Can you guys please recommend me some kwin script that’s equivalent to gTile extension?
For those who doesn’t know, it’s an extension that will alow you to tile applications “manually”. I know we have a lot of automatic tiling scripts, but I havent found one which I can manually decide on windows sizes with a simple command.
3 aur/kwin-bismuth 2.3.0-1 [+11 ~1.45]
Addon for KDE Plasma to arrange your windows automatically and switch between them using keyboard shortcuts, like tiling window managers.
4 aur/kwin-bismuth-bin 2.3.0-1 [+7 ~2.58]
5 aur/kwin-bismuth-git 2.3.0.r35.g78eff10-1 [+3 ~1.35]
:: Packages to install (eg: 1 2 3, 1-3):
Those tile automatically. Although bismuth can very simply be turned off. I’ve never seen anything like gtile. Although I can’t stand it so I’ve never looked hard. Bismuth would definitely be my suggestion though.
Thanks for the inputs!
I definitely do not like “auto-tiling” window managers. But I like to quickly place windows on a grid just like gTile (or even windows 11).
Well, too bad. Thank you all anyway! =)
