So what do I have to add to get it to work for sudo then too?
pebcak
May 28, 2022, 8:24pm
23
Do as @keybreak mentioned here .
You haven’t used sudo all this time for test don’t you…?
That would explain a lot, since again - it requires separate config at
/root/.nanorc
include /usr/share/nano/*.nanorc
include /usr/share/nano-syntax-highlighting/*.nanorc
So do I do:
touch ~/root/.nanorc
nano ~/root/.nanorc
Add:
Save that and should give sudo colors? Or is there another way I should be doing that?
Pretty much, but you can actually do just:
sudo nano /root/.nanorc
paste all that
save it
P.S. Actually where the hell have you found ~ in my post about root?
It’s just /root
I was browsing over this while experimenting, I know it’s not Arch per se, but I think that’s where we got the “~” from fyi:
When I run sudo nano ~/root/.nanorc and try to save I get an error.
( gets rid of ~ … )
Add:
Save, and run a sudo file known to display some color syntax and…voila!?
But one thing worth noting is the red error message at the bottom saying “mistakes in include /usr/share/nano-syntax-highlighting/*.nanorc”
Should I just get ride of “include /usr/share/nano-syntax-highlighting/*.nanorc” because otherwise I think I’ll be seeing that red error message in every nano window
As you wish you’ll loose some extended syntax highlighting though…wonder what’s that error all about.
opened 08:13AM - 15 Dec 17 UTC
Hey,
thanks for compiling all these syntax highlighters. I definitely find t… hem useful as I probably use nano 99.9% of the time (my copy of ST3 is feeling sorely neglected)
However, I get a bunch of errors from a number of them in Arch Linux using GNU nano 2.9.1-1. Are they written for a different version?
Here's the full output:
Error in /usr/share/nano/default.nanorc on line 2: Command "+LINT" not allowed in included file
Error in /usr/share/nano/default.nanorc on line 2: Syntax "default" has no color commands
Error in /usr/share/nano/peg.nanorc on line 3: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/peg.nanorc on line 4: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/peg.nanorc on line 5: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/peg.nanorc on line 6: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/peg.nanorc on line 7: Command "REGEXP:" not allowed in included file
Error in /usr/share/nano/peg.nanorc on line 8: Command "+STRING" not allowed in included file
Error in /usr/share/nano/peg.nanorc on line 9: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/peg.nanorc on line 10: Command "+TODO" not allowed in included file
Error in /usr/share/nano/peg.nanorc on line 11: Command "+LINT" not allowed in included file
Error in /usr/share/nano/peg.nanorc on line 11: Syntax "peg" has no color commands
Error in /usr/share/nano/sed.nanorc on line 4: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/sed.nanorc on line 5: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/sed.nanorc on line 6: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/sed.nanorc on line 7: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/sed.nanorc on line 8: Command "+LINT" not allowed in included file
Error in /usr/share/nano/sed.nanorc on line 8: Syntax "sed" has no color commands
Error in /usr/share/nano/makefile.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 6: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 7: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 8: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 9: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 10: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 11: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 12: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 13: Command "PLAIN:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 14: Command "+STRING" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 15: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 16: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 17: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 18: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/makefile.nanorc on line 19: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/json.nanorc on line 4: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/json.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/json.nanorc on line 6: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/json.nanorc on line 7: Command "+STRING" not allowed in included file
Error in /usr/share/nano/json.nanorc on line 8: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/json.nanorc on line 9: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/json.nanorc on line 10: Command "+LINT" not allowed in included file
Error in /usr/share/nano/json.nanorc on line 10: Syntax "json" has no color commands
Error in /usr/share/nano/glsl.nanorc on line 3: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 4: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 5: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 6: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 7: Command "JUMP:" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 8: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 9: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 10: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 11: Command "+CCOMMENT" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 12: Command "+TODO" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 13: Command "+LINT" not allowed in included file
Error in /usr/share/nano/glsl.nanorc on line 13: Syntax "glsl" has no color commands
Error in /usr/share/nano/mpdconf.nanorc on line 3: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/mpdconf.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/mpdconf.nanorc on line 5: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/mpdconf.nanorc on line 6: Command "+STRING" not allowed in included file
Error in /usr/share/nano/mpdconf.nanorc on line 7: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/mpdconf.nanorc on line 8: Command "+LINT" not allowed in included file
Error in /usr/share/nano/mpdconf.nanorc on line 8: Syntax "mpdconf" has no color commands
Error in /usr/share/nano/pkgbuild.nanorc on line 3: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 6: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 7: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 8: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 9: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 10: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 11: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 12: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 13: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 14: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 15: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 16: Command "STRING:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 17: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 18: Command "STRING:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 19: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 20: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 21: Command "+LINT" not allowed in included file
Error in /usr/share/nano/pkgbuild.nanorc on line 21: Syntax "pkgbuild" has no color commands
