Hello im new in linux i don’t know almost nothing i need help to fix this pls
[saibot@SpiKenDouh ~]$ update
[sudo] password for saibot:
:: Synchronizing package databases…
core 137.6 KiB 202 KiB/s 00:01 [----------------------------------------------------------] 100%
extra 1564.7 KiB 553 KiB/s 00:03 [----------------------------------------------------------] 100%
community 5.9 MiB 660 KiB/s 00:09 [----------------------------------------------------------] 100%
multilib 150.3 KiB 188 KiB/s 00:01 [----------------------------------------------------------] 100%
endeavouros 23.7 KiB 37.1 KiB/s 00:01 [----------------------------------------------------------] 100%
error: failed retrieving file ‘community.db’ from archmirror.it : The requested URL returned error: 403
error: failed retrieving file ‘core.db’ from archmirror.it : The requested URL returned error: 403
error: failed retrieving file ‘extra.db’ from archmirror.it : The requested URL returned error: 403
warning: too many errors from archmirror.it, skipping for the remainder of this transaction
error: failed retrieving file ‘multilib.db’ from archmirror.it : The requested URL returned error: 403
If your Internet connection is alright, you could try launching the Welcome app and refresh your mirrors.
After that: sudo pacman -Syyu
Hopefully it will resolve the issue.
this is an issue with the mirror indeed… it says you do not have permission … so rerank mirrors will fix it.
You should do that from time to time.
