Hey, super-new Endeavour user here. Just today I was trying to install Steam games on my HDD, but they would not launch after installing them. Pretty quickly I discovered that the issue was that my HDD was NTFS, which is not compatible. To change it to ext4, I tried following this guide, and I made sure to not mistype or do anything wrong.
However, after following all the steps, I noticed that I wasn’t able to create any folders or files in there. The Properties window brought me this:
After that, I tried unmounting the disk and then trying to fix any errors with it. First I did:
$ sudo fsck -f /dev/sda1
Which resulted in:
fsck from util-linux 2.39.2
e2fsck 1.47.0 (5-Feb-2023)
Pass 1: Checking inodes, blocks, and sizes
Pass 2: Checking directory structure
Pass 3: Checking directory connectivity
Pass 4: Checking reference counts
Pass 5: Checking group summary information
yura: 12/61054976 files (0.0% non-contiguous), 4115203/244190390 blocks
After that, I tried to remount it by using the mount command:
$ sudo mount -o remount,rw /dev/sda1 /run/media/azarth/yura
However, it does not mount. Instead it says:
mount: /run/media/azarth/yura: mount point not mounted or bad option.
dmesg(1) may have more information after failed mount system call.
I have tried checking dmesg, but it has so much information in there that I don’t know what to actually consider or not to fix this problem.
Any help?
