Help I can't enter screen configuration anymore
good evening I have a problem, I can no longer start screen configuration on system settings I get a black screen and this message (Unable to load extension from /usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_kscreen.so: Unable to load library /usr/lib/qt6/plugins/plasma/kcms/systemsettings/kcm_kscreen.so: /usr/lib/libQt6Core.so.6: version `Qt_6.8’ not found (required by /usr/lib/libQt6Sensors.so.6) help me please.
This was an update. Are you up to date?
Edit: Check
pacman -Qi qt6-declarative
clear
103 / 5.000
Risultati della traduzione
Risultato di traduzione
it seems like the monitor screen is back, thanks for your concern, this is what I get
[marco@MarcoPc ~]$ pacman -Qi qt6-declarative
Nome : qt6-declarative
Versione : 6.8.0-2
Descrizione : Classes for QML and JavaScript languages
Architettura : x86_64
URL : https://www.qt.io
Licenze : GPL3 LGPL3 FDL custom
Gruppi : qt6
Fornisce : Nessuno
Dipenda da : gcc-libs glibc qt6-base
Dipendenze opzionali : Nessuno
Richiesto da : accounts-qml-module bluedevil breeze discover eos-quickstart haruna kcmutils kconfig kdeclarative kdeconnect
kdenetwork-filesharing kdeplasma-addons kinfocenter kirigami kirigami-addons kpipewire kquickcharts kscreen
kscreenlocker ktexteditor kwin libksysguard libplasma milou mpvqt okular plasma-desktop plasma-disks
plasma-firewall plasma-integration plasma-nm plasma-pa plasma-systemmonitor plasma-workspace plasma5support
polkit-kde-agent powerdevil print-manager purpose qcoro qqc2-breeze-style qqc2-desktop-style qt6-quick3d
qt6-quicktimeline qt6-virtualkeyboard qt6-wayland qt6-webchannel qt6-webengine qt6-webview sddm sddm-kcm signon-ui
spectacle systemsettings xdg-desktop-portal-kde xwaylandvideobridge
Opzionale per : baloo bluez-qt kaccounts-integration kate kcontacts kcoreaddons kholidays ki18n kiconthemes kitemmodels knewstuff
knotifications kpeople ksvg kuserfeedback kwindowsystem layer-shell-qt networkmanager-qt plasma-activities prison
qt6-5compat qt6-multimedia qt6-positioning qt6-sensors qt6-speech qt6-tools qt6-websockets sonnet
syntax-highlighting
Conflitti con : Nessuno
Sostituisce : Nessuno
Spazio richiesto : 101,69 MiB
Pacchettizzatore : Antonio Rojas arojas@archlinux.org
Data di creazione : mar 15 ott 2024, 13:21:48
Data di installazione : mar 15 ott 2024, 22:45:01
Motivo dell’installazione : Installato come dipendenza di un altro pacchetto
Script di install : No
Convalidato da : Firma
Must be another issue if the package is installed and updated.
I rebooted the system and it started up again, I don’t know how but it seems to be working now
