ 38.791456] wlan0: RX AssocResp from 26:5a:4c:1a:35:ca (capab=0x1011 status=0 aid=14)
[ 38.794330] wlan0: associated
[ 38.903891] wlan0: Limiting TX power to 36 (36 - 0) dBm as advertised by 26:5a:4c:1a:35:ca
[havok@laptop ~]$
im not sure where else to look to remediate this. any help is greatly appreciated!!
you did enable bluetooth correct? its not enabled out of the box
sudo systemctl enable --now bluetooth
well… that works now. but i still have to manually click on the radial switch for wifi when ever i open the lid…
not sure if this helps:
[havok@laptop ~]$ lspci -k
00:00.0 Host bridge: Intel Corporation Device 6400 (rev 04)
DeviceName: Onboard - Other
Subsystem: ASUSTeK Computer Inc. Device 10c4
libkmod: ERROR: kmod_config_parse: /etc/modprobe.d/blacklist.conf line 1: ignoring bad line starting with ‘sudo’
00:02.0 VGA compatible controller: Intel Corporation Lunar Lake [Intel Arc Graphics 130V / 140V] (rev 04)
DeviceName: Onboard - Video
Kernel driver in use: xe
Kernel modules: xe
00:04.0 Signal processing controller: Intel Corporation Device 641d (rev 04)
Kernel driver in use: proc_thermal_pci
Kernel modules: processor_thermal_device_pci
00:07.0 PCI bridge: Intel Corporation Lunar Lake-M Thunderbolt 4 PCI Express Root Port #0 (rev 10)
Kernel driver in use: pcieport
00:07.1 PCI bridge: Intel Corporation Lunar Lake-M Thunderbolt 4 PCI Express Root Port #1 (rev 10)
00:0a.0 Signal processing controller: Intel Corporation Device 647d (rev 04)
Kernel driver in use: intel_vsec
Kernel modules: intel_vsec
00:0b.0 Processing accelerators: Intel Corporation Lunar Lake NPU (rev 04)
Subsystem: ASUSTeK Computer Inc. Device 20bf
Kernel driver in use: intel_vpu
Kernel modules: intel_vpu
00:0d.0 USB controller: Intel Corporation Lunar Lake-M Thunderbolt 4 USB Controller (rev 10)
Subsystem: ASUSTeK Computer Inc. Device 201f
Kernel driver in use: xhci_hcd
00:0d.2 USB controller: Intel Corporation Lunar Lake-M Thunderbolt 4 NHI #0 (rev 10)
Kernel driver in use: thunderbolt
Kernel modules: thunderbolt
00:12.0 Serial controller: Intel Corporation Lunar Lake-M Integrated Sensor Hub (rev 10)
Kernel driver in use: intel_ish_ipc
Kernel modules: intel_ish_ipc
00:13.0 Communication controller: Intel Corporation Device a862 (rev 10)
00:14.0 USB controller: Intel Corporation Lunar Lake-M USB 3.2 Gen 2x1 xHCI Host Controller (rev 10)
00:14.2 RAM memory: Intel Corporation Device a87f (rev 10)
00:14.3 Network controller: Intel Corporation BE201 320MHz (rev 10)
DeviceName: Onboard - Ethernet
Subsystem: Intel Corporation Device 00e4
Kernel driver in use: iwlwifi
Kernel modules: iwlwifi
00:14.7 Bluetooth: Intel Corporation Device a876 (rev 10)
Subsystem: Intel Corporation Device 000e
Kernel driver in use: btintel_pcie
Kernel modules: btintel_pcie
00:15.0 Serial bus controller: Intel Corporation Lunar Lake-M Serial IO I2C Controller #0 (rev 10)
Kernel driver in use: intel-lpss
Kernel modules: intel_lpss_pci
00:15.1 Serial bus controller: Intel Corporation Lunar Lake-M Serial IO I2C Controller #1 (rev 10)
00:15.2 Serial bus controller: Intel Corporation Lunar Lake-M Serial IO I2C Controller #2 (rev 10)
00:15.3 Serial bus controller: Intel Corporation Lunar Lake-M Serial IO I2C Controller #3 (rev 10)
00:16.0 Communication controller: Intel Corporation Device a870 (rev 10)
Kernel driver in use: mei_me
Kernel modules: mei_me
00:19.0 Serial bus controller: Intel Corporation Device a850 (rev 10)
00:1c.0 PCI bridge: Intel Corporation Lunar Lake-M PCI Express Root Port #5 (rev 10)
00:1f.0 ISA bridge: Intel Corporation Device a807 (rev 10)
00:1f.3 Multimedia audio controller: Intel Corporation Lunar Lake-M HD Audio Controller (rev 10)
DeviceName: Onboard - Sound
Kernel driver in use: sof-audio-pci-intel-lnl
Kernel modules: snd_hda_intel, snd_sof_pci_intel_lnl
00:1f.4 SMBus: Intel Corporation Lunar Lake-M SMbus Controller (rev 10)
00:1f.5 Serial bus controller: Intel Corporation Lunar Lake-M SPI Controller (rev 10)
Kernel driver in use: intel-spi
Kernel modules: spi_intel_pci
55:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO
Subsystem: Samsung Electronics Co Ltd SSD 980 PRO
Kernel driver in use: nvme
Kernel modules: nvme
[havok@laptop ~]$
Since this is new its possible the Linux Kernel doesn’t have an exact driver for the WiFi for this model. You could try looking up some other drivers for it. I would make sure there isn’t anything in the bios that may turn it on or off during conditions.
also to help keep the thread readable for others in the future please post logs using eos-sendlog tool copy the url and paste the url here.
Can you show what is in this file.
cat /etc/modprobe.d/blacklist.conf | eos-sendlog
Post the url.
Edit: Are you also dual booting with Windows?
https://0x0.st/8VaM.txt
no, i removed the windows ssd before even booting to it. i opened up the laptop and swapped in a new ssd and installed linux immediatly after purchasing the laptop.
Not sure if you tried to edit that conf file with nano but you saved it with sudo nano in the line and there is nothing in the file that is blacklisted.
Contents of the file.
sudo nano /etc/modprobe.d/blacklist.conf
If you use nano you have to hit ctrl + o then enter to save and the ctrl + x to exit nano.
Edit: The empty file should only be /etc/modprobe.d/blacklist.conf and empty since there is nothing in it blacklisting anything.
Also did you check systemctl status bluetooth
Then run
modprobe btusb
systemctl restart bluetooth
Edit: Did you get bluetooth working but it stops working?
You may need to try disabling power save on the WiFi with
/etc/modprobe.d/iwlwifi.conf
add
options iwlwifi power_save=0
no issues with bluetooth now. just have to manually turn on wifi now…
made this change, no change in behavior, still have to manually turn on wifi
removed the line from blacklist.conf file. Still no change in behavior.
Not sure why you would have to turn on WiFi manually? Are you using Kde plasma? Right click on Network icon and configure network connections. Click on the WiFi entry and check if set to connect automatically in the general tab.
yes using KDE, yes connect automatically is enabled. its as if the wireless card starts up as disabled
Check the Arch Wiki for potential workarounds.
But more importantly: are you using asusctl already ?
It also helps sometimes just to search on github for gists or even specific repositories, just by searching for the specific model number of your laptop. In this case, check on the asusctl gitlab site for similiar issues for your model.
Not sure why that would be. If it’s turned on it should automatically connect even if you were using Ethernet as long as it is checked in NetworkManager.
