HDMI monitor no display after update
I ran yay -Syu and rebooted, and afterwards my montior configuration/arrangement seemed to be reset, and my HDMI monitor no longer seems to be detected (it does not appear in xrandr or the KDE display configuration). I have 2 other connected displayport monitors, and they still work. I am not sure where to begin looking to identify the issue.
Since xrandr does not even list an unconnected hdmi output, I’m wondering if somehow something is wrong on the driver side? GPU is a 9070xt, as far as I can tell everything is working fine otherwise.
xrandr output:
xrandr
Screen 0: minimum 16 x 16, current 5120 x 1440, maximum 32767 x 32767
DP-1 connected 2560x1440+2560+0 (normal left inverted right x axis y axis) 598mm x 336mm
2560x1440 143.91*+
1920x1440 143.90
1600x1200 143.89
1440x1080 143.80
1400x1050 143.89
1280x1024 143.79
1280x960 143.86
1152x864 143.92
1024x768 143.87
800x600 143.83
640x480 143.85
320x240 142.05
1920x1200 143.89
1680x1050 143.88
1440x900 143.86
1280x800 143.84
1152x720 143.77
960x600 143.72
928x580 143.50
800x500 143.68
768x480 143.69
720x480 143.85
640x400 143.37
320x200 141.40
2048x1152 143.88
1920x1080 143.88
1600x900 143.93
1368x768 143.77
1280x720 143.67
1024x576 143.91
864x486 143.63
720x400 143.88
640x350 143.57
DP-2 connected primary 2560x1440+0+0 (normal left inverted right x axis y axis) 597mm x 336mm
2560x1440 239.84*+
1920x1440 239.84
1600x1200 239.94
1440x1080 239.87
1400x1050 239.76
1280x1024 239.78
1280x960 239.80
1152x864 239.87
1024x768 239.74
800x600 239.81
640x480 239.21
320x240 238.24
1920x1200 239.88
1680x1050 239.73
1440x900 239.68
1280x800 239.70
1152x720 239.91
960x600 239.72
928x580 239.78
800x500 239.72
768x480 239.29
720x480 239.35
640x400 239.49
320x200 238.84
2048x1152 239.87
1920x1080 239.88
1600x900 239.72
1368x768 239.74
1280x720 239.79
1024x576 239.43
864x486 239.60
720x400 239.07
640x350 239.59
Edited to add:
Unplugging the HDMI cable from the GPU and inserting it into the second HDMI port fixed the issue, and then reinserting it into the new HDMI port works. I probably should have tried that first I suppose. No idea what the root cause is.
Made account to post something similar updated to latest system with yay, now my screen reverted to 1920/1080 instead my old 2056x1080 on top of it when I run xrandr there is also no option of my ultrawide screen. Inside Kde there is no option to change screen either, I tried in both wayland and x11 I have nvidia card
I had a similar problem this morning. I downgraded the nvidia drivers by running sudo downgrade nvidia-open-dkms nvidia-utils and rebooting. I had to select my higher resolution in the display and monitor settings.
sudo downgrade nvidia nvidia-utils lib32-nvidia-utils running and reverting to 580.95.05-1(nvidia-utils lib32-nvidia-utils ) and nvidia itself to 580.95.05-9, seemed to do the trick thank you mate!
