I deleted the /cryptokeyfile.bin file by mistake
Now, every time I reboot the system, I enter the password of the root partition twice
Does anyone know how I can solve this problem?
The basic steps would be:
How to create keyfile?
Something like this:
dd if=/dev/random bs=32 count=1 of=/cryptokeyfile.bin
I created the keyfile and rebooted the system, but I entered the password twice, I think it didn’t work
You can’t just create a new keyfile. You need to remove the old keyfile from your luks volume and then add the new one as I mentioned above.
Unfortunately, I don’t know the steps you mentioned, can you write the instructions commands for the above steps?
I finally found it
7.5.2 With a keyfile embedded in the initramf
