Help! Missing Qt Libraries
Hello, recently my laptop crashed when I was updating, and forced to restart.
Now everytime I use pacman or yay to update something I get the following:
ldconfig: File /usr/lib/libQt6Widgets.so is empty, not checked.
ldconfig: File /usr/lib/libQt6EglFSDeviceIntegration.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6XcbQpa.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6EglFsKmsGbmSupport.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Network.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Widgets.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Xml.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6DBus.so is empty, not checked.
ldconfig: File /usr/lib/libQt6OpenGL.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Test.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6EglFSDeviceIntegration.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6DBus.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6EglFsKmsSupport.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Concurrent.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Xml.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6PrintSupport.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Concurrent.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Xml.so is empty, not checked.
ldconfig: File /usr/lib/libQt6EglFsKmsGbmSupport.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Sql.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Core.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Gui.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6EglFsKmsSupport.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6EglFSDeviceIntegration.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Network.so is empty, not checked.
ldconfig: File /usr/lib/libQt6PrintSupport.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6EglFsKmsSupport.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Core.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6PrintSupport.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6OpenGLWidgets.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6OpenGLWidgets.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Test.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Test.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6XcbQpa.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Widgets.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Core.so is empty, not checked.
ldconfig: File /usr/lib/libQt6DBus.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Network.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6OpenGL.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Gui.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6Sql.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6Concurrent.so.6.7.0 is empty, not checked.
ldconfig: File /usr/lib/libQt6OpenGL.so.6 is empty, not checked.
ldconfig: File /usr/lib/libQt6EglFsKmsGbmSupport.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Sql.so is empty, not checked.
ldconfig: File /usr/lib/libQt6OpenGLWidgets.so is empty, not checked.
ldconfig: File /usr/lib/libQt6Gui.so is empty, not checked.
ldconfig: File /usr/lib/libQt6XcbQpa.so is empty, not checked.
(1/2) Arming ConditionNeedsUpdate...
(2/2) Checking which packages need to be rebuilt
Use pacman -Qo to find out what packages own those files and then reinstall them.
Your issue was mostly likely caused by the issues with the nvidia drivers
For example:
$ pacman -Qo /usr/lib/libQt6XcbQpa.so
/usr/lib/libQt6XcbQpa.so is owned by qt6-base 6.7.0-6
So at least reinstall qt6-base and try again.
Thanks for replying, I made a script for it:
files=(
"/usr/lib/libQt6Widgets.so",
"/usr/lib/libQt6EglFSDeviceIntegration.so.6",
"/usr/lib/libQt6XcbQpa.so.6.7.0",
"/usr/lib/libQt6EglFsKmsGbmSupport.so.6",
"/usr/lib/libQt6Network.so.6.7.0",
"/usr/lib/libQt6Widgets.so.6",
"/usr/lib/libQt6Xml.so.6.7.0",
"/usr/lib/libQt6DBus.so",
"/usr/lib/libQt6OpenGL.so.6.7.0",
"/usr/lib/libQt6Test.so.6",
"/usr/lib/libQt6EglFSDeviceIntegration.so.6.7.0",
"/usr/lib/libQt6DBus.so.6.7.0",
"/usr/lib/libQt6EglFsKmsSupport.so",
"/usr/lib/libQt6Concurrent.so.6",
"/usr/lib/libQt6Xml.so.6",
"/usr/lib/libQt6PrintSupport.so",
"/usr/lib/libQt6Concurrent.so",
"/usr/lib/libQt6Xml.so",
"/usr/lib/libQt6EglFsKmsGbmSupport.so.6.7.0",
"/usr/lib/libQt6Sql.so.6.7.0",
"/usr/lib/libQt6Core.so.6.7.0",
"/usr/lib/libQt6Gui.so.6",
"/usr/lib/libQt6EglFsKmsSupport.so.6",
"/usr/lib/libQt6EglFSDeviceIntegration.so",
"/usr/lib/libQt6Network.so",
"/usr/lib/libQt6PrintSupport.so.6.7.0",
"/usr/lib/libQt6EglFsKmsSupport.so.6.7.0",
"/usr/lib/libQt6Core.so.6",
"/usr/lib/libQt6PrintSupport.so.6",
"/usr/lib/libQt6OpenGLWidgets.so.6.7.0",
"/usr/lib/libQt6OpenGLWidgets.so.6",
"/usr/lib/libQt6Test.so",
"/usr/lib/libQt6Test.so.6.7.0",
"/usr/lib/libQt6XcbQpa.so.6",
"/usr/lib/libQt6Widgets.so.6.7.0",
"/usr/lib/libQt6Core.so",
"/usr/lib/libQt6DBus.so.6",