Error in /usr/share/nano/ledger.nanorc on line 3: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/ledger.nanorc on line 4: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/ledger.nanorc on line 5: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/ledger.nanorc on line 6: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/ledger.nanorc on line 7: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/ledger.nanorc on line 8: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/ledger.nanorc on line 9: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/ledger.nanorc on line 9: Syntax "ledger" has no color commands
Error in /usr/share/nano/rpmspec.nanorc on line 3: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 6: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 7: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 8: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 9: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 10: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 11: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 12: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 13: Command "+STRING" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 14: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 15: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 16: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 17: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 18: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 19: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 20: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 21: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 22: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 23: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 24: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 25: Command "+LINT" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 26: Command "+TODO" not allowed in included file
Error in /usr/share/nano/rpmspec.nanorc on line 26: Syntax "rpmspec" has no color commands
Error in /usr/share/nano/lua.nanorc on line 4: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 6: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 7: Command "JUMP:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 8: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 9: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 10: Command "WARNING:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 11: Command "PLAIN:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 12: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 13: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 14: Command "+STRING" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 15: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 16: Command "STRING:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 17: Command "STRING:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 18: Command "STRING:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 19: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 20: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 21: Command "+TODO" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 22: Command "+LINT" not allowed in included file
Error in /usr/share/nano/lua.nanorc on line 22: Syntax "lua" has no color commands
Error in /usr/share/nano/nanorc.nanorc on line 4: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 6: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 8: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 9: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 11: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 12: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 13: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 14: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 16: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 17: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/nanorc.nanorc on line 18: Command "+LINT" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 3: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 4: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 5: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 6: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 7: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 8: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 9: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 10: Command "JUMP:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 11: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 12: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 13: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 14: Command "+STRING" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 15: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 16: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 17: Command "STRING:" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 18: Command "+CCOMMENT" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 19: Command "+TODO" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 20: Command "+LINT" not allowed in included file
Error in /usr/share/nano/go.nanorc on line 20: Syntax "go" has no color commands
Error in /usr/share/nano/vi.nanorc on line 3: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/vi.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/vi.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/vi.nanorc on line 6: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/vi.nanorc on line 7: Command "+STRING" not allowed in included file
Error in /usr/share/nano/vi.nanorc on line 8: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/vi.nanorc on line 9: Command "+LINT" not allowed in included file
Error in /usr/share/nano/vi.nanorc on line 9: Syntax "vi" has no color commands
Error in /usr/share/nano/yum.nanorc on line 3: Command "+INI" not allowed in included file
Error in /usr/share/nano/yum.nanorc on line 4: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/yum.nanorc on line 5: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/yum.nanorc on line 6: Command "+LINT" not allowed in included file
Error in /usr/share/nano/yum.nanorc on line 6: Syntax "yum" has no color commands
Error in /usr/share/nano/man.nanorc on line 3: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/man.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/man.nanorc on line 5: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/man.nanorc on line 6: Command "+STRING" not allowed in included file
Error in /usr/share/nano/man.nanorc on line 7: Command "STRING:" not allowed in included file
Error in /usr/share/nano/man.nanorc on line 8: Command "+LINT" not allowed in included file
Error in /usr/share/nano/man.nanorc on line 8: Syntax "man" has no color commands
Error in /usr/share/nano/xresources.nanorc on line 3: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/xresources.nanorc on line 4: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/xresources.nanorc on line 5: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/xresources.nanorc on line 6: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/xresources.nanorc on line 7: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/xresources.nanorc on line 8: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/xresources.nanorc on line 9: Command "+LINT" not allowed in included file
Error in /usr/share/nano/xresources.nanorc on line 9: Syntax "xresources" has no color commands
