Hi All!
Been a while since I have been on here. I am guessing a year or two ago at this point. My old laptop, an ASUS ROG GL752VW I purchased at Costco, started to have issues (keyboard buttons started not working unless pushed hard, the SSD started failing, and the battery was giving out). I was getting into music production, and since I felt I spent more time trying to get sound to work than I spent making music, I ended up purchasing a Macbook Pro M1. Its been a great computer and the battery life is amazing.
I will be passing the Macbook to someone else in the household, and will need another laptop. I was highly considering getting another M1 Macbook, but I think my old laptop will work perfectly fine with a few repairs and it will save a lot of money.
It looks like I will need to replace the following components. I need help choosing the best ones as I am not up to date on hardware at all. I’m looking for the best overall value (performance for dollars) not just the fastest overall. I’m not sure what the limitations are of the hardware so don’t want to purchase something that has faster speeds than the system can even run (but would be okay purchasing something that was backwards compatible that I could put in a newer system in a couple of years).
M.2 drive- This works, but is only 128GB. Would like to upgrade to 1TB
SSD drive- Is this even worth replacing? If I upgrade the M.2 drive to 1 TB, that should be more than I need. Will it cause errors if I leave the slot empty?
Ram- I have 16GB and seems to be fine. Would it be worth upgrading to 32GB or faster speed…if it can handle it?
Updated wifi card- I believe the current one is 802.11 AC
Keyboard and battery- Not a lot of options here, but please recommend if you know of something better than what is offered on Amazon
Really appreciate everyone’s help. Excited to get this thing up and running again!