"/usr/lib/libQt6Network.so.6",
"/usr/lib/libQt6OpenGL.so",
"/usr/lib/libQt6Gui.so.6.7.0",
"/usr/lib/libQt6Sql.so.6",
"/usr/lib/libQt6Concurrent.so.6.7.0",
"/usr/lib/libQt6OpenGL.so.6",
"/usr/lib/libQt6EglFsKmsGbmSupport.so",
"/usr/lib/libQt6Sql.so",
"/usr/lib/libQt6OpenGLWidgets.so",
"/usr/lib/libQt6Gui.so",
"/usr/lib/libQt6XcbQpa.so"
for filename in "${files[@]}"; do
  pacman -Qo "$filename"
done
But neither of them are owned:
error: No package owns /usr/lib/libQt6Widgets.so,
error: No package owns /usr/lib/libQt6EglFSDeviceIntegration.so.6,
error: No package owns /usr/lib/libQt6XcbQpa.so.6.7.0,
error: No package owns /usr/lib/libQt6EglFsKmsGbmSupport.so.6,
error: No package owns /usr/lib/libQt6Network.so.6.7.0,
error: No package owns /usr/lib/libQt6Widgets.so.6,
error: No package owns /usr/lib/libQt6Xml.so.6.7.0,
error: No package owns /usr/lib/libQt6DBus.so,
error: No package owns /usr/lib/libQt6OpenGL.so.6.7.0,
error: No package owns /usr/lib/libQt6Test.so.6,
error: No package owns /usr/lib/libQt6EglFSDeviceIntegration.so.6.7.0,
error: No package owns /usr/lib/libQt6DBus.so.6.7.0,
error: No package owns /usr/lib/libQt6EglFsKmsSupport.so,
error: No package owns /usr/lib/libQt6Concurrent.so.6,
error: No package owns /usr/lib/libQt6Xml.so.6,
error: No package owns /usr/lib/libQt6PrintSupport.so,
error: No package owns /usr/lib/libQt6Concurrent.so,
error: No package owns /usr/lib/libQt6Xml.so,
error: No package owns /usr/lib/libQt6EglFsKmsGbmSupport.so.6.7.0,
error: No package owns /usr/lib/libQt6Sql.so.6.7.0,
error: No package owns /usr/lib/libQt6Core.so.6.7.0,
error: No package owns /usr/lib/libQt6Gui.so.6,
error: No package owns /usr/lib/libQt6EglFsKmsSupport.so.6,
error: No package owns /usr/lib/libQt6EglFSDeviceIntegration.so,
error: No package owns /usr/lib/libQt6Network.so,
error: No package owns /usr/lib/libQt6PrintSupport.so.6.7.0,
error: No package owns /usr/lib/libQt6EglFsKmsSupport.so.6.7.0,
error: No package owns /usr/lib/libQt6Core.so.6,
error: No package owns /usr/lib/libQt6PrintSupport.so.6,
error: No package owns /usr/lib/libQt6OpenGLWidgets.so.6.7.0,
error: No package owns /usr/lib/libQt6OpenGLWidgets.so.6,
error: No package owns /usr/lib/libQt6Test.so,
error: No package owns /usr/lib/libQt6Test.so.6.7.0,
error: No package owns /usr/lib/libQt6XcbQpa.so.6,
error: No package owns /usr/lib/libQt6Widgets.so.6.7.0,
error: No package owns /usr/lib/libQt6Core.so,
error: No package owns /usr/lib/libQt6DBus.so.6,
error: No package owns /usr/lib/libQt6Network.so.6,
error: No package owns /usr/lib/libQt6OpenGL.so,
error: No package owns /usr/lib/libQt6Gui.so.6.7.0,
error: No package owns /usr/lib/libQt6Sql.so.6,
error: No package owns /usr/lib/libQt6Concurrent.so.6.7.0,
error: No package owns /usr/lib/libQt6OpenGL.so.6,
error: No package owns /usr/lib/libQt6EglFsKmsGbmSupport.so,
error: No package owns /usr/lib/libQt6Sql.so,
error: No package owns /usr/lib/libQt6OpenGLWidgets.so,
error: No package owns /usr/lib/libQt6Gui.so,
Could you show the full output of
sudo pacman -Syu
Ps.
The
Only shows when installing or updating other packages.
Have you tried to echo what your script of array outputs at the first place? :smiley:
It puts there a comma, that is the problem.
Remove all the commas from the “files” list and your script will run as expected, and you’ll get outputs.
You need to strip the commas.
:point_up: :smiley:
on telegram i gave paccheck --list-broken --md5sum
and pacrepairdb ?
system is broken because of second part a crash… pacrepairdb (package) , should fix it and download it from cache…
Sorry, I didn’t see it, I ran it again without the commas, I also ran the command individually to test them without the script but they are still the same.
Yes, sorry I posted this first before asking in telegram, I’ll try it in a minute as I was busy with something and let you know.
In that case, you can use pkgfile.
First do sudo pkgfile -u to update the database and then try pkgfile <filename>
is just by the crash packages is ‘unowned’ of there libs…
Hello ringo,
This is the result im getting
lsb-release don’t mind it, eos does have a hooks so its always md5sum bad,
try sudo pacman -S --overwrite=‘*’ qt6-base rkhunter
that wil fix those unowned for now for huge part…
Nvm, I tried again with pacrepairdb and it works now, i did sudo pkgfile -u from dalto, dont know if that’s related.
I’ll make some test, to see if it works, if everything all right I’ll mark it solved.
Thanks to everyone who helped!
lsb-release will always shows up dont botter it :slight_smile: if pacman -S lsb-release works normally dont bother on that atleast
pkgfile you can tracks paths+libs who the owner if of that path libs… so you can reinstall overwrite those packages or remove the empty shell the reinstall the package as example…
i gues pacutils has that also or was it pactree :stuck_out_tongue: lot with pacutils you can fix some of the packages without the overwrite
