After using pacman -Syu and saying yes to a million different packages, I get:
:: installing jsoncpp (1.9.6-3) breaks dependency 'libjsoncpp.so=25-64' required by headlines
:: removing plasma-framework breaks dependency 'plasma-framework>=5.82' required by plasma-gamemode-git
:: removing kactivities breaks dependency 'kactivities' required by telepathy-kde-integration-module
I’m usually pretty good at resolving these but not sure if it’s months of not using Linux or just organization being weird… but updating is proving… troublesome.
Apologies if there’s info already available. The jsoncpp one with headlines had a fix but it seems it involved a pacman -Syu that… yeah, I’m having issues with. Feels like it’s looping back on itself.
Help? And if I may ask, what even is headlines?
Btw, the “removal” is likely more to do with these:
Replace plasma-framework with extra/plasma-framework5? [Y/n] y
Replace kactivities with extra/kactivities5? [Y/n] y
:: Replace kactivities with extra/plasma-activities? [Y/n] y
:: Replace kactivities-stats with extra/kactivities-stats5? [Y/n] y
:: Replace kactivities-stats with extra/plasma-activities-stats? [Y/n] y
Almost past the finish line, I think! Though now when I run eos-update --aur I’m getting the following errors, the showstopper seeming to be -> could not find all required packages: clang =17.0.6
the other being
:: There are 13 providers available for java-runtime-headless:
:: Repository extra
1) jdk-openjdk 2) jdk11-openjdk 3) jdk17-openjdk 4) jdk21-openjdk 5) jre-openjdk 6) jre-openjdk-headless 7) jre11-openjdk 8) jre11-openjdk-headless 9) jre17-openjdk 10) jre17-openjdk-headless 11) jre21-openjdk 12) jre21-openjdk-headless 13) jre8-openjdk-headless
which I’m… unsure about but cursory searches say jre-openjdk-headless is the most up-to-date?
EDIT: clang issue seems to be related to python-shiboken2
I’m all down for boring as long as I can learn from it.
Unfortunately, that command didn’t seem to change the “clang” issue.
For anyone that may stumble across this issue in the future and find this in search (as unlikely as it is), my problem was anydesk-bin in the AUR uses python-shiboken2. I found this out by trying to uninstall python-shiboken2 with yay and it said anydesk depended on it, so I simply updated anydesk-bin with yay -S anydesk-bin which seems to have cleared up the error.
eos-update -aur is chugging along without issue now.
Not sure which post to tag as the solution, though, since this was a bit of a rabbit hole.