Error in /usr/share/nano/shell.nanorc on line 4: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 6: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 7: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 8: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 9: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 10: Command "STRING:" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 11: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 12: Command "STRING:" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 13: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 14: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 15: Command "+TODO" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 16: Command "+LINT" not allowed in included file
Error in /usr/share/nano/shell.nanorc on line 16: Syntax "sh" has no color commands
Error in /usr/share/nano/javascript.nanorc on line 3: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 4: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 5: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 6: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 7: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 8: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 9: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 10: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 11: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 12: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 13: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 14: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 15: Command "REGEXP:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 16: Command "+STRING" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 17: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 18: Command "+CCOMMENT" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 19: Command "+TODO" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 20: Command "+LINT" not allowed in included file
Error in /usr/share/nano/javascript.nanorc on line 20: Syntax "JavaScript" has no color commands
Error in /usr/share/nano/markdown.nanorc on line 9: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/markdown.nanorc on line 10: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/markdown.nanorc on line 11: Command "PLAIN:" not allowed in included file
Error in /usr/share/nano/markdown.nanorc on line 12: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/markdown.nanorc on line 13: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/markdown.nanorc on line 14: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/markdown.nanorc on line 15: Command "STRING:" not allowed in included file
Error in /usr/share/nano/markdown.nanorc on line 16: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/markdown.nanorc on line 17: Command "+LINT" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 3: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 4: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 5: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 6: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 7: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 8: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 9: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 10: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 11: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 12: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 13: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 14: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 15: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 16: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 17: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 18: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 19: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 20: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 21: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 24: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 25: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 26: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 27: Command "BOOLEAN:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 29: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 30: Command "+STRING" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 31: Command "STRING:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 32: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 33: Command "+LINT" not allowed in included file
Error in /usr/share/nano/sql.nanorc on line 33: Syntax "sql" has no color commands
Error in /usr/share/nano/pkg-config.nanorc on line 3: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/pkg-config.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/pkg-config.nanorc on line 5: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/pkg-config.nanorc on line 6: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/pkg-config.nanorc on line 7: Command "+LINT" not allowed in included file
Error in /usr/share/nano/pkg-config.nanorc on line 7: Syntax "pkg-config" has no color commands
Error in /usr/share/nano/c.nanorc on line 3: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 4: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 5: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 6: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 7: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 8: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 9: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 10: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 11: Command "JUMP:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 12: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 13: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 14: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 15: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 16: Command "ATTRIBUTE:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 17: Command "STRING:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 18: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 19: Command "+CCOMMENT" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 20: Command "+TODO" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 21: Command "+LINT" not allowed in included file
Error in /usr/share/nano/c.nanorc on line 21: Syntax "c" has no color commands
Error in /usr/share/nano/css.nanorc on line 4: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 5: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 6: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 7: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 8: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 9: Command "STRING:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 10: Command "PLAIN:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 13: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 14: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 16: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 17: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 18: Command "BOOLEAN:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 19: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 20: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 21: Command "WARNING:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 22: Command "PLAIN:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 23: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 24: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 25: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 26: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 27: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 28: Command "+STRING" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 29: Command "+CCOMMENT" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 30: Command "+TODO" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 31: Command "+LINT" not allowed in included file
