from what I could find none of these are set to work for Arch/Arch based Systems. You could try the source file from Cannon but even it says for Ubuntu and Fedora.
There are a bunch of Stuff for Cannon in the AUR you can search there and see if there is something for your printer. Personally haven’t installed a printer in over a decade so can’t be much help with that hopefully someone who does use one will be able to chime in.
Sorry, it’s scangearmp2 now. cnijlgmon3 was the old name. I remember last time I open it using cnijlgmon3.
You can search it in the apps menu and open it as well.
