Hey all
Not 100% sure if it was directly after the update but its my best guess due to the timeline I experienced. I was using my headphones and was working fine, then went to a workshop and updated my laptop. Today I tried the headphones after not using the laptop all evening. I also experienced a USB-C port not powering a USB-HUB, which it could before, but I’m not sure if that’s related as well.
Here is my inxi -Fza output:
[josem@tp-x1 ~]$ inxi -Fza
Kernel: 6.12.65-1-lts arch: x86_64 bits: 64 compiler: gcc v: 15.2.1
clocksource: tsc avail: acpi_pm
parameters: initrd=\36a2155209c148548bcd54b15a24d64b\6.12.65-1-lts\initrd
nvme_load=YES nowatchdog rw
root=UUID=81233856-753c-4e45-9ad4-1eeab1992261
systemd.machine_id=36a2155209c148548bcd54b15a24d64b
Desktop: i3 v: 4.25 with: i3bar tools: xss-lock avail: i3lock vt: 7
dm: LightDM v: 1.32.0 Distro: EndeavourOS base: Arch Linux
Type: Laptop System: LENOVO product: 20XW00QGUS v: ThinkPad X1 Carbon Gen 9
serial: Chassis: type: 10 serial:
Mobo: LENOVO model: 20XW00QGUS v: SDK0T76530 WIN
serial: part-nu: LENOVO_MT_20XW_BU_Think_FM_ThinkPad
X1 Carbon Gen 9 uuid: Firmware: UEFI vendor: LENOVO
v: N32ET80W (1.56 ) date: 08/29/2022
Battery:
ID-1: BAT0 charge: 40.5 Wh (86.6%) condition: 46.8/57 Wh (82.1%) power: 7 W
volts: 16.31 min: 15.44 model: Celxpert 5B10W13974 type: Li-poly
serial: charging: status: discharging control: start: 0%
end: 100% cycles: 387
Device-1: hidpp_battery_0 model: Logitech Wireless Mouse M510
serial: charge: 55% (should be ignored) rechargeable: yes
status: discharging
Info: model: 11th Gen Intel Core i7-1185G7 bits: 64 type: MT MCP
arch: Tiger Lake gen: core 11 level: v4 note: check built: 2020
process: Intel 10nm family: 6 model-id: 0x8C (140) stepping: 1
microcode: 0xBC
Topology: cpus: 1x dies: 1 clusters: 4 cores: 4 threads: 8 tpc: 2
smt: enabled cache: L1: 320 KiB desc: d-4x48 KiB; i-4x32 KiB L2: 5 MiB
desc: 4x1.2 MiB L3: 12 MiB desc: 1x12 MiB
Speed (MHz): avg: 677 min/max: 400/4800 scaling: driver: intel_pstate
governor: powersave cores: 1: 677 2: 677 3: 677 4: 677 5: 677 6: 677 7: 677
8: 677 bogomips: 47936
Flags-basic: avx avx2 ht lm nx pae sse sse2 sse3 sse4_1 sse4_2 ssse3 vmx
Vulnerabilities:
Type: gather_data_sampling mitigation: Microcode
Type: indirect_target_selection mitigation: Aligned branch/return thunks
Type: reg_file_data_sampling status: Not affected
Type: spec_rstack_overflow status: Not affected
prctl
sanitization
Type: spectre_v2 mitigation: Enhanced / Automatic IBRS; IBPB:
conditional; PBRSB-eIBRS: SW sequence; BHI: SW loop, KVM: SW loop
Type: tsa status: Not affected
Type: vmscape status: Not affected
Device-1: Intel TigerLake-LP GT2 [Iris Xe Graphics] vendor: Lenovo
driver: i915 v: kernel alternate: xe arch: Xe process: Intel 10nm
built: 2020-21 ports: active: eDP-1 empty: DP-1, DP-2, DP-3, DP-4,
HDMI-A-1, HDMI-A-2, HDMI-A-3 bus-ID: 00:02.0 chip-ID: 8086:9a49
class-ID: 0300
Device-2: Syntek Integrated Camera driver: uvcvideo type: USB rev: 2.0
speed: 480 Mb/s lanes: 1 mode: 2.0 bus-ID: 3-4:4 chip-ID: 174f:2455
class-ID: 0e02
Display: x11 server: X.Org v: 21.1.21 compositor: Picom v: 12.5 driver: X:
loaded: modesetting alternate: fbdev,intel,vesa dri: iris gpu: i915
display-ID: :0 screens: 1
Screen-1: 0 s-res: 1920x1200 s-dpi: 96 s-size: 508x317mm (20.00x12.48")
