Help needed with audio settings pulse / pipewire
Hi I hope I can find someone who can help me with my audio issue.
On boot up I can’t start anything with audio, for example strawberry won’t play or videos in Firefox won’t start. I have to go to the audio settings select a different profile for my sound card then switch to the one I used to use, then I would have audio playback for a random amount of time until i have to do the same thing again.
How did I get there?
I couldn’t find the option to boost my Mic, but remembered from my earlier linux experiences that pulse had that option. So I installed pulse using octopi, everything was good, but after rebooting I encountered the issue I am having now. So I thought Pulse was to blame and deleted it again trough octopi. Now I had no audio and no audio settings.
I reinstalled Pulse (and all recommended packages) and now I am here.
I am using Plasma as my Desktop environment my sound card is a creative sound blaster z-series connected to a PCIe slot.
inxi -Fza:
  Kernel: 6.12.17-1-lts arch: x86_64 bits: 64 compiler: gcc v: 14.2.1
    clocksource: tsc avail: hpet,acpi_pm
    parameters: BOOT_IMAGE=/boot/vmlinuz-linux-lts
    root=UUID=6dab932d-dd67-4b94-99cd-3917131f813f rw nowatchdog
    nvme_load=YES nvidia_drm.modeset=1 loglevel=3
  Desktop: KDE Plasma v: 6.3.2 tk: Qt v: N/A info: frameworks v: 6.11.0
    wm: kwin_wayland vt: 1 dm: SDDM Distro: EndeavourOS base: Arch Linux
  Type: Desktop Mobo: ASUSTeK model: Z170 PRO GAMING/AURA v: Rev X.0x
    serial: <superuser required> part-nu: SKU uuid: <superuser required>
    UEFI-[Legacy]: American Megatrends v: 3805 date: 05/16/2018
  Info: model: Intel Core i7-7700K bits: 64 type: MT MCP arch: Kaby Lake
    gen: core 7 level: v3 note: check built: 2018 process: Intel 14nm family: 6
    model-id: 0x9E (158) stepping: 9 microcode: 0xF8
  Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
    smt: enabled cache: L1: 256 KiB desc: d-4x32 KiB; i-4x32 KiB L2: 1024 KiB
    desc: 4x256 KiB L3: 8 MiB desc: 1x8 MiB
  Speed (MHz): avg: 4403 min/max: 800/4500 scaling: driver: intel_pstate
    governor: powersave cores: 1: 4403 2: 4403 3: 4403 4: 4403 5: 4403 6: 4403
    7: 4403 8: 4403 bogomips: 67224
  Vulnerabilities:
  Type: gather_data_sampling mitigation: Microcode
  Type: itlb_multihit status: KVM: Split huge pages
  Type: l1tf mitigation: PTE Inversion; VMX: conditional cache flushes, SMT
    vulnerable
  Type: mmio_stale_data mitigation: Clear CPU buffers; SMT vulnerable
  Type: reg_file_data_sampling status: Not affected
  Type: retbleed mitigation: IBRS
  Type: spec_rstack_overflow status: Not affected
    prctl
    sanitization
  Type: spectre_v2 mitigation: IBRS; IBPB: conditional; STIBP: conditional;
    RSB filling; PBRSB-eIBRS: Not affected; BHI: Not affected
  Type: tsx_async_abort mitigation: TSX disabled
  Device-1: NVIDIA GP102 [GeForce GTX 1080 Ti] vendor: ASUSTeK driver: nvidia
    v: 570.124.04 alternate: nouveau,nvidia_drm non-free: 550/565.xx+
    status: current (as of 2025-01; EOL~2026-12-xx) arch: Pascal code: GP10x
    process: TSMC 16nm built: 2016-2021 pcie: gen: 3 speed: 8 GT/s lanes: 16
    ports: active: none off: DP-1,DP-2 empty: DVI-D-1,HDMI-A-1,HDMI-A-2
    bus-ID: 01:00.0 chip-ID: 10de:1b06 class-ID: 0300
  Display: wayland server: X.org v: 1.21.1.16 with: Xwayland v: 24.1.6
    compositor: kwin_wayland driver: X: loaded: nvidia unloaded: modesetting
    alternate: fbdev,nouveau,nv,vesa gpu: nvidia,nvidia-nvswitch
    d-rect: 3840x1080 display-ID: 0
  Monitor-1: DP-1 pos: primary,left model: Samsung S27E650 serial: <filter>
    built: 2015 res: mode: 1920x1080 hz: 60 scale: 100% (1) dpi: 82 gamma: 1.2
    size: 598x336mm (23.54x13.23") diag: 686mm (27") ratio: 16:9 modes:
    max: 1920x1080 min: 640x480
  Monitor-2: DP-2 pos: right model: Idek Iiyama PL2770H serial: <filter>
    built: 2022 res: mode: 1920x1080 hz: 165 scale: 100% (1) dpi: 82 gamma: 1.2
  API: EGL v: 1.5 hw: drv: nvidia platforms: device: 0 drv: nvidia gbm:
    drv: nvidia surfaceless: drv: nvidia wayland: drv: nvidia x11: drv: nvidia
