Haruna screenshots fail
Why would haruna’s screenshots work normally in an MATE environment, but fail in Plasma?
.. Haruna
MATE yes
Plasma no
Not enough information for me. It works here (version 6.6.4 in Wayland).
Edit: I must admit I haven"t used the S key.
Disabling hw acceleration helped.
BTW Fedora 44 cosmic-comp (Wayland) works with hw acc. auto
[1/7] libXScrnSaver-0:1.2.4-7.fc44.x86_64
[2/7] libXpresent-0:1.0.0-28.fc44.x86_64
[3/7] vapoursynth-libs-0:72-1.fc44.x86_64
[4/7] mujs-0:1.3.7-2.fc44.x86_64
[5/7] mpvqt-0:1.1.1-1.fc44.x86_64
[6/7] haruna-0:1.7.1-1.fc44.x86_64
[7/7] mpv-libs-0:0.41.0-5.fc44.x86_64
Screenshot in Haruna fails for me as well…
─❯ kinfo
Operating System: EndeavourOS
KDE Plasma Version: 6.6.4
KDE Frameworks Version: 6.25.0
Qt Version: 6.11.0
Kernel Version: 7.0.3-zen1-2-zen (64-bit)
Graphics Platform: Wayland
Processors: 12 × Intel® Core™ i7-8700K CPU @ 3.70GHz
Memory: 32 GiB of RAM (31.3 GiB usable)
Graphics Processor: NVIDIA GeForce RTX 3060 Ti
Qt Version: 6.11.0
Wayland?
Nvidia?
@cc_spicuous_2, it might help if you post the entire kinfo instead of just a portion of it.
Qt Version: 6.11.0
Kernel Version: 7.0.2-x64v3-xanmod1 (64-bit)
Processors: 16 × AMD Ryzen 7 5700U with Radeon Graphics
Memory: 8 GB of RAM (5.6 GB usable)
Graphics Processor: AMD Radeon Graphics
The problem exists with the latest regular kernel, too. It works under MATE.
Seems to be an issue with KDE the past couple months. This from reddit…
From other forums, disabling hardware acceleration in Haruna - particularly for Nvidia graphics - may fix the problem.
That did it! In settings, got to Playback and set Hardware Decoding to disabled
Using the S key to take a screenshot now works. It created a folder in Pictures called Haruna screenshots.
Thanks!
I get this bug every now and then, 1 second it will be working then stop and then at some random point seems to fix itself.
