Hello. I’m trying to fix my old problem. I bought an ASUS PCE-AX300 PCI-E WiFi card, I installed it into my PC, and Wi-Fi doesn’t work for some reason. But what’s strange is that lspci shows NOTHING about that card, while lsusb makes the bluetooth part appear (if unplug bluetooth usb cable/unplug entire card- it disappears)
Do you have another PCI-e slot you can try it in?
I got also a asus ax3000 card…I believe xd
Had one time hibernation after hibernation it didn’t wake up. Reboot didn’t help. I poweroff the machine after some sec turn on and it worked again
Most likely something was wrong with PCI-E conversion circuit board as it had scratches on some contacts, took out the M2 chip on the board and plugged it into M2 WiFi port on my motherboard- Wi-Fi started to work.
