1. Problem
I’ve been working on trying to get the SSH agent running and the keys added to the agent using systemd units. However, I can’t get the SSH keys added to the agent after login. Ideally, I’d also like to define all required environmental variables within the systemd units, but I can’t seem to do the for $SSH_AUTH_SOCK.
So far I have the following:
2. Environmental variables
ssh-askpass.sh
cat /etc/profile.d/ssh-askpass.sh
#!/bin/sh
export SSH_ASKPASS=/usr/bin/ksshaskpass
.zshenv
I’ve set the following variable in my ~/.zshenv file, as I couldn’t get it to work when it was set as Environment=SSH_AUTH_SOCK="$XDG_RUNTIME_DIR"/ssh-agent.socket in the [Service] section of the ssh-agent.service systemd unit:
cat ~/.zshenv
# [... TRUNCATED ...]
### SSH Auth Sock ###
export SSH_AUTH_SOCK="$XDG_RUNTIME_DIR"/ssh-agent.socket
3. Systemd units
ssh-agent.service
cat ~/.config/systemd/user/ssh-agent.service
[Unit]
Description=SSH key agent
[Service]
Type=simple
Environment=SSH_AUTH_SOCK=%t/ssh-agent.socket
# DISPLAY required for ssh-askpass to work
Environment=DISPLAY=:0
ExecStart=/usr/bin/ssh-agent -D -a $SSH_AUTH_SOCK
[Install]
WantedBy=default.target
ssh-add.service
cat ~/.config/systemd/user/ssh-add.service
[Unit]
Description=Add private key identities to the SSH agent
PartOf=ssh-agent.service
After=ssh-agent.service
[Service]
Type=oneshot
ExecStart=/home/benjamin/.local/bin/systemd-ssh-add after
[Install]
WantedBy=ssh-agent.service
4. Scripts
systemd-ssh-add
My homebrewed script to add SSH keys to the agent is as follows:
cat ~/.local/bin/systemd-ssh-add
#!/bin/sh
### Find Keys ###
DIR_SSH="${HOME}"/.ssh
[[ ! -d "$DIR_SSH" ]] && exit 1
KEYS=$(
    grep -zlP \
        --exclude="authorized_keys*" \
        --exclude="config*" \
        --exclude="known_hosts*" \
        --exclude="*.pub" \
        '-----BEGIN OPENSSH PRIVATE KEY-----(.*\n.*){1,}-----END OPENSSH PRIVATE KEY-----' \
        "$DIR_SSH"/*
### Add Keys to Agent ###
[[ ! -n "$KEYS" ]] && exit 1
ssh-add -q $KEYS < /dev/null
exit 0
5. Output
systemctl --user status ... output
The ssh-agent.service launches and runs without error:
systemctl --user status ssh-agent.service
● ssh-agent.service - SSH key agent
     Loaded: loaded (/home/benjamin/.config/systemd/user/ssh-agent.service; enabled; vendor preset: enabled)
     Active: active (running) since Mon 2021-08-23 18:00:00 BST; 1min 24s ago
   Main PID: 1171 (ssh-agent)
      Tasks: 1 (limit: 4307)
     Memory: 904.0K
        CPU: 13ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/app.slice/ssh-agent.service
             └─1171 /usr/bin/ssh-agent -D -a /run/user/1000/ssh-agent.socket
Aug 23 18:00:00 Scatha systemd[1164]: Started SSH key agent.
Aug 23 18:00:00 Scatha ssh-agent[1171]: SSH_AUTH_SOCK=/run/user/1000/ssh-agent.socket; export SSH_AUTH_SOCK;
Aug 23 18:00:00 Scatha ssh-agent[1171]: echo Agent pid 1171;
However, the ssh-add.service throws errors that appear to indicate that it’s running before the ssh-agent.service is ready:
systemctl --user status ssh-add.service
○ ssh-add.service - Add private key identities to the SSH agent
     Loaded: loaded (/home/benjamin/.config/systemd/user/ssh-add.service; enabled; vendor preset: enabled)
     Active: inactive (dead) since Mon 2021-08-23 18:00:00 BST; 1min 24s ago
   Main PID: 1172 (code=exited, status=0/SUCCESS)
        CPU: 42ms
Aug 23 18:00:00 Scatha systemd[1164]: Starting Add private key identities to the SSH agent...
Aug 23 18:00:00 Scatha systemd-ssh-add[1176]: Could not open a connection to your authentication agent.
Aug 23 18:00:00 Scatha systemd[1164]: Finished Add private key identities to the SSH agent.
If I run systemctl --user start ssh-add.service after login, the process runs as intended, albeit, while taking over 8s to add six keys to the agent:
     Active: inactive (dead) since Mon 2021-08-23 18:04:07 BST; 5s ago
    Process: 2329 ExecStart=/home/benjamin/.local/bin/systemd-ssh-add after (code=exited, status=0/SUCCESS)
   Main PID: 2329 (code=exited, status=0/SUCCESS)
        CPU: 8.538s
Aug 23 18:03:58 Scatha systemd[1164]: Starting Add private key identities to the SSH agent...
Aug 23 18:04:07 Scatha systemd[1164]: Finished Add private key identities to the SSH agent.
Aug 23 18:04:07 Scatha systemd[1164]: ssh-add.service: Consumed 8.538s CPU time.
6. Misc
printenv | grep -i 'ssh'
pgrep -a 'ssh'
835 sshd: /usr/bin/sshd -D [listener] 0 of 10-100 startups
1170 /usr/bin/ssh-agent -D -a /run/user/1000/ssh-agent.socket
pacman -Qs kwallet
local/ksshaskpass 5.22.4-1 (plasma)
    ssh-add helper that uses kwallet and kpassworddialog
local/kwallet 5.85.0-1 (kf5)
    Secure and unified container for user passwords
local/kwallet-pam 5.22.4-1 (plasma)
    KWallet PAM integration
local/kwalletmanager 21.08.0-1 (kde-applications kde-utilities)
    Wallet management tool
local/signon-kwallet-extension 21.08.0-1 (kde-applications kde-network)
    KWallet integration for signon framework
