First time using Endeavour OS. Previously, everything was functioning correctly, but now both the front and back headphone jacks are not working (does not show device). However, the USB and HDMI connections still provide audio output. Interestingly, the headphone jack starts working again after a core update (reboot prompt show up) and stops working upon rebooting
Does anyone have any insights into what might be causing this problem?
I’m using XFCE on a custom maching (B450 tomahuk max ii)
Hi,
the headphone is working properly. i tested it on other device
Pipewire-jack is installed. i tried to reinstall it but it not help.
is there anything i can do to get more troubleshoot information?
sorry, i did not phase it correctly.
i meant every times the system install a core update, the headphone jack work again until reboot.
it work after those line apear:
This is a normal thing, as the newer, updated kernel modules (DKMS) are being installed and then loaded again…
Mind, such an update is only really “finished”, after you reboot your computer.
If indeed the sound is not working after a reboot (and only before a reboot, after a DKMS rebuild), there must be something wrong with your kernel / driver installation, me thinks.