Error in /usr/share/nano/css.nanorc on line 31: Syntax "css" has no color commands
Error in /usr/share/nano/ini.nanorc on line 4: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/ini.nanorc on line 5: Command "+INI" not allowed in included file
Error in /usr/share/nano/ini.nanorc on line 6: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/ini.nanorc on line 7: Command "+STRING" not allowed in included file
Error in /usr/share/nano/ini.nanorc on line 8: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/ini.nanorc on line 9: Command "+LINT" not allowed in included file
Error in /usr/share/nano/ini.nanorc on line 9: Syntax "ini" has no color commands
Error in /usr/share/nano/privoxy.nanorc on line 3: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 4: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 5: Command "+LINT" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 7: Syntax "privoxy-config" has no color commands
Error in /usr/share/nano/privoxy.nanorc on line 14: Command "PLAIN:" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 15: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 16: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 17: Command "+LINT" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 21: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 22: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 23: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 24: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 25: Command "+LINT" not allowed in included file
Error in /usr/share/nano/privoxy.nanorc on line 26: Syntax "privoxy-filter" has no color commands
Error in /usr/share/nano/vala.nanorc on line 3: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 4: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 6: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 7: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 8: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 9: Command "JUMP:" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 10: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 11: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 12: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 13: Command "+STRING" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 14: Command "+CCOMMENT" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 15: Command "+TODO" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 16: Command "+LINT" not allowed in included file
Error in /usr/share/nano/vala.nanorc on line 16: Syntax "vala" has no color commands
Error in /usr/share/nano/php.nanorc on line 4: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 5: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 6: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 7: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 8: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 9: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 10: Command "JUMP:" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 11: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 12: Command "+STRING" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 13: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 14: Command "+CCOMMENT" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 15: Command "+TODO" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 16: Command "+LINT" not allowed in included file
Error in /usr/share/nano/php.nanorc on line 16: Syntax "php" has no color commands
Error in /usr/share/nano/properties.nanorc on line 3: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/properties.nanorc on line 4: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/properties.nanorc on line 5: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/properties.nanorc on line 6: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/properties.nanorc on line 7: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/properties.nanorc on line 8: Command "+LINT" not allowed in included file
Error in /usr/share/nano/properties.nanorc on line 8: Syntax "properties" has no color commands
Error in /usr/share/nano/systemd.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/systemd.nanorc on line 5: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/systemd.nanorc on line 6: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/systemd.nanorc on line 7: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/systemd.nanorc on line 8: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/systemd.nanorc on line 9: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/systemd.nanorc on line 10: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/systemd.nanorc on line 11: Command "+LINT" not allowed in included file
Error in /usr/share/nano/systemd.nanorc on line 11: Syntax "systemd" has no color commands
Error in /usr/share/nano/csharp.nanorc on line 4: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 7: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 9: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 10: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 11: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 12: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 14: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 15: Command "JUMP:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 16: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 17: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 18: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 19: Command "+STRING" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 20: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 21: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 22: Command "+CCOMMENT" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 23: Command "+TODO" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 24: Command "+LINT" not allowed in included file
Error in /usr/share/nano/csharp.nanorc on line 24: Syntax "c#" has no color commands
Error in /usr/share/nano/kickstart.nanorc on line 3: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/kickstart.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/kickstart.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/kickstart.nanorc on line 6: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/kickstart.nanorc on line 13: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/kickstart.nanorc on line 14: Command "+LINT" not allowed in included file
Error in /usr/share/nano/yaml.nanorc on line 4: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/yaml.nanorc on line 5: Command "BOOLEAN:" not allowed in included file
Error in /usr/share/nano/yaml.nanorc on line 6: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/yaml.nanorc on line 7: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/yaml.nanorc on line 8: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/yaml.nanorc on line 9: Command "+STRING" not allowed in included file
Error in /usr/share/nano/yaml.nanorc on line 10: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/yaml.nanorc on line 11: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/yaml.nanorc on line 12: Command "+LINT" not allowed in included file
Error in /usr/share/nano/yaml.nanorc on line 12: Syntax "yaml" has no color commands
