Well I was playing around and deleted both kernels I had (my mistake).
Anyway, I have live USB and I have been trying to chroot into my system, and every time I get the error message
/mnt/boot/efi: mount point does not exist.
This applies also if I do /mnt
but I do have a EFI system so /mnt/boot/efi
should apply.
I am going through these instructions https://discovery.endeavouros.com/system-rescue/arch-chroot-for-efi-uefi-systems/2021/03/
I am using BTRFS so I went after the tutorial about that, and here is the result of that
[liveuser@eos-2022.09.10 ~]$ sudo btrfs subvolume list -p /mnt
ID 256 gen 90014 parent 5 top level 5 path @
ID 257 gen 90014 parent 5 top level 5 path @home
ID 258 gen 90014 parent 5 top level 5 path @cache
ID 259 gen 90014 parent 5 top level 5 path @log
ID 260 gen 26 parent 256 top level 256 path @/var/lib/portables
ID 261 gen 27 parent 256 top level 256 path @/var/lib/machines
ID 262 gen 89267 parent 5 top level 5 path timeshift-btrfs/snapshots/2022-10-22_12-23-23/@
ID 263 gen 59118 parent 5 top level 5 path timeshift-btrfs/snapshots/2022-10-22_12-23-23/@home
ID 294 gen 89041 parent 5 top level 5 path timeshift-btrfs/snapshots/2022-11-14_21-00-01/@
ID 295 gen 86747 parent 5 top level 5 path timeshift-btrfs/snapshots/2022-11-14_21-00-01/@home
ID 296 gen 89041 parent 5 top level 5 path timeshift-btrfs/snapshots/2022-11-15_21-00-02/@
ID 297 gen 88234 parent 5 top level 5 path timeshift-btrfs/snapshots/2022-11-15_21-00-02/@home
ID 298 gen 90016 parent 5 top level 5 path timeshift-btrfs/snapshots/2022-11-16_21-00-01/@
ID 299 gen 90017 parent 5 top level 5 path timeshift-btrfs/snapshots/2022-11-16_21-00-01/@home
[liveuser@eos-2022.09.10 ~]$ sudo mount -o subvol=@ /dev/nvme0n1p1 /mnt/boot/efi
mount: /mnt/boot/efi: mount point does not exist.
dmesg(1) may have more information after failed mount system call.
[liveuser@eos-2022.09.10 ~]$ sudo mount /dev/nvme0n1p1 /mnt/boot/efi
Then I decided to install Timeshift to my live user, because I literally have a working snapshot from midnight.
However I can’t install Timeshift, all of the dependencies get timed out due to connection error, like I am not connected to the internet at all.
I am however writing from the live user and I am connected to Wi-Fi.
I do feel a bit lost at the moment and good ideas would be appreciated.
