HELP PLEASE! im on i3 and i cant boot into bios! [ NOT SOLVED ]
Do you have a link to the thread? Or a title, I see tons of threads with the word key in it
I’m looking now because I could give you the command but I want to make sure I have it correct.
Try this as I can’t find the link.
sudo pacman -Sy endeavouros-keyring
Edit: Then run
sudo pacman -Syu
EndeavourOS keyring updated, users should update soon This one?
seems to have did something as there were no errors
Now run
sudo pacman -Syu
its 100% doing way more
Wait until it completes. If it is successful you’ll need to reboot.
yeah it wants me to reboot right now
do i reboot?
Of course!
alright
anything else i should do?
Does it boot up properly now?
same as last time from the looks of it. Should i see if bios boots?
the whole time ive had it the boot looks the same. The only problem is the bios does not work ( ive not tried to see if the bios works on the new update )
Try and see.
Nope, I tried to see on boot if i could press esc and it would show something but it just black screened. same with bios. If i leave it and dont touch it when i press power to turn it on, It will boot up just fine though
f2 or del are the keys listed to get to the BIOS btw.
On Asus z590 motherboards you use F2 or Del to access bios. Turn off the computer hold F2 and power on. Don’t let go off F2 until bios shows
Yep i pressed one of the first try and one on the other
ill hold it. I was spam pressing, Ill be back one sec