Error in /usr/share/nano/po.nanorc on line 3: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/po.nanorc on line 4: Command "+STRING" not allowed in included file
Error in /usr/share/nano/po.nanorc on line 5: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/po.nanorc on line 6: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/po.nanorc on line 7: Command "+LINT" not allowed in included file
Error in /usr/share/nano/po.nanorc on line 7: Syntax "po" has no color commands
Error in /usr/share/nano/tex.nanorc on line 3: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/tex.nanorc on line 4: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/tex.nanorc on line 5: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/tex.nanorc on line 6: Command "+LINT" not allowed in included file
Error in /usr/share/nano/tex.nanorc on line 6: Syntax "tex" has no color commands
Error in /usr/share/nano/cmake.nanorc on line 3: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/cmake.nanorc on line 4: Command "BOOLEAN:" not allowed in included file
Error in /usr/share/nano/cmake.nanorc on line 5: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/cmake.nanorc on line 6: Command "+STRING" not allowed in included file
Error in /usr/share/nano/cmake.nanorc on line 7: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/cmake.nanorc on line 8: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/cmake.nanorc on line 9: Command "+LINT" not allowed in included file
Error in /usr/share/nano/cmake.nanorc on line 9: Syntax "cmake" has no color commands
Error in /usr/share/nano/lisp.nanorc on line 3: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 4: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 5: Command "PLAIN:" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 6: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 7: Command "~KEYWORD:" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 8: Command "BOOLEAN:" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 9: Command "STRING:" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 10: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 11: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 12: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 13: Command "+LINT" not allowed in included file
Error in /usr/share/nano/lisp.nanorc on line 13: Syntax "lisp" has no color commands
Error in /usr/share/nano/java.nanorc on line 4: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 7: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 9: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 10: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 11: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 12: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 13: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 14: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 15: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 16: Command "JUMP:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 17: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 18: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 19: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 20: Command "+STRING" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 21: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 22: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 23: Command "+CCOMMENT" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 24: Command "+TODO" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 25: Command "+LINT" not allowed in included file
Error in /usr/share/nano/java.nanorc on line 25: Syntax "java" has no color commands
Error in /usr/share/nano/xml.nanorc on line 4: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/xml.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/xml.nanorc on line 6: Command "+STRING" not allowed in included file
Error in /usr/share/nano/xml.nanorc on line 7: Command "WARNING:" not allowed in included file
Error in /usr/share/nano/xml.nanorc on line 8: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/xml.nanorc on line 9: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/xml.nanorc on line 10: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/xml.nanorc on line 11: Command "+LINT" not allowed in included file
Error in /usr/share/nano/xml.nanorc on line 11: Syntax "xml" has no color commands
Error in /usr/share/nano/cython.nanorc on line 3: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 6: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 7: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 9: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 10: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 11: Command "TYPE:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 13: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 14: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 15: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 16: Command "BOOLEAN:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 17: Command "+STRING" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 18: Command "STRING:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 19: Command "STRING:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 20: Command "STRING:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 21: Command "STRING:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 22: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 23: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 24: Command "+TODO" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 25: Command "+LINT" not allowed in included file
Error in /usr/share/nano/cython.nanorc on line 25: Syntax "cython" has no color commands
Error in /usr/share/nano/nginx.nanorc on line 4: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/nginx.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/nginx.nanorc on line 6: Command "PLAIN:" not allowed in included file
Error in /usr/share/nano/nginx.nanorc on line 7: Command "BOOLEAN:" not allowed in included file
Error in /usr/share/nano/nginx.nanorc on line 8: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/nginx.nanorc on line 9: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/nginx.nanorc on line 10: Command "+STRING" not allowed in included file
Error in /usr/share/nano/nginx.nanorc on line 11: Command "STRING:" not allowed in included file
Error in /usr/share/nano/nginx.nanorc on line 12: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/nginx.nanorc on line 13: Command "+LINT" not allowed in included file
Error in /usr/share/nano/nginx.nanorc on line 13: Syntax "nginx" has no color commands
Error in /usr/share/nano/keymap.nanorc on line 3: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/keymap.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/keymap.nanorc on line 5: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/keymap.nanorc on line 6: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/keymap.nanorc on line 7: Command "+STRING" not allowed in included file
Error in /usr/share/nano/keymap.nanorc on line 8: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/keymap.nanorc on line 9: Command "+LINT" not allowed in included file
Error in /usr/share/nano/keymap.nanorc on line 9: Syntax "keymap" has no color commands