  API: OpenGL v: 4.6.0 vendor: nvidia v: 570.124.04 glx-v: 1.4
    direct-render: yes renderer: NVIDIA GeForce GTX 1080 Ti/PCIe/SSE2
    memory: 10.74 GiB display-ID: :1.0
  API: Vulkan v: 1.4.304 layers: 5 device: 0 type: discrete-gpu name: NVIDIA
    GeForce GTX 1080 Ti driver: N/A device-ID: 10de:1b06
    surfaces: xcb,xlib,wayland
    de: kscreen-console,kscreen-doctor gpu: nvidia-smi wl: wayland-info
    x11: xdpyinfo, xprop, xrandr
  Device-1: Intel 100 Series/C230 Series Family HD Audio vendor: ASUSTeK
    driver: snd_hda_intel v: kernel alternate: snd_soc_avs bus-ID: 00:1f.3
    chip-ID: 8086:a170 class-ID: 0403
  Device-2: NVIDIA GP102 HDMI Audio vendor: ASUSTeK driver: snd_hda_intel
    v: kernel pcie: gen: 3 speed: 8 GT/s lanes: 16 bus-ID: 01:00.1
    chip-ID: 10de:10ef class-ID: 0403
  Device-3: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D /
    Z-Series BlasterX AE-5 Plus] driver: snd_hda_intel v: kernel pcie: gen: 1
    speed: 2.5 GT/s lanes: 1 bus-ID: 03:00.0 chip-ID: 1102:0012 class-ID: 0403
  API: ALSA v: k6.12.17-1-lts status: kernel-api
  Server-1: PipeWire v: 1.2.7 status: active with: 1: wireplumber
    status: active 2: pipewire-alsa type: plugin 3: pw-jack type: plugin
    tools: pw-cat,pw-cli,wpctl
  Server-2: PulseAudio v: 17.0-43-g3e2bb status: active with:
    1: pulseaudio-alsa type: plugin 2: pulseaudio-jack type: module
    tools: pacat,pactl,pavucontrol,pulsemixer
  Device-1: Intel Ethernet I219-V vendor: ASUSTeK driver: e1000e v: kernel
    port: N/A bus-ID: 00:1f.6 chip-ID: 8086:15b8 class-ID: 0200
  IF: enp0s31f6 state: up speed: 100 Mbps duplex: full mac: <filter>
  Info: services: NetworkManager,systemd-timesyncd
  Local Storage: total: 5.69 TiB used: 555.39 GiB (9.5%)
  ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Samsung model: SSD 980 PRO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 63.2 Gb/s
    lanes: 4 tech: SSD serial: <filter> fw-rev: 1B2QGXA7 temp: 35.9 C
    scheme: MBR
  ID-2: /dev/sda maj-min: 8:0 vendor: Samsung model: SSD 850 PRO 256GB
    size: 238.47 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: GPT
  ID-3: /dev/sdb maj-min: 8:16 vendor: Samsung model: SSD 850 EVO 500GB
    size: 465.76 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 2B6Q scheme: MBR
  ID-4: /dev/sdc maj-min: 8:32 vendor: Western Digital
    model: WD20EURS-63S48Y0 size: 1.82 TiB block-size: physical: 4096 B
    logical: 512 B speed: 3.0 Gb/s tech: N/A serial: <filter> fw-rev: AB51
    scheme: GPT
  ID-5: /dev/sdd maj-min: 8:48 vendor: Seagate model: FireCuda SE SSD
    ZA2000GM10011 size: 1.82 TiB block-size: physical: 512 B logical: 512 B
    speed: 6.0 Gb/s tech: SSD serial: <filter> fw-rev: D013 scheme: GPT
  ID-6: /dev/sde maj-min: 8:64 vendor: Samsung model: SSD 860 EVO 1TB
    size: 931.51 GiB block-size: physical: 512 B logical: 512 B speed: 6.0 Gb/s
    tech: SSD serial: <filter> fw-rev: 4B6Q scheme: GPT
  ID-1: / raw-size: 465.76 GiB size: 457.38 GiB (98.20%)
    used: 300.41 GiB (65.7%) fs: ext4 dev: /dev/nvme0n1p1 maj-min: 259:1
  System Temperatures: cpu: 42.0 C mobo: N/A
  Fan Speeds (rpm): N/A
  Memory: total: 64 GiB note: est. available: 62.74 GiB used: 5.5 GiB (8.8%)
  Processes: 276 Power: uptime: 5h 36m states: freeze,mem,disk suspend: deep
    avail: s2idle wakeups: 0 hibernate: platform avail: shutdown, reboot,
    suspend, test_resume image: 25.03 GiB services: org_kde_powerdevil,
    power-profiles-daemon, upowerd Init: systemd v: 257 default: graphical
    tool: systemctl
  Packages: pm: pacman pkgs: 1287 libs: 383 tools: octopi,yay Compilers:
    gcc: 14.2.1 Shell: Bash v: 5.2.37 running-in: konsole inxi: 3.3.37
lspci -k
00:00.0 Host bridge: Intel Corporation Xeon E3-1200 v6/7th Gen Core Processor Host Bridge/DRAM Registers (rev 05)
        Subsystem: ASUSTeK Computer Inc. Device 8694
        Kernel driver in use: skl_uncore
00:01.0 PCI bridge: Intel Corporation 6th-10th Gen Core Processor PCIe Controller (x16) (rev 05)
        Kernel driver in use: pcieport
00:14.0 USB controller: Intel Corporation 100 Series/C230 Series Chipset Family USB 3.0 xHCI Controller (rev 31)