s-diag: 599mm (23.57")
Monitor-1: eDP-1 model: AU Optronics 0xd291 built: 2020 res:
mode: 1920x1200 hz: 60 scale: 100% (1) dpi: 162 gamma: 1.2
size: 301x188mm (11.85x7.4") diag: 355mm (14") ratio: 16:10
modes: 1920x1200
API: EGL v: 1.5 hw: drv: intel iris platforms: device: 0 drv: iris
device: 1 drv: swrast gbm: drv: iris surfaceless: drv: iris x11: drv: iris
inactive: wayland
API: OpenGL v: 4.6 compat-v: 4.5 vendor: intel mesa v: 25.3.3-arch1.2
glx-v: 1.4 direct-render: yes renderer: Mesa Intel Iris Xe Graphics (TGL
GT2) device-ID: 8086:9a49 memory: 14.97 GiB unified: yes
Info: Tools: api: eglinfo,glxinfo x11: xdpyinfo, xprop, xrandr
Device-1: Intel Tiger Lake-LP Smart Sound Audio vendor: Lenovo
driver: sof-audio-pci-intel-tgl alternate: snd_hda_intel, snd_soc_avs,
snd_sof_pci_intel_tgl bus-ID: 00:1f.3 chip-ID: 8086:a0c8 class-ID: 0403
API: ALSA v: k6.12.65-1-lts status: kernel-api
Server-1: PipeWire v: 1.4.9 status: active with: 1: pipewire-pulse
Device-1: Intel Wi-Fi 6 AX201 driver: iwlwifi v: kernel bus-ID: 00:14.3
chip-ID: 8086:a0f0 class-ID: 0280
IF: wlan0 state: up mac:
IF-ID-1: br-0b1c95ee018f state: up speed: 10000 Mbps duplex: unknown
mac:
IF-ID-2: br-c1c5ada55de4 state: down mac:
IF-ID-3: br-e8ef0de56eef state: up speed: 10000 Mbps duplex: unknown
mac:
IF-ID-4: docker0 state: down mac:
IF-ID-5: veth30ee169 state: up speed: 10000 Mbps duplex: full
mac:
IF-ID-6: vethab99502 state: up speed: 10000 Mbps duplex: full
mac:
IF-ID-7: vethaf5863f state: up speed: 10000 Mbps duplex: full
mac:
IF-ID-8: vethb2f88b8 state: up speed: 10000 Mbps duplex: full
mac:
IF-ID-9: vethba0b910 state: up speed: 10000 Mbps duplex: full
mac:
IF-ID-10: vethd3ec767 state: up speed: 10000 Mbps duplex: full
mac:
IF-ID-11: vethdab74f6 state: up speed: 10000 Mbps duplex: full
mac:
Info: services: NetworkManager, systemd-timesyncd, wpa_supplicant
Bluetooth:
Device-1: Intel AX201 Bluetooth driver: btusb v: 0.8 type: USB rev: 2.0
speed: 12 Mb/s lanes: 1 mode: 1.1 bus-ID: 3-10:10 chip-ID: 8087:0026
class-ID: e001
Report: btmgmt ID: hci0 rfk-id: 3 state: down bt-service: disabled
Local Storage: total: 1.82 TiB used: 281.84 GiB (15.1%)
ID-1: /dev/nvme0n1 maj-min: 259:0 vendor: Western Digital
model: WD BLACK SN850X 2000GB size: 1.82 TiB block-size: physical: 512 B
logical: 512 B speed: 63.2 Gb/s lanes: 4 tech: SSD serial:
fw-rev: 620361WD temp: 30.9 C scheme: GPT
ID-1: / raw-size: 1.82 TiB size: 1.79 TiB (98.37%) used: 281.63 GiB (15.4%)
fs: ext4 dev: /dev/nvme0n1p2 maj-min: 259:2
Kernel: swappiness: 60 (default) cache-pressure: 100 (default) zswap: yes
compressor: zstd max-pool: 20%
ID-1: swap-1 type: file size: 512 MiB used: 0 KiB (0.0%) priority: -2
file: /swapfile
Src: /sys System Temperatures: cpu: 39.0 C mobo: N/A
Fan Speeds (rpm): N/A
Memory: total: 16 GiB note: est. available: 15.33 GiB used: 3.49 GiB (22.7%)
Processes: 275 Power: uptime: 2m states: freeze,mem,disk suspend: s2idle
wakeups: 0 hibernate: platform avail: shutdown, reboot, suspend, test_resume
image: 6.12 GiB services: power-profiles-daemon Init: systemd v: 259
default: graphical tool: systemctl
Packages: pm: pacman pkgs: 1008 libs: 248 tools: yay Compilers:
gcc: 15.2.1 Shell: Bash v: 5.3.9 running-in: xfce4-terminal inxi: 3.3.40
Thank you for your assistance and time!