Error in /usr/share/nano/coffeescript.nanorc on line 4: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 5: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 6: Command "PLAIN:" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 7: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 8: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 9: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 10: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 11: Command "BOOLEAN:" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 12: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 13: Command "+STRING" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 14: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 15: Command "+LINT" not allowed in included file
Error in /usr/share/nano/coffeescript.nanorc on line 15: Syntax "coffeescript" has no color commands
Error in /usr/share/nano/html.nanorc on line 4: Command "ATTRIBUTE:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 5: Command "WARNING:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 6: Command "TAG:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 7: Command "STRING:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 8: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 9: Command "+STRING" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 10: Command "PLAIN:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 11: Command "TAG:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 14: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 15: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 16: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 17: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 19: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 20: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 21: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 22: Command "+LINT" not allowed in included file
Error in /usr/share/nano/html.nanorc on line 22: Syntax "html" has no color commands
Error in /usr/share/nano/ruby.nanorc on line 3: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/ruby.nanorc on line 4: Command "STRING:" not allowed in included file
Error in /usr/share/nano/ruby.nanorc on line 5: Command "REGEXP:" not allowed in included file
Error in /usr/share/nano/ruby.nanorc on line 6: Command "+STRING" not allowed in included file
Error in /usr/share/nano/ruby.nanorc on line 7: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/ruby.nanorc on line 8: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/ruby.nanorc on line 9: Command "+TODO" not allowed in included file
Error in /usr/share/nano/ruby.nanorc on line 10: Command "+LINT" not allowed in included file
Error in /usr/share/nano/ruby.nanorc on line 10: Syntax "ruby" has no color commands
Error in /usr/share/nano/git.nanorc on line 3: Command "+BOOLEAN" not allowed in included file
Error in /usr/share/nano/git.nanorc on line 4: Command "+INI" not allowed in included file
Error in /usr/share/nano/git.nanorc on line 5: Command "+STRING" not allowed in included file
Error in /usr/share/nano/git.nanorc on line 6: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/git.nanorc on line 7: Command "+LINT" not allowed in included file
Error in /usr/share/nano/git.nanorc on line 9: Syntax "gitconfig" has no color commands
Error in /usr/share/nano/git.nanorc on line 11: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/git.nanorc on line 16: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/git.nanorc on line 17: Command "NUMBER:" not allowed in included file
Error in /usr/share/nano/git.nanorc on line 18: Command "COMMENT:" not allowed in included file
Error in /usr/share/nano/git.nanorc on line 18: Syntax "git-rebase" has no color commands
Error in /usr/share/nano/dot.nanorc on line 3: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/dot.nanorc on line 4: Command "ATTRIBUTE:" not allowed in included file
Error in /usr/share/nano/dot.nanorc on line 5: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/dot.nanorc on line 6: Command "+STRING" not allowed in included file
Error in /usr/share/nano/dot.nanorc on line 7: Command "+CCOMMENT" not allowed in included file
Error in /usr/share/nano/dot.nanorc on line 7: Syntax "dot" has no color commands
Error in /usr/share/nano/inputrc.nanorc on line 5: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/inputrc.nanorc on line 6: Command "+STRING" not allowed in included file
Error in /usr/share/nano/inputrc.nanorc on line 7: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/inputrc.nanorc on line 8: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/inputrc.nanorc on line 9: Command "+LINT" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 4: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 5: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 6: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 7: Command "VARIABLE:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 8: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 9: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 10: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 11: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 12: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 13: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 14: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 15: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 16: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 17: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 18: Command "FUNCTION:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 19: Command "REGEXP:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 20: Command "+STRING" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 21: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 22: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 23: Command "+TODO" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 24: Command "+LINT" not allowed in included file
Error in /usr/share/nano/awk.nanorc on line 24: Syntax "awk" has no color commands
Error in /usr/share/nano/python.nanorc on line 4: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 5: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 6: Command "KEYWORD:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 7: Command "+FUNCTION" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 8: Command "OPERATOR:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 9: Command "MACRO:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 10: Command "SECTION:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 11: Command "BOOLEAN:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 12: Command "+STRING" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 13: Command "STRING:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 14: Command "STRING:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 15: Command "STRING:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 16: Command "STRING:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 17: Command "ESCAPE:" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 18: Command "+HASHCOMMENT" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 19: Command "+TODO" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 20: Command "+LINT" not allowed in included file
Error in /usr/share/nano/python.nanorc on line 20: Syntax "python" has no color commands
Yes, nano tries to load each one of the .nanorc files in the directory and responds with an error for every line that invokes an unsupported value. That’s why there are several errors per .nanorc file (which are one .nanorc file per language syntax definition). So basically several languages were not supported in the version I was using in Arch, nano 2.9.1-1.