        Subsystem: ASUSTeK Computer Inc. H110I-PLUS Motherboard
        Kernel driver in use: xhci_hcd
00:16.0 Communication controller: Intel Corporation 100 Series/C230 Series Chipset Family MEI Controller #1 (rev 31)
        Kernel driver in use: mei_me
        Kernel modules: mei_me
00:17.0 SATA controller: Intel Corporation Q170/Q150/B150/H170/H110/Z170/CM236 Chipset SATA Controller [AHCI Mode] (rev 31)
        Kernel driver in use: ahci
00:1b.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #17 (rev f1)
00:1b.2 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #19 (rev f1)
00:1c.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #1 (rev f1)
00:1d.0 PCI bridge: Intel Corporation 100 Series/C230 Series Chipset Family PCI Express Root Port #9 (rev f1)
00:1f.0 ISA bridge: Intel Corporation Z170 Chipset LPC/eSPI Controller (rev 31)
00:1f.2 Memory controller: Intel Corporation 100 Series/C230 Series Chipset Family Power Management Controller (rev 31)
00:1f.3 Audio device: Intel Corporation 100 Series/C230 Series Chipset Family HD Audio Controller (rev 31)
        Subsystem: ASUSTeK Computer Inc. Device 86ae
        Kernel driver in use: snd_hda_intel
        Kernel modules: snd_hda_intel, snd_soc_avs
00:1f.4 SMBus: Intel Corporation 100 Series/C230 Series Chipset Family SMBus (rev 31)
        Kernel driver in use: i801_smbus
        Kernel modules: i2c_i801
00:1f.6 Ethernet controller: Intel Corporation Ethernet Connection (2) I219-V (rev 31)
        Subsystem: ASUSTeK Computer Inc. Device 8672
        Kernel driver in use: e1000e
        Kernel modules: e1000e
01:00.0 VGA compatible controller: NVIDIA Corporation GP102 [GeForce GTX 1080 Ti] (rev a1)
        Subsystem: ASUSTeK Computer Inc. Device 85f1
        Kernel driver in use: nvidia
        Kernel modules: nouveau, nvidia_drm, nvidia
01:00.1 Audio device: NVIDIA Corporation GP102 HDMI Audio Controller (rev a1)
03:00.0 Audio device: Creative Labs CA0132 Sound Core3D [Sound Blaster Recon3D / Z-Series / Sound BlasterX AE-5 Plus] (rev 01)
        Subsystem: Creative Labs SB1570 SB Audigy Fx
04:00.0 USB controller: ASMedia Technology Inc. ASM1142 USB 3.1 Host Controller
        Subsystem: ASUSTeK Computer Inc. Device 8675
05:00.0 Non-Volatile memory controller: Samsung Electronics Co Ltd NVMe SSD Controller PM9A1/PM9A3/980PRO
        Subsystem: Samsung Electronics Co Ltd SSD 980 PRO
        Kernel driver in use: nvme
        Kernel modules: nvme
systemctl --user status pipewire
pipewire.service - PipeWire Multimedia Service
     Loaded: loaded (/usr/lib/systemd/user/pipewire.service; disabled; preset: enabled)
     Active: active (running) since Mon 2025-03-17 08:21:30 CET; 5h 38min ago
 Invocation: 784aef5b78a64ca2b39cc042e73d16c3
TriggeredBy: ● pipewire.socket
   Main PID: 829 (pipewire)
      Tasks: 3 (limit: 76900)
     Memory: 10.1M (peak: 11.6M)
        CPU: 466ms
     CGroup: /user.slice/user-1000.slice/user@1000.service/session.slice/pipewire.service
             └─829 /usr/bin/pipewire
Mär 17 08:21:30 Kriegsspielliebesautomat systemd[713]: Started PipeWire Multimedia Service.
This wiki page for EndeavourOS helps you to set up pipewire correctly:
https://discovery.endeavouros.com/audio/pipewire/2021/09/
Thank you very much, I followed the steps and most things are fixed now. The only thing I miss is the Icon in the System Tray.
Maybe you need to do this. Right click on your panel. Show Panel Configuration. Add or Manage Widgets. Search for audio. Click on that widget to add it to your panel.
I was looking in widgets and System Tray settings it is no where to be found.
Try this package: sudo pacman -Syu plasma-pa
Thanks a lot, everything is back to normal.
Would you mind to tell me what it did? was it an update/upgrade of the whole system?
Yes, it updates the system and installs the package plasma-pa.
On Archlinux, you need to update your system before installing any single package.
You need always try to avoid partial upgrade situation.
https://wiki.archlinux.org/title/System_maintenance#Partial_upgrades_are_unsupported
