hey im having issues with a vpn and connecting etc its private closed source vpn
but i have the source code
please do not run this stuff outside a vm!!! i don’t trust it
from what i can tell it uses pptp on port 3000 with a username and password
ill share a link to it on a google drive so anyone that know about this can help.
i have been struggling for a few weeks. any help would mean the word to me
i will take a day to respond at min im really busy with work and coding etc
I’m not sure you should share these docs here. The Installation Guide states: “No part of this manual may be reproduced or transmitted in any form or by any means without prior written
consent of New H3C Technologies Co., Ltd.”
Just trying to help prevent problems for you.
i can send it. we have premission its chill.
we are working with them.
currently i want to connect with my machine into env but i cant using the vpn they provide.
also they have a .deb if needed
thx this helps alot. now i can work from home with it do you know one for kali linuxits ok if you dont
I Do pen-testing but when install this on kali it wont work but works on a different kali vm then not on another vm i installed kali on hardware and it does not work on hardware for some weird reason
I just found that with a web search. I don’t see a guide specifically for Kali, but Kali is Debian if I recall correctly, so I would think the documentation you posted earlier should cover that, as it says that Debian is supported.
yeah your right with kali being debian but there version is debian 10 kali uses like debian 13 and i think there is package versioning issues
Sorry, I’m not familiar with Kali nor this software. You say it does work on one Kali VM, though? Well, that’s promising. I wish you luck.
its fine thx for the article i might be able to do that steps on my machine. i read through that article i agree with them on most points i tested h3c they have 31 vulnerabilities in there servers they run centos 7 on most things and just change os release to say h3clinux