However, several others were. I simply deleted the unsupported syntax (.nanorc) files and stopped receiving the errors.
It had nothing to do with the default.nanorc file. Sorry if that wasn’t clear.
I was mostly just curious if they were supported in a different version of nano. What version have you tested these definition files with?
Thanks! Hope you have a nice day, too
This is an error I get for example:
[scott@EndeavourOS ~]$ sudo nano /etc/nanorc
Error in /usr/share/nano-syntax-highlighting/nanorc.nanorc on line 26: Color 'normal' takes no prefix
PLus the red error shows up if it’s sudo or not. This is starting to become very troublesome
I have a similar error. I renamed nanorc.nanorc to nanorc.nanorc_old and copied /usr/share/nano/nanorc.nanorc to /usr/share/nano-syntax-highlighting/nanorc.nanorc to get rid of the error and I don’t notice any difference in the highlighting.
We’re at v6.3 though…
It was 2017…
Will Echo them all without using asterix
Needs to replace install path with the path to the rc files indeed
Less universal, in case there will be updates and new languages added, if we’re talking iso skel
Yea bloated in case of lines of text
Just a quick recap to condense the solution that worked for me:
Enable nano colors without sudo, create nanorc file in Home directory:
nano ~/.nanorc
Added only this (nano-syntax-highlighting was giving too many errors):
include /usr/share/nano/*.nanorc
Save and exit.
Enable nano colors with sudo:
sudo nano /root/.nanorc
Added the same line as above:
Save and exit. Now “some” nano colors are enabled and working with and without sudo. The nano-syntax-highlighting package just honestly seems like more effort than it’s worth to figure out, so I think I’ll just stick with this for now.
I will check to replicate this…
As it is shipped with i3 and xfce4
You should not use sudo in home dir though, just
nano ~/.nanorc
sudo should be used only when it’s necessary, otherwise permissions / owner of file will be messed for your home user
pebcak
May 28, 2022, 9:20pm
39
Perhaps check the ownership of ~/.nanorc?
ls -al ~/.nanorc
[scott@EndeavourOS ~]$ ls -al ~/.nanorc
-rw-r--r-- 1 scott scott 33 May 28 16:57 /home/scott/.nanorc
Edit: FYI, love seeing this community come together to figure stuff out
Yes, having wrong permissions causes issues in these configurations.
scopatz:master ← hdquemada:master
opened 02:46AM - 16 Apr 22 UTC
Line 26 of nanorc.nanorc generates an error in nano 6.2. Changed brightnormal to… normal.
for this will be fixed on next update what will come n late 2025 i would bet
There is a git version in AUR:
https://aur.archlinux.org/packages/nano-syntax-highlighting-git
what have the same error indeed as it is still not merged all together…
So this is strange in a way as … nanorc.nanorc is the one for highlighting… nanorc files … should get solved and indeed changing brightnormal to normal as it does not allow a prefix will solve the error in red…
And there is also exclude what excludes files you do not want:
exclude /usr/share/nano-syntax-highlighting/nanorc.nanorc per example in your .nanorc…
other than this it is fully working for me :
