I mostly make settings through kernel parameters
Is it possible to add multi line(GRUB_CMDLINE_LINUX) for better control parameters?
Like this
GRUB_CMDLINE_LINUX=“parameters”
Like this
Multiple lines of GRUB_CMDLINE_LINUX=“parameters” will be ignored, afaik. Only the first line will work. You have to separate the parameters with a space like this:
GRUB_CMDLINE_LINUX_DEFAULT="quiet splash"
The difference:
GRUB_CMDLINE_LINUX_DEFAULT="param1 param2" will be executed on every boot.
GRUB_CMDLINE_LINUX="param1 param2" (without the “_DEFAULT”) will NOT be executed if the fall-back kernel is executed.
If you want to just have a better overview of the kernel parameters, something like the following would work.
The example is from my /etc/default/grub:
GRUB_CMDLINE_LINUX_DEFAULT="intel_pstate=passive
lsm=landlock,lockdown,yama,integrity,apparmor,bpf
zswap.enabled=0
nowatchdog"
Kind of Off topic, but for future readers:
AFAIK, only the last one will work.
I think you can have multiple lines like this:
GRUB_CMDLINE_LINUX="parameters"
GRUB_CMDLINE_LINUX+=" parameters"
Note the usage of += catenation and the first space inside the additional strings. They should make the value as one bigger string.
Note also that I haven’t really tested this, but AFAIK it is treated as bash or sh script.
Please correct me if I’m wrong.
Are you asking others to test?
It can be tested with a temporary save to a local file ![]()
The Manual says the same
The file /etc/default/grub controls the operation of
grub-mkconfig. It is sourced by a shell script, and so must be valid POSIX shell input; normally, it will just be a sequence of ‘KEY=value’ lines, but if the value contains spaces or other special characters then it must be quoted.
→ Are YOU asking others to test??? ![]()
…or do you know for sure, or did you try it?
Why not? ![]()
As it is run with sh, then it should work.
And there are other syntactical ways too:
GRUB_CMDLINE_LINUX="$GRUB_CMDLINE_LINUX parameters"
and the one presented in posts above. And probably more…
So many ways to do the same thing! ![]()
