hi, i am having a problem to install parsec-bin, seems to be an issue with the sha256sums, i can install it by running:
yay -S --mflags --skipinteg parsec-bin
but is this secure ? maybe installing it with flatpak would be a better option ?
Curious why you don’t just do yay -S parsec-bin
i tried the package fails to install with that command
The sha256sum listed in the package built doesn’t match the current sha256sum so that’s probably why it’s failing. Once yay clones the repo you can probably update the PKGBUILD with the new sha256sum of the new debian package and it will work.
I tried it myself and it builds correctly after you update the sha256sum to the new one of the new package. The new correct sha256sum is this.
f45e7abbe8d88f60829616e71a52e2eb91714b556ad34728c70bbb9a3553635c
hi how do i update the sha256sum with yay ?
Download the PKGBUILD for parsec-bin in some directory.
Open a terminal in that directory and run:
updpkgsums
This would download the latest .deb file from which the package is built and update the sha256sum in the PKGBUILD file accordingly.
then run:
makepkg -si
to build and install the package.
Nice it worked, just ran the commands from this directory:
/home/ramon/.cache/yay/parsec-bin/
Same result different solution.
