[Guide] Install Nvidia hybride graphics with Optimus and Vulkan support
Might have figured out what’s wrong with my setup. Optimus stopped working properly again and I couldn’t switch to hybrid graphics any more. Somehow… I think I was looking at NVidia graphics setup from the arch wiki and I stubled on kernel modules, modprobe and loading drivers. I manually loaded the nvidia-drm and was able to switch to hybrid again. Gonna try to make the change permanent, so I don’t have to manually load the driver. There might be many conflicting settings though.
Yeah, can’t get this to work automatically. I need to manually load the nvidia-drm driver and still prime won’t work. Messing with xorg.conf just messes up the system and SDDM doesn’t work.
I guess I need to set somethings up in modules/modprobe. I just don’t get what.
Edit: After removing and reinstalling nvidia drivers I got optimus to work properly. I just need to manually unload vfio drivers at boot, then restart optimus-manager and then switch to hybrid or nvidia mode.
Thanks… It works great and tested on CS GO with 5.7.11-arch1-1 and Nvidia 450.57 Driver with optimus software.
Welcome to the party @SuperSayiyajin :beers:
Welcome, @SuperSayiyajin glad it works :slight_smile:
P.s. I couldn’t get the prime render of load to work, but my current guide has worked right away with a clean install.
Regards wim
Thanks for your informations and warm wellcome.I tried too many linux distros and i think Endavour is my last stop.
I have a feeling that the gdm-prime package is now broken with the latest Gnome Desktop (“gdm” 3.36.3-6.) after core files from PAM were changed.
PAM and PAMBASE got updated, which might prevent you from login
Due to updates from pambase and pam you might take care about any .pacnew files in /etc/pam.d as for example pam_tally , pam_tally2 and pam_cracklib got deprecated
Symptoms of the Break:
  • When logging out with older Nvidia Cards that use the Nvidia 390 driver the GDM front end will crash at commend prompt.
  • Running the systemctl status gdm you will see the following errors:
gdm.service - GNOME Display Manager
Loaded: loaded (/usr/lib/systemd/system/gdm.service; enabled; vendor preset: disabled)
Active: active (running) since Fri 2020-09-04 23:13:19 EDT; 1min 18s ago
Main PID: 1159 (gdm)
 Tasks: 3 (limit: 18866)
 Memory: 9.0M
 CGroup: /system.slice/gdm.service
         └─1159 /usr/bin/gdm
Sep 04 23:13:19 hanna systemd[1]: Starting GNOME Display Manager...
Sep 04 23:13:19 hanna systemd[1]: Started GNOME Display Manager.
Sep 04 23:13:29 hanna gdm-fingerprint][3250]: PAM unable to dlopen(/usr/lib/security/pam_tally.so):>
Sep 04 23:13:29 hanna gdm-fingerprint][3250]: PAM adding faulty module: /usr/lib/security/pam_tally>
Sep 04 23:13:29 hanna gdm-fingerprint][3250]: gkr-pam: no password is available for user
Sep 04 23:13:36 hanna gdm-password][3249]: gkr-pam: unable to locate daemon control file
Sep 04 23:13:36 hanna gdm-password][3249]: gkr-pam: stashed password to try later in open session
Sep 04 23:13:36 hanna gdm-password][3249]: pam_systemd_home(gdm-password:account): systemd-homed is>
Sep 04 23:13:37 hanna gdm-password][3249]: pam_unix(gdm-password:session): session opened for user >
Sep 04 23:13:37 hanna gdm-password][3249]: gkr-pam: gnome-keyring-daemon started properly and unloc>
My Notes:
https://forum.manjaro.org/t/errors-after-stable-2020-08-28-update-in-gdm-service-which-seem-related-to-pam-changes/21424
Wich nvidia card do you use?
I have an older Thinkpad t430s with the Nvidia NVS 5200M GPU.
I installed nvidia-prime (with optimus-manager)
and in hybrid mode I can launch applications running with Nvidia GPU
run-prime program_name
works with my Intel i5-8300H (8) @ 4.000GHz/NVIDIA GeForce GTX 1050 Mobile
ps. shutting down the nvidia gpu for good needs some configurations if you swith to intel mode.Askannz explains power management in his wiki.Great program. I use PCI power control (cant harm you) and PCI remove to silence the Nvidia Gpu before switching to Intel.
Great!
Welcome to the club @Blahnik
I’ve tried this also, but hasn’t worked for me with my GTX1070. I can switch back to Intel usually, but xorg is still using nvidia, so I can’t launch my VM without a complete reboot.
Hello everyone. newbie here, really nub, i decided to make a USB and boot endeavor OS, titan, in my case, and i decided to use i3, doing some investigation i discover that my laptop have something what is called hybrid graphics, and the graphics that i have are NVIDIA Quadro M2000M (4GB) and Intel(R) HD Graphics P530 (128MB), i was using solidworks, and playing minecraft, but i no longer use solid, so i decided to go full Linux… the thing is that i can’t make work the nvidia graphics, whit optimus-manager-git or nvidia alone, my goal if it posible is to use the intel all the time and when its required, change to nvidia or use booth, im new in this world but im exited and want some helps,mi kernel is 6.18.45-1-lts, and i install endeavor os titan via online whit the i3 wm…
i instal the nvidia-dkms (nvidia-open-dkms) nvidia-utils and nvidia-settings…
That is because your card is not supported anymore. You need to install the 580.xxx driver from the aur.
More info here → NVIDIA GPU users, attention please! (Dec-2025) - #33 by MichelN
tanks, i think i remove the nvidia-470xx-dms that i just install and use the 580xx… tanks im almost done, after struggle like 2 days almost… tnk
Since this is a 6-year-old thread, it’s safe to assume that a lot has changed in the meantime.
Please start a new thread
close
